Map Your Family and Send Travel Updates by Push Notifications
I don’t understand what you are trying to get at with the API keys linked to devices (they aren’t). I use the same API key for all of my google API calls (html5 push notifications, travel time, maps) because I enabled all of the APIs on a single project on googles website.
Reread the OPs configuration for the cameras and you’ll see that the API calls takes a latitude/longitude point(s) and your API key. A single API key handles an infinite number of latitude/longitude points (ignoring API rate limits).
If you can get a single map down from Google, then odds are you have an error somewhere else. Check your configuration to make sure valid latitude/longitude points are being fed to the cameras URL.
Everything works accordingly.
After redo everything again. Everything works fine now. Street view display, sometime have no image due to private road. But once I go outside, it display normally. I didn’t see any image yesterday because of devices are home and private road therefore no picture to display.
Thank you very much.
I cant get this part to work (yes i have replaced trackers :slight_smile: )
center_map_on:
value_template: >-
{% set center = states.input_select.center_map_on.state %}
{% if center == “Jeremy”%}
{% set lat = states.device_tracker.jeremys_iphone.attributes.latitude %}
{% set long = states.device_tracker.jeremys_iphone.attributes.longitude %}
{% elif center == “Anja”%}
{% set lat = states.device_tracker.anjas_iphone.attributes.latitude %}
{% set long = states.device_tracker.anjas_iphone.attributes.longitude %}
{% else %}
{% endif %}
{{ [lat,long]|join(’,’) }}
@dawnlord can you post your config so I can see where the problem may be? Also if you can use the </> formatting in the toolbar it’s more helpful. Thanks
I have copied all parts and everything works but this:
    center_map_on:
    value_template: >-
      {% if center == "Jeremy"%}
        {% set lat = states.device_tracker.xxx.attributes.latitude %}
        {% set long = states.device_tracker.xxx.attributes.longitude %}
      {% elif center == "Anja"%}
        {% set lat = states.device_tracker.yyy.attributes.latitude %}
        {% set long = states.device_tracker.yyy.attributes.longitude %}
      {% else %}
      {% endif %}
      {{ [lat,long]|join(',') }}
What names are in your input_select? You have to change those and then change the following lines accordingly.
{% if center == "Anja"%}
Yes they are also replaced, its the platform template giving errors:
ERROR (MainThread) [homeassistant.config] Invalid config for [sensor.template]: required key not provided @ data[‘sensors’]. Got None
Did you put it under sensors? Template sensor is a type of sensor and should be embedded under one.
Also the value_template should be indented 2 spaces (and everything underneath)
Yes its under sensors.
Now i tried as you said: (yyy = person 1, xxx = person 2).
Failed config
sensor.template:
- Invalid config for [sensor.template]: required key not provided @ data[‘sensors’]. Got None.
  • platform: template
    center_map_on: None
      center_map_on:
      value_template: >-
        {% if center == "xxx"%}
        {% elif center == "yyy"%}
        {% else %}
        {% endif %}
    sensors:
      center_map_on:
        value_template: >-
           {% else %}
           {% endif %}
With that code i get:
bad indentation of a mapping entry at line 89, column 20:
center_map_on:
Sorry. Was doing it from my phone and forgot something. I edited it above. Try again
Now it works thank you :slight_smile:
WOW - this is awesome. I continue to be blown away by the power of Home Assistant and the contributions individuals make for neat solutions like this. After a bunch of copy/pasting and some find/replacing I was able to stitch this together in a single package file and get it to work. Now I can work on tweaking little things with it (Notifications, timestamps, etc).
Thanks again @Jer78 ! This is great!
First of all thanks for sharing!
When you say IOS app? Did you mean IOS Home Assistant App or iCloud? Can you please kindly elaborate.
Some sort of device_tracker from the phone (I use the iOS app here)
Some sort of Notify (Again, using iOS)
I want implement my wife has iPhone and I have an android.
@Vin Yes, I use the iOS app for the device_tracker but I believe any sort of device_tracker that provides lat and long coordinates into HA should work just as well.
On the camera part of the config. Anyway to hide the API key using secret.yaml?
@Vin yes. I put the entire URL in the secret file and just reference it
Lol… thanks :slight_smile: it was that simple :slight_smile:
