I have the same problem. Did you find a solution for it?
I have about 10+ of these dimmers in my home so this was very helpful, thanks to everyone contributing here.
Regarding getting the red led to turn on when the light is off, I’m no programmer but I got it working, but not ideally.
First I defined GPI04 in the output:
section
- platform: gpio
pin: GPIO4
inverted: true
and then in the interval:
section, I added id(redled).turn_off();
and id(redled).turn_on;
interval:
- interval: 250ms
# https://esphome.io/guides/automations.html#interval
then:
- lambda: |-
auto dimmer_vals = id(dimmer).current_values;
if (dimmer_vals.is_on()) {
id(dimmer_lvl) = dimmer_vals.get_brightness();
if (id(dimmer_lvl) > .19) { id(led2).turn_on(); }
if (id(dimmer_lvl) < .20) { id(led2).turn_off(); }
if (id(dimmer_lvl) > .39) { id(led3).turn_on(); }
if (id(dimmer_lvl) < .40) { id(led3).turn_off(); }
if (id(dimmer_lvl) > .59) { id(led4).turn_on(); }
if (id(dimmer_lvl) < .60) { id(led4).turn_off(); }
if (id(dimmer_lvl) > .79) { id(led5).turn_on(); }
if (id(dimmer_lvl) < .80) { id(led5).turn_off(); }
} else {
id(redled).turn_on();
This appears to be working fine. However, I don’t have the blinking status light anymore when the switch is not connected, since it’s always solid red when the switch is off.
I’m not sure how to get this working.
I see in this configuration they got it to work by specifying platform: status_led
under light:
section
light:
- platform: status_led
pin:
number: GPIO4
inverted: True
But this doesn’t work when I try putting it this under light:
in the config discussed here.
Any idea what may be wrong?
I would love to get the status led function as well as the red led when the switch is turned off in the config built here.
Nope. Recently moved these back to Tasmota. Much less of a delay.
I know this is a bit old, but this thread was super helpful for me in updating my Martin Jerry dimmer switches to esphome from Tasmota, so I figured I’d drop a comment in case it helps anyone.
Regarding the delay when turning off the dimmer, I found this is a direct result of the value used for pwm_min_power
. Essentially, if you lower the pwm_min_power
value, you will lower the delay you are experiencing.
Logically, it makes sense as the “power off” sequence is likely going through a fixed dimming process before turning off the light. If you have a higher pwm_min_power
value, then the light will simply not dim any further during the “power off” sequence once the dimming value has gone below pwm_min_power
threshold.
Thank you for posting this, I changed the pwm_min_power setting from 15% to 5% and I no longer have the delay.
device_name: office-lights # hostname & entity_id
friendly_name: Office Lights # Displayed in HA frontend
pwm_min_power: 5% # keep dimming functional at lowest levels
no_delay: 0s # transition when changing dimmer_lvl & relay delay
transition_length: 0s # transition when turning on/off
long_press_min: .4s # minimum time to activate long-press action
long_press_max: 2s # maximum time to activate long-press action
long_press_up: 100% # long press brightness
long_press_down: 20% # long press brightness
long_press_main: 50% # long press brightness
