Maybe dumb, but do we need a ZBT-1 radio on the HA server for this to work?
I also got problems with the connection to Alexa.
(Matter Hub running as HA Addon, Port 5540, IPv6 enabled, iOs Alexa app with all app requests allowed).
What I don’t know (and understand what that’s got to do with it) is, which one of my Echo devices I should power cycle. I have a whole lot of different Echo types around my house and I already power cycled a few of them without success.
Can anyone describe to me how my iOs Alexa App technically connects to the HA Addon on my Homeserver? I don’t get it, sorry.
Also I enabled the debug logging, but I don’t know what it should look like when Alexa tries to connect to the hub. I’ve got a couple of Matter / MdnsScanner and Matter / Transaction entries, but that’s about it.
Thank you for your support.
edit:
I configured a second bridge with port 5550 and paired it with my Apple Homekit App. That works like a charm.
Hi, this looks like a fantastic solution to connect up Alexa and Google Home without using the cloud. I’ve given it a go, but both Alexa and Google Home fail to discover the hubs I’ve setup.
When I scan to see what ports are open on my HA instance, i don’t see 5540 or 5541, is this an issue ?
phil@desktop-phil:~$ nmap -p 1-10000 hassio
Starting Nmap 7.80 ( https://nmap.org ) at 2024-12-21 14:18 GMT
Nmap scan report for hassio (192.168.10.30)
Host is up (0.00019s latency).
Not shown: 9989 closed ports
PORT STATE SERVICE
22/tcp open ssh
111/tcp open rpcbind
199/tcp open smux
1883/tcp open mqtt
1884/tcp open idmaps
4357/tcp open qsnet-cond
5355/tcp open llmnr
8056/tcp open senomix05
8123/tcp open polipo
8883/tcp open secure-mqtt
8884/tcp open unknown
Nmap done: 1 IP address (1 host up) scanned in 0.28 seconds
however, they are open on UDP
phil@desktop-phil:~$ sudo nmap -sU -p 5539-5542 hassio
Starting Nmap 7.80 ( https://nmap.org ) at 2024-12-21 14:11 GMT
Host is up (0.00025s latency).
PORT STATE SERVICE
5539/udp closed unknown
5540/udp open|filtered sdxauthd
5541/udp open|filtered unknown
5542/udp closed unknown
MAC Address: E0:51:D8:15:69:1F (Unknown)
Nmap done: 1 IP address (1 host up) scanned in 1.41 seconds
I have ipv6 enabled locally and I see my google and alexa devices with valid addresses as well as my home assistant install and the phone I’m using for pairing.
What is not clear to me is the exact requirements, both logical and physical for setting this up correctly:
Most Matter devices use Bluetooth to perform the initial pairing during setup. Is that the case here ? eg. When trying to pair with Alexa via the Alexa app on my phone do I need to be within Bluetooth range of my Alexa Show, Home Assistant or both ?
It would be really useful to know exactly how the pairing workflow works in order to find a solution to my issue, as there is no feedback in the apps, or anything in the HA logs to indicate why the pairing does not work.
This is the log output from the addon.
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
Add-on: Home-Assistant-Matter-Hub
Publish your entities from Home Assistant to any Matter-compatible controller like Alexa, Apple Home or Google Home.
Add-on version: 3.0.0-alpha.57
You are running the latest version of this add-on.
System: Home Assistant OS 14.1 (amd64 / generic-x86-64)
Home Assistant Core: 2024.12.5
Home Assistant Supervisor: 2024.12.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
[ 2024-12-20T18:55:39.211Z ] [ INFO ] [ Matter / ServerNodeStore ]: Opened *dbd9cff8894a47b28dda5c0961dcd2e9* storage at /config/data/dbd9cff8894a47b28dda5c0961dcd2e9
[ 2024-12-20T18:55:39.279Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9* ready endpoint#: 0 type: RootNode (0x16) behaviors: 💤parts ✓index ✓basicInformation ✓accessControl ✓groupKeyManagement ✓generalCommissioning ✓administratorCommissioning ✓operationalCredentials ✓generalDiagnostics ✓commissioning ✓network 💤productDescription 💤sessions 💤controller ✓descriptor
[ 2024-12-20T18:55:39.284Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator* ready endpoint#: 1 type: Aggregator (0xe) behaviors: 💤parts ✓index ✓descriptor
[ 2024-12-20T18:55:39.543Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.light_office_light* ready endpoint#: 29 type: DimmableLight (0x101) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.543Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.switch_shelly1_f4cfa2e5e072* ready endpoint#: 31 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.544Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.script_livingroom_theatre_lights* ready endpoint#: 32 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.544Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.script_masterbedroom_bedtime_lights* ready endpoint#: 33 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.544Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.switch_sonoff_1000c02f0f* ready endpoint#: 34 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.545Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.switch_sonoff_10005045eb_2* ready endpoint#: 36 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.545Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.light_sonoff_10006977fc* ready endpoint#: 37 type: OnOffLight (0x100) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.546Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.light_sonoff_1000697f87* ready endpoint#: 38 type: OnOffLight (0x100) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.546Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.switch_sonoff_1000699f10* ready endpoint#: 39 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.547Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.light_sonoff_100051f65e* ready endpoint#: 40 type: OnOffLight (0x100) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.547Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.light_sonoff_1000c17c0f* ready endpoint#: 41 type: OnOffLight (0x100) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.547Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.light_sonoff_1000c1863f* ready endpoint#: 42 type: OnOffLight (0x100) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.548Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.light_spare_bedroom_light* ready endpoint#: 43 type: DimmableLight (0x101) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.548Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.light_sonoff_1000524960_123* ready endpoint#: 44 type: DimmableLight (0x101) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.548Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.light_kitchen_lights* ready endpoint#: 45 type: DimmableLight (0x101) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.549Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.light_stairs* ready endpoint#: 49 type: DimmableLight (0x101) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.549Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.light_dining_room* ready endpoint#: 50 type: DimmableLight (0x101) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.549Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.light_utility* ready endpoint#: 52 type: DimmableLight (0x101) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.550Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.light_front_garden_lights* ready endpoint#: 53 type: DimmableLight (0x101) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.550Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.light_master_bedroom* ready endpoint#: 54 type: DimmableLight (0x101) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.550Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.light_ambers_bedroom_light* ready endpoint#: 30 type: ExtendedColorLight (0x10d) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓colorControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.551Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.switch_sonoff_10005045eb_1* ready endpoint#: 35 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.552Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.light_summer_house_fairy_lights* ready endpoint#: 46 type: ExtendedColorLight (0x10d) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓colorControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.553Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.light_patio* ready endpoint#: 55 type: ExtendedColorLight (0x10d) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓colorControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.553Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.light_living_room* ready endpoint#: 51 type: DimmableLight (0x101) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.554Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.climate_upstairs* ready endpoint#: 47 type: Thermostat (0x301) behaviors: ✓identify ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓thermostat ✓descriptor
[ 2024-12-20T18:55:39.555Z ] [ INFO ] [ Matter / Endpoint ]: *dbd9cff8894a47b28dda5c0961dcd2e9.aggregator.climate_downstairs* ready endpoint#: 48 type: Thermostat (0x301) behaviors: ✓identify ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓thermostat ✓descriptor
[ 2024-12-20T18:55:39.557Z ] [ INFO ] [ Matter / Node ]: *dbd9cff8894a47b28dda5c0961dcd2e9* going online
[ 2024-12-20T18:55:39.665Z ] [ INFO ] [ Matter / Node ]: *dbd9cff8894a47b28dda5c0961dcd2e9* is online
[ 2024-12-20T18:55:39.668Z ] [ INFO ] [ Matter / AccessControlServer ]: initializing ACL manager with ACL
[ 2024-12-20T18:55:39.689Z ] [ INFO ] [ Matter / Commissioning ]: *dbd9cff8894a47b28dda5c0961dcd2e9* is uncommissioned passcode: 92777573 discriminator: 2029 manual pairing code: 16051756625
QR code URL: https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT:Y.K90C0R153X1U2J-10
[ 2024-12-20T18:55:39.732Z ] [ INFO ] [ Matter / ServerNodeStore ]: Opened *dbf403c9bf8e414a99e950c391794ee4* storage at /config/data/dbf403c9bf8e414a99e950c391794ee4
[ 2024-12-20T18:55:39.742Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4* ready endpoint#: 0 type: RootNode (0x16) behaviors: 💤parts ✓index ✓basicInformation ✓accessControl ✓groupKeyManagement ✓generalCommissioning ✓administratorCommissioning ✓operationalCredentials ✓generalDiagnostics ✓commissioning ✓network 💤productDescription 💤sessions 💤controller ✓descriptor
[ 2024-12-20T18:55:39.745Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator* ready endpoint#: 1 type: Aggregator (0xe) behaviors: 💤parts ✓index ✓descriptor
[ 2024-12-20T18:55:39.989Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator.light_office_light* ready endpoint#: 2 type: DimmableLight (0x101) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.989Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator.switch_shelly1_f4cfa2e5e072* ready endpoint#: 4 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.990Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator.script_livingroom_theatre_lights* ready endpoint#: 5 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.990Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator.script_masterbedroom_bedtime_lights* ready endpoint#: 6 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.990Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator.switch_sonoff_1000c02f0f* ready endpoint#: 7 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.991Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator.switch_sonoff_10005045eb_2* ready endpoint#: 9 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.991Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator.light_sonoff_10006977fc* ready endpoint#: 10 type: OnOffLight (0x100) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.992Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator.light_sonoff_1000697f87* ready endpoint#: 11 type: OnOffLight (0x100) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.992Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator.switch_sonoff_1000699f10* ready endpoint#: 12 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.992Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator.light_sonoff_100051f65e* ready endpoint#: 13 type: OnOffLight (0x100) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.993Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator.light_sonoff_1000c17c0f* ready endpoint#: 14 type: OnOffLight (0x100) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.993Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator.light_sonoff_1000c1863f* ready endpoint#: 15 type: OnOffLight (0x100) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.993Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator.light_spare_bedroom_light* ready endpoint#: 16 type: DimmableLight (0x101) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.994Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator.light_sonoff_1000524960_123* ready endpoint#: 17 type: DimmableLight (0x101) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.994Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator.light_kitchen_lights* ready endpoint#: 18 type: DimmableLight (0x101) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.994Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator.light_stairs* ready endpoint#: 20 type: DimmableLight (0x101) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.995Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator.light_dining_room* ready endpoint#: 21 type: DimmableLight (0x101) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.995Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator.light_utility* ready endpoint#: 23 type: DimmableLight (0x101) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.995Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator.light_front_garden_lights* ready endpoint#: 24 type: DimmableLight (0x101) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.996Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator.light_master_bedroom* ready endpoint#: 25 type: DimmableLight (0x101) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.996Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator.light_ambers_bedroom_light* ready endpoint#: 3 type: ExtendedColorLight (0x10d) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓colorControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.997Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator.switch_sonoff_10005045eb_1* ready endpoint#: 8 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.998Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator.light_summer_house_fairy_lights* ready endpoint#: 19 type: ExtendedColorLight (0x10d) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓colorControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.998Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator.light_patio* ready endpoint#: 26 type: ExtendedColorLight (0x10d) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓colorControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:39.999Z ] [ INFO ] [ Matter / Endpoint ]: *dbf403c9bf8e414a99e950c391794ee4.aggregator.light_living_room* ready endpoint#: 22 type: DimmableLight (0x101) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2024-12-20T18:55:40.001Z ] [ INFO ] [ Matter / Node ]: *dbf403c9bf8e414a99e950c391794ee4* going online
[ 2024-12-20T18:55:40.027Z ] [ INFO ] [ Matter / Node ]: *dbf403c9bf8e414a99e950c391794ee4* is online
[ 2024-12-20T18:55:40.028Z ] [ INFO ] [ Matter / AccessControlServer ]: initializing ACL manager with ACL
[ 2024-12-20T18:55:40.056Z ] [ INFO ] [ Matter / Commissioning ]: *dbf403c9bf8e414a99e950c391794ee4* is uncommissioned passcode: 96258425 discriminator: 2379 manual pairing code: 21880958752
QR code URL: https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT:Y.K90YDA13DCJN4B120
[ 2024-12-20T18:55:40.063Z ] [ INFO ] [ WebApi ]: HTTP server (API & Web App) listening on port 64877
[ 2024-12-20T19:10:39.803Z ] [ INFO ] [ Matter / DeviceCommissioner ]: All announcements stopped
[ 2024-12-20T19:10:40.181Z ] [ INFO ] [ Matter / DeviceCommissioner ]: All announcements stopped
Live
Intel x86 bare metal running HAOS 14.1, core 2424.12.5 and Home-Assistant-Matter-Hub 3.0.0-alpha.57 add on.
Any and all suggestions welcome…
OK, had another crack at this today and got both Alexa and Google Home working perfectly.
The solution was to attempt to pair with Alexa/Google right after restarting the add-on. I was also not in bluetooth range of either Alexa/Google Hubs or my HA system, so it looks like everyting works over the network without the use of bluetooth.
It appears that some time after starting up, the hubs configured in the add-on stop listening for new connections after a period of time.
Great to have full local integration to Alexa and Google Home without the cloud…, this is awesome
Same here. Although I could activate it on the iPhone XR (latest iOS Version) of my wife, but not on the iPad 10th Gen V18.2
Google Home keeps telling me, I would need a device to use this, which I clearly do not own (and do not want to xD)
If it was for the need of a device, why does it work on the iPhone?
iPhone with Home Kit - Port 5541 - works
Android 14 with Google Home - Port 5542 - doesn’t work
iPad with Home Kit - Port 5542 - doesn’t work
All three devices have a different Mail account.
I have the exact same issues, has anyone manged to solve it? I tried enabling ipv4/ipv6 dual mode on my router, and i can ping my HA’s ipv6, and the other way around.
Works fine with Apple Home, but with Alexa, the devices added aren’t showing up on the list of devices, yet they show up if you want to involve one of them with a routine. Not sure what the issue is. If you use the device (turn on, etc.) it shows up on the list of devices within Alexa for a moment, then disappears. Thank you for your hard work on this, I do think it’s awesome…Would love to see more support for various devices (garage door opener, water valve, etc.) They do work, but as lights and shades
The Hass Matter Matter (BETA) - Home Assistant is marked as Beta.
What Tobias Glatthar and contribs have done is create a 3rd party addon which is a complete matter hub that does not rely on the HA matter intergration as it provides that itself to publish ha items as matter devices. GitHub - t0bst4r/home-assistant-matter-hub: Publish your Home-Assistant Instance using Matter.
I think Matter (BETA) - Home Assistant is to import matter devices into HA where its stil Beta and you would prob never run both.
I had the same problems described in all of the above postings and had all the prerequisites.
Even restarting Alexa, putting them in the same room (for whatever reason), nothing helped. My home assistant is running bare metal on intel.
Then I read something about bridges only being available for a certain time after the addon started.
SUCCESS: stopping and starting the addon and starting the Alexa search within seconds „solved“ my problem. Now Alexa sees the bridge.
Wishing you luck.
I posted my solution further down: stopping and starting the addon and starting the Alexa search within seconds did the job for me. I also have mine running bare metal on intel.
I tried to install the add-on to my HA. However, the add-on is not starting.
The log shows only those errors:
exec /init: exec format error
Does anyone have an idea on how to get it to start?
Or to get some more detailed logs to narrow down the problem?
(I tried changing the settings to have more detailed logs, but this did not affect the logs)
Thanks for the help in advance!
Dunno 1. Installation
Hi @stuartiannaylor,
Thanks for the hint. I tried to uninstall/install as well as the rebuild button. In all cases it still shows the same logs when I try to start the add-on.
Any other thoughts?
Likely better speaking to themselves, but could be still taking a festive break.
No you don’t. You just need home assistant accessible on your network.
I have been running the original Matterbridge addon since 1.0.x, June 2024 and it has worked really well. Just this week I decided to try this new version but I’m finding it to be rather unstable and resource intensive compared to the original addon. Anyone else noticing this? Also, thermostat doesn’t work but I haven’t done any debugging.
I’m using this with Amazon Alexa. I unplugged all echos except my newest Echo Show with the strongest wifi connection to set this up.
I’m trying to get this working with my Google Home, and I can’t seem to get past the Can’t find device error during the adding process. I’ve rebooted everything, and the logs aren’t showing any useful errors. I think my IPv6 is working properly; I can ping the HA server’s IPv6 address. The bridge is showing 6 devices waiting to be added. Any ideas? Logs are below.
Add-on version: 3.0.0-alpha.58
Home Assistant Core: 2025.1.0
Home Assistant Supervisor: 2024.12.3
[ 2025-01-06T02:56:46.299Z ] [ INFO ] [ Matter / ServerNodeStore ]: Opened *d3962785729e4232914f0a7f306d1ce0* storage at /config/data/d3962785729e4232914f0a7f306d1ce0
[ 2025-01-06T02:56:46.404Z ] [ INFO ] [ Matter / Endpoint ]: *d3962785729e4232914f0a7f306d1ce0* ready endpoint#: 0 type: RootNode (0x16) behaviors: 💤parts ✓index ✓basicInformation ✓accessControl ✓groupKeyManagement ✓generalCommissioning ✓administratorCommissioning ✓operationalCredentials ✓generalDiagnostics ✓commissioning ✓network 💤productDescription 💤sessions 💤controller ✓descriptor
[ 2025-01-06T02:56:46.411Z ] [ INFO ] [ Matter / Endpoint ]: *d3962785729e4232914f0a7f306d1ce0.aggregator* ready endpoint#: 1 type: Aggregator (0xe) behaviors: 💤parts ✓index ✓descriptor
[ 2025-01-06T02:56:46.574Z ] [ INFO ] [ Matter / Endpoint ]: *d3962785729e4232914f0a7f306d1ce0.aggregator.switch_smart_socket_2* ready endpoint#: 59 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2025-01-06T02:56:46.574Z ] [ INFO ] [ Matter / Endpoint ]: *d3962785729e4232914f0a7f306d1ce0.aggregator.switch_smart_socket_3* ready endpoint#: 87 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2025-01-06T02:56:46.575Z ] [ INFO ] [ Matter / Endpoint ]: *d3962785729e4232914f0a7f306d1ce0.aggregator.light_string_lights* ready endpoint#: 4 type: ExtendedColorLight (0x10d) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓colorControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2025-01-06T02:56:46.576Z ] [ INFO ] [ Matter / Endpoint ]: *d3962785729e4232914f0a7f306d1ce0.aggregator.switch_smart_socket_1* ready endpoint#: 58 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2025-01-06T02:56:46.576Z ] [ INFO ] [ Matter / Endpoint ]: *d3962785729e4232914f0a7f306d1ce0.aggregator.switch_smart_socket_4* ready endpoint#: 60 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2025-01-06T02:56:46.577Z ] [ INFO ] [ Matter / Endpoint ]: *d3962785729e4232914f0a7f306d1ce0.aggregator.light_lab_fan_light* ready endpoint#: 81 type: ExtendedColorLight (0x10d) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓colorControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2025-01-06T02:56:46.580Z ] [ INFO ] [ Matter / Node ]: *d3962785729e4232914f0a7f306d1ce0* going online
[ 2025-01-06T02:56:46.741Z ] [ INFO ] [ Matter / Node ]: *d3962785729e4232914f0a7f306d1ce0* is online
[ 2025-01-06T02:56:46.748Z ] [ INFO ] [ Matter / AccessControlServer ]: initializing ACL manager with ACL
[ 2025-01-06T02:56:46.775Z ] [ INFO ] [ Matter / Commissioning ]: *d3962785729e4232914f0a7f306d1ce0* is uncommissioned passcode: 44328533 discriminator: 1957 manual pairing code: 15896527051
QR code URL: https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT:Y.K90C0R15KWGG6MZ00
[ 2025-01-06T02:56:46.787Z ] [ INFO ] [ WebApi ]: HTTP server (API & Web App) listening on port 64755
I have an amazon Echo Show 21, but i don’t succeed in getting the new (or old) addon discovered by Amazon Alexa.
The bridge itself is working on port 5540 and has the required devices. Somewhere was mentioned that the bridge is only discovered directly after starting the addon. Which I tried, but did not succeed.
What did you do to get it discovered by Alexa on your Echo Show?
Make sure your phone (device running Alexa app), home assistant and the Amazon Echo are on the same network and if your router has, enable mDNS. I didn’t do anything with ipv6 but it is enabled. I use an iPhone and often rebooting the iPhone helps with setting up things like this. iPhones have weird networking glitches. Matter is finicky too but when I set up the new add-on it just worked first time. When I set up the original Matterbridge add-on, I unplugged all my Echoes and plugged back in the one I wanted to use as a hub with the strongest wifi, so it was rebooted also.
I have same issue like a few above with the Google Home App running on Android 14 phone: after scanning the QR Code the message that “You need a hub for Matter to setup…” appears.
- ipv6 is working (tested with ping from raspberry running Home Assistant to the Android Phone)
- mDNS is working on my network (e.g., I can open my Deco device web admin UI from a browser using http://tplinkdeco.net/, which works with mDNS)
- I’ve rebooted Android and restarted the add-on and then tried immediately scanning the code
There is no error on the add-on logs, seem to be as expected
Add-on version: 3.0.0-alpha.61
System: Home Assistant OS 14.1 (aarch64 / raspberrypi4-64)
[ 2025-01-08T16:31:36.578Z ] [ INFO ] [ Matter / ServerNodeStore ]: Opened *e25b20e7255d4c34ab75c54e1c3b2c0f* storage at /config/data/e25b20e7255d4c34ab75c54e1c3b2c0f
[ 2025-01-08T16:31:36.929Z ] [ INFO ] [ Matter / Endpoint ]: *e25b20e7255d4c34ab75c54e1c3b2c0f* ready endpoint#: 0 type: RootNode (0x16) behaviors: 💤parts ✓index ✓basicInformation ✓accessControl ✓groupKeyManagement ✓generalCommissioning ✓administratorCommissioning ✓operationalCredentials ✓generalDiagnostics ✓commissioning ✓network 💤productDescription 💤sessions 💤controller ✓descriptor
[ 2025-01-08T16:31:36.953Z ] [ INFO ] [ Matter / Endpoint ]: *e25b20e7255d4c34ab75c54e1c3b2c0f.aggregator* ready endpoint#: 1 type: Aggregator (0xe) behaviors: 💤parts ✓index ✓descriptor
[ 2025-01-08T16:31:37.445Z ] [ INFO ] [ Matter / Endpoint ]: *e25b20e7255d4c34ab75c54e1c3b2c0f.aggregator.switch_sonoff_library_light* ready endpoint#: 2 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2025-01-08T16:31:37.446Z ] [ INFO ] [ Matter / Endpoint ]: *e25b20e7255d4c34ab75c54e1c3b2c0f.aggregator.light_entry_inside* ready endpoint#: 4 type: OnOffLight (0x100) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2025-01-08T16:31:37.449Z ] [ INFO ] [ Matter / Endpoint ]: *e25b20e7255d4c34ab75c54e1c3b2c0f.aggregator.switch_christmastree* ready endpoint#: 5 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2025-01-08T16:31:37.453Z ] [ INFO ] [ Matter / Endpoint ]: *e25b20e7255d4c34ab75c54e1c3b2c0f.aggregator.light_living_room_central* ready endpoint#: 3 type: DimmableLight (0x101) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2025-01-08T16:31:37.454Z ] [ INFO ] [ Matter / Endpoint ]: *e25b20e7255d4c34ab75c54e1c3b2c0f.aggregator.light_living_room_sofa* ready endpoint#: 6 type: DimmableLight (0x101) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2025-01-08T16:31:37.456Z ] [ INFO ] [ Matter / Endpoint ]: *e25b20e7255d4c34ab75c54e1c3b2c0f.aggregator.light_dinner* ready endpoint#: 7 type: DimmableLight (0x101) behaviors: ✓identify ✓groups ✓onOff ✓levelControl ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2025-01-08T16:31:37.466Z ] [ INFO ] [ Matter / Node ]: *e25b20e7255d4c34ab75c54e1c3b2c0f* going online
[ 2025-01-08T16:31:37.890Z ] [ INFO ] [ Matter / Node ]: *e25b20e7255d4c34ab75c54e1c3b2c0f* is online
[ 2025-01-08T16:31:37.905Z ] [ INFO ] [ Matter / AccessControlServer ]: initializing ACL manager with ACL
[ 2025-01-08T16:31:37.978Z ] [ INFO ] [ Matter / Commissioning ]: *e25b20e7255d4c34ab75c54e1c3b2c0f* is uncommissioned passcode: 24901274 discriminator: 167 manual pairing code: 01397815190
QR code URL: https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT:Y.K90SO527KIBH7.J00
[ 2025-01-08T16:31:38.013Z ] [ INFO ] [ WebApi ]: HTTP server (API & Web App) listening on port 62480
Is there anything else I can try?
