i got a breakthrough with maveo and wanted to share my progress with you.
In the beginning I used the code for the switches from @tomu, and it worked great.
But since I also wanted to read/show the current state, I was hoping that there is another way without doing crazy python scripts and such things. So I looked for an alternative and ended up with Node-RED.
But since these were my first attempts with Node-RED, I failed mercilessly at the beginning. After reading a lot about Node-Red, and watching countless videos, I was able to report initial successes.
So, enough chatter, here’s my solution:
Note: I’m not an expert in Node-RED and not sure if all values/nodes are necessary, but it works!
Since English is not my main language and I also use the German apps/software, I try to describe and translate everything as best as I can. For this reason please forgive me small mistakes/inaccuracies.
I created 5 button nodes
in Node-RED, one for each possible command (open, close, stop, lightOn and lightOff).- Edit each Entitiy Config and create a uniqe button.
e.g.
e.g.
Connected each of them with a change node
and as value i used a string with the command i wanted to send.- set: msg.payload
- e.g. value: C;name of your garagedoor;open
- list of possible commands:
Important:
The commands are case sensitive, and be careful not to accidentally use a comma instead of a semicolon!- C;name of your garagedoor*;open
- C;name of your garagedoor*;close
- C;name of your garagedoor*;stop
- C;name of your garagedoor*;lightOn
- C;name of your garagedoor*;lightOff
* Replace “name of your garagedoor” with the real name of your garage door!
Each of those change nodes is connected with its own tcp request node
but ensure to enable TCP in third party settings of your maveo app beforehand.- server: your local IP adress
- port: 2785
- return: Strings
- close: never
all of the change node are connected with one switch node
- “enthält” means “contains”
- “ansonsten” means “else”
- since the responses contains either closed, closing, open, opening, lightOn or lightOff, i ended up with the values shown in the screenshot so that I can distinguish the answers as follows:
- door:
- S;name of your garagedoor;open
- S;name of your garagedoor;opening
- S;name of your garagedoor;close
- S;name of your garagedoor;closing
- light
- S;name of your garagedoor;lightOn
- S;name of your garagedoor;lightOff
- command
- R;OK (valid commands are confirmed in this way)
- R;Error;…(Invalid Commands will be returned in this way)
- door:
after that i created one tcp out
and 3 function nodes
to cut off the first part of the response (which is always the same) so that only the actual status remains.
- door function:
- connect to switch node output “clos” and “open”
- under function Tab enter following code and enter your real garagedoor name:
msg.payload = msg.payload.split('S;**your door name**;')[1].substr(0, 8); return msg;
- light function:
*see small optional addition at the end.- connect to switch node output “light”
msg.payload = msg.payload.split('S;**your door name**;light')[1].substr(0, 3); return msg;
- command function:
- connect to switch node output “else”
- under function Tab enter following code:
msg.payload = msg.payload.split('R;')[1].substr(0, 5); return msg;
- tcp out
- connect every output of the switch not to this
- settings:
- connect to port: 2785
- host: your local ip address
- Then i created a text helpers for door, light and command feedback (e.g. input_text.garage_door_status). In order to fill them with the data, I needed a call service node
for each function node. Configure each node as follows:
- entity: choose the appropriate helper for each state
- e.g.
That’s all!!
Just create some dashboard cards and enjoy your fully controllable garage door including status feedback!
Small optional addition:
For the lights I wanted a tile that changes color depending on state (refer to screenshot above and below)
I couldn’t solve it any other way, so i created a few more nodes and connected these to the light function node:
one switch node
one entity switch node
enable input and create new device by clicking the edit button
- Name: whatever you like or call it
- Device: click edit Button and give it a name you like or call it, no further editing needed.
- Type: switch
as you can see in the screenshot below i entered nearly the same name everywhere - Device class: switch
two call service nodes
to toggle the switch (you just created) on and off.-
Now connect everything as shown in the screenshot above and your good to go.
