@swifty Could you open an issue on GitHub and provide in detail what code you are using, which version (goto: http:///esp_status), type of LED used etc. Also a serial log would be great.
Iām really glad to see that others are having the same issues with their LEDs turning off at random times, and itās not just me. I did see this: āHow To: Pick the right pins on the NodeMCU ESP8266 and ESP32ā, YouTube video recently, and was going to try to use a different output pin to see if that made the turning off issue disappear; since I used pin D6 like probably a lot of other people did.
Either way, Iām not smart enough to contribute much yet, but Iāll be standing by watching/hoping for a great outcome lol.
Thanks @debsahu - Managed to get it working now⦠embarrassingly iād typoād the MQTT port number in the config
When I couldnāt get the Android APK working reliably I assumed Iād done something wrong, but as soon as I fixed the MQTT port, it works seamlessly with HA.
Iām using the WS2801 branch you made, all effects Iāve tried work great, apart from ābreathā which seems to causes the leds to stop responding.
@debsahu You have a great project here! Just passing by to say thank you! Its working like a charm!
Best regards!
Cannot get this to compile - get an error - āDynamicJsonBufferā was not declared in this scope - tried making sure I had all the right library versions etc and it will not compile. Did anyone else run into this?
Install correct version of ArduinoJSON.
Which version? I tried l Iike 3-4 versions based on documentation on the github page, no dice.
As of today you can use https://github.com/bblanchon/ArduinoJson/releases/tag/v6.5.0-beta
Thanks! Iāll try to give it a go when I get a moment
I used https://github.com/toblum/McLighting as it is recently updated and it states than Home Assistant is supported.
When I go to the webpage of the ESP8266 I get the webinterface and the ledstrip is fuctional.
I added https://github.com/toblum/McLighting/blob/Before_AMQTT_NeoAnimationFX/clients/HomeAssistant/light.yaml to the configuration.yaml
I get the error:
Platform not found: light.mqtt_json
Invalid config for [automation]: expected str for dictionary value @ data[āidā]. Got None.
Any idea what iām doing wrong?
Oke changing:
- platform: mqtt_json
to - platform: mqtt
schema: json
gets rid of the Platform not found error.
The latest McLighting takes care of the change to MQTT JSON light since HA version 0.84. As suggested above, new client configuration is https://github.com/toblum/McLighting/blob/master/clients/HomeAssistant/light.yaml
Best LED lighting project out there at moment. It will be even better when E1.31 gets implemented, thanks to @debsahu
Ok, I used the new light.yaml and added the following code to configuration.yaml
mqtt:
broker: 192.168.1.105
port: 1883
client_id: home-assistant
keepalive: 60
discovery: true
discovery_prefix: homeassistant
Home Assistant config checker indicated that the automation idās should be str, so I changed them to id: āneo1ā and id: āneo2ā. Config check is ok now.
After reboot of HA I get a slider but the ledstrip is not responding. Should there also be a effect-selector?
Some more experimenting and even found https://github.com/toblum/McLighting/issues/223 (what didnāt help either).
Only thing I edit in definitions.h is
uncomment #define MQTT_HOME_ASSISTANT_SUPPORT
uncomment #define WIFIMGR_PORTAL_TIMEOUT 180
uncomment #define WIFIMGR_SET_MANUAL_IP
and set a fixed ip
#ifdef WIFIMGR_SET_MANUAL_IP
uint8_t _ip[4] = {192,168,1,105};
uint8_t _gw[4] = {192,168,1,1};
uint8_t _sn[4] = {255,255,255,0};
#endif
web-ui is working fine, but in HA I donāt get the light button/switch.
All instructions are here: https://github.com/toblum/McLighting/wiki/Homeassistant-integration did you use the higher bandwidth option?
It might just be that you have set a different HOSTNAME. The MQTT topics are based on your HOSTNAME! Automation for speed sliders canāt be added in MQTT Discovery. One has to manually add them and use the correct MQTT topics. Without the sliders you will be stuck in default speed, which should be reasonable for most animations.
I didnāt change the default hostname McLighting01, but now I have. I used Ledstrip01.
When I access 192.168.4.1 I can fill in MQTT values. Should this be done or can this be ignored?
In the light.yaml (which I copied in the configuration.yaml) I changed the HOSTNAME to.
I also removed the id: in de automations because they throw an error. The alias is now the leading (- ) row.
And I get this in the logging.
ERROR (MainThread) [homeassistant.components.mqtt] Failed to connect due to exception: [Errno 111] Connection refused
Sorry, Iāam new to MQTT. HA I have learned a lot past weeks
This helped me out. Thank you.
the NodeMCU has fixed ip on 192.168.1.105 and the HAraspberry 192.168.1.122
In the wifi page of the NodeMCU I used the following MQTT
192.168.1.122
1883
homeassistant
mqtt_password
I put
mqtt:
broker: 192.168.1.105 (also tried 192.168.1.122)
port: 1883
keepalive: 60
discovery: true
password: !secret mqtt_password
in configuration.yaml
Also the content from light.yaml
I keep getting the error
Oke after installing mosquitto by following
no errors. But still no reaction on the ledstrip when I change the speed.
What can I do next?
Update:
I got it working! HOSTNAME changing resulted that old and new name popped up in HA.
Been using this for a few days now and love, couldnāt get home assistant to automatically see it but overall very good work thanks
