Measuring 12v on ESP32 or ESP8266
you mean something like this?
https://it.aliexpress.com/item/1005004904872120.html?spm=a2g0o.productlist.main.1.3cb06f83K5Mlvg&algo_pvid=86632f94-566c-443c-b0c5-1db51a03cedd&algo_exp_id=86632f94-566c-443c-b0c5-1db51a03cedd-0&pdp_npi=4%40dis!EUR!3.69!3.69!!!4.02!4.02!%402103894417271007217707840e9598!12000030968453858!sea!IT!2692602029!X&curPageLogUid=XQeVPUj1Qra6&utparam-url=scene%3Asearch|query_from%3A
There in no way to use voltage divider to power something that draws variable current.
Esp can draw anything between 0 and 250mA and the voltage has to remain between 2.5V and 3.6V. Make your math… Otherwise who would buy expensive linear voltage regulators and buck converters… :wink:
Yes, I use several like this.
Yes and no.
Yes - your blind spot was due to the loads w/ ESP32, which being an SOC, there are maybe millions, if not more, of transistors keeps on and off, doing all kinds of stuff… essentially a bunch of mini switches for your programming…
And no, you should not consider doing voltage divider at all. Use buck converters please.
Ok, understood! Something like this.
I’m ordering the buck converter.
I have a quick question. From the picture below, it seems that the connections for Input, GND, and Output should be made to both pins of each pair. I assume it means one of the two pins and not both, correct?
Thanks to all for the suggestions
correct, one is enough.
