what version of Home Assistant are you running?
Home Assistant 0.117.5
I don’t know why you get this errors. I’ve just started hass with following config:
- platform: media_player_template
media_players:
denon:
friendly_name: Denon
value_template: >
{% if is_state_attr("remote.soggiorno", "current_activity", "Ascolta Spotify") -%}
on
{%- else -%}
off
{%- endif %}
turn_on:
service: remote.turn_on
entity_id: remote.soggiorno
activity: "Ascolta Spotify"
turn_off:
activity: "PowerOff"
volume_up:
service: remote.send_command
command:
- VolumeUp
device: 45938921
volume_down:
command:
- VolumeDown
device: 45938921
play:
service: media_player.media_play
entity_id: media_player.soggiorno
pause:
service: media_player.media_pause
next:
service: media_player.media_next_track
previous:
service: media_player.media_previous_track
mute:
command:
- Mute
device: 45938921
inputs:
Spotify:
command:
- InputMediaPlayer
device: 45938921
title_template: "{{ state_attr('media_player.soggiorno', 'media_title') }}"
album_art_template: "{{ state_attr('media_player.soggiorno', 'entity_picture_local') }}"
album_template: "{{ state_attr('media_player.soggiorno', 'media_album_name') }}"
artist_template: "{{ state_attr('media_player.soggiorno', 'media_artist') }}"
media_content_type_template: "music"
and I don’t receive any error’s. The only thing I could suggest is that you remove all the files in custom_components\media_player_template and redownload the latest release from https://github.com/Sennevds/media_player.template/releases/tag/0.0.3
That’s exaclty what I done, twice: first time when I installed it and now after your suggestion.
Unfortunately the issue appears.
You also deleted the pycache folder
I tried also. Nothing changed.
I downgraded to 0.1 leaving the template config and now the issue is different:
Invalid config
The following integrations and platforms could not be set up:
* [media_player.media_player_template](https://github.com/Sennevds/media_player.template)
Please check your config and [logs](http://192.168.2.101:8123/config/logs).
Version 0.1 of my component has less options. You should use the latest version.
It works when I add it to my setup(hass 0.117.5) so the problem is somewhere else.
Could you try to install the latest version with the config I posted above and send me your log file?
The log file is in het config folder
Yes I tested 0.1 just to understand better the issue. Normally I always used 0.3 erasing pycache every ti,e
Mi setup is 0.117.6 so similar to yours.
Below the full steps I made.
- Deleted folder for media_player_template in custom_components and pychache folder in custom_components folder. Commented the media_player_template code.
- Reboot - No error in logs
- Copy pasted the 3 files from 0.3 in custom_components folder (/config/custom_components/media_player_template) : media_player.py - manifest.json and init.py.
4: uncommented the following code:
media_player:
media_players:
denon:
value_template: >
on
{%- else -%}
off
{%- endif %}
turn_on:
turn_off:
volume_up:
command:
- VolumeUp
device: 45938921
volume_down:
command:
- VolumeDown
device: 45938921
play:
pause:
next:
previous:
mute:
command:
- Mute
device: 45938921
inputs:
Spotify:
command:
- InputMediaPlayer
device: 45938921
- Checked config and reboot.
- Now in notification I see this error message:
Invalid config
- template
- media_player_template.media_player
Please check your config and logs.
Here’s the log related:
2020-11-13 11:30:56 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for media_player_template which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-11-13 11:30:56 ERROR (MainThread) [homeassistant.setup] Setup failed for template: No setup function defined.
2020-11-13 11:30:56 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of media_player_template. Setup failed for dependencies: template
2020-11-13 11:30:56 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform media_player_template.media_player: Could not set up all dependencies.
Here’s the config used:
Here’s the full log:
Thank you for your patience and your support
Thanks for the files. I’ve finally found the problem!. I’ve added following code to the manifest.json
"dependencies": ["template"],
for integration in hacs but apparantly this tries to initiate template as a integration.
For now change that line to
"dependencies": [],
I will check what I need to change to be compatible with hacs! Sorry it took me so long to find out!
The issue is now gone with 0.4
Great work! I’m looking for a solution and I think this might be of great use. My goal is to create a media player that combined the volume attributes of other media players and gives an average number. But the important part is that when changing volume, the players linked to it need to change relatively.
Example:
Player A = 20% volume
Player B = 40% volume
This gives Player.template a volume attribute of 30%. When changing the volume to 31%, then all players need to add that difference relatively. So they don’t both go to 32%, but increase it to 21% and 41%.
Is this possible with this component?
Hmm this is a special case of course. I don’t think it’s currently possible to define 2 services to activate and you would need to have 2 different services because the volume_set service can only accept one entity(I think). But maybe I could change the code to accept multiple services like so:
set_volume :
- service: media_player.volume_set
data_template:
entity_id: media_player.player_a
volume_level: {{ }}
data_template:
entity_id: media_player.player_b
volume_level: {{ }}
And then use as volume level a template that calculates the volume level needed based on a sensor which holds the current main volume
edit:
So I just checked and following works:
set_volume:
- service: input_number.set_value
entity_id: input_number.volume_1
value: "{{ volume + 1 }}"
entity_id: input_number.volume_2
value: "{{ volume + 2 }}"
volume is the variable between 0 and 1
The integration is released to hacs!
I tested it and it works smoothy. Thank you!
Only one thing: when I turn on the device it can correctly take source info as template but the input_select source at start it empty while the tv-receiver will always start with a source of corse. Can it be implemented?
Below some screenshot
original device
template
You need to set the current_source_template to the right input
The issue was that the source had different names
any chance to have also fw re commands in ui?
This is my config:
media_players:
televisionecucina:
friendly_name: Televisione Cucina Template
current_source_template: >
{% if is_state('media_player.tv_cucina', 'off') %}
off
{% elif is_state('media_player.chromecast_cucina', 'playing') %}
HDMI
{% else %}
TV
{% endif %}
value_template: >
{% if is_state("media_player.tv_cucina", "on") -%}
on
{%- else -%}
off
{%- endif %}
turn_on:
service: media_player.turn_on
entity_id: media_player.tv_cucina
turn_off:
service: media_player.turn_off
volume_up:
service: media_player.volume_up
volume_down:
service: media_player.volume_down
mute:
service: media_player.volume_mute
play:
entity_id: media_player.chromecast_cucina
pause:
service: media_player.media_play_pause
stop:
service: media_player.media_stop
next:
previous:
inputs:
TV:
- service: remote.send_command
entity_id: remote.rmini_cucina_remote
command: b64:JgAaAA4JCRIMOggADJ8GZAYAAQgKxQsAAT0RAA0FAAAAAAAAAAAAAAAAAAA=
HDMI:
command:
- b64:JgCEAFYfDh4ODw0QDR8cDw0RDRANEA0QDRANEA4PDg8NEBwQDRANHg4PDRAOAArKVx4OHg0QDRANHxwPDhANEA0QDRANEA0QDRAODw4PHBANEA0eDg8PDg8ACslXHw0eDg8NEA0fHA8OEA0QDRANEA0QDRAODw0QDRAcEA0QDh0ODw4PDgANBQAAAAA=
- b64:JgBMAFYfDR4NEA0QLCwNEA0QDRANEA0QDRANEA0QHB4cEA0eHBANAAraVh8OHQ0QDRAqLg4PDRAODw4PDRANEA0QDRAcHh0PDh0dDw0ADQUAAAAAAAAAAAAAAAA
- b64:JgB4AFYfDh4ODw0QKi4ODw0QDRANEA0QDRANEA0QGx8bEA4PDh4NEA0ACstWHw0fDRANECotDg8OEA0QDRANEA4PDRANEBsfGxAODw0fDg8NAArLVh8OHg0QDRAqLQ0QDg8OEA0PDhANEA0QDg8bHxsQDRANHw0QDQANBQ==
title_template: >
{% if is_state_attr('media_player.chromecast_cucina', 'app_name' , 'Plex') %}
{{ state_attr('media_player.chromecast_cucina', 'media_title') }}
{% elif is_state_attr('media_player.chromecast_cucina', 'app_name' , 'Netflix') %}
{% elif is_state_attr('media_player.chromecast_cucina', 'app_name' , 'Spotify') %}
{% else %}
Live TV
{% endif %}
media_image_url_template : >
{{ state_attr('media_player.chromecast_cucina', 'entity_picture_local') }}
{{ state_attr('media_player.chromecast_cucina', 'entity_picture') }}
https://xxxx.xxxx.it/local/netflix.png
{% elif is_state_attr('media_player.chromecast_cucina', 'app_name' , 'Prime Video') %}
https://xxxx.xxxx.it/local/amazonprime.png
{% else %}
https://xxxx.xxxx.it/local/antenna.png
{% endif %}
artist_template: >
{{ state_attr('media_player.chromecast_cucina', 'media_artist') }}
{% else %}
Live TV
{% endif %}
media_content_type_template: >
tv_show
tv_show
music
{% else %}
video
{% endif %}
As you may see buttons are not there :
Template media player:
Chromecast media player:
Hmm strange I’ve just added next and previous in my test setup and it shows the buttons. Do you got any errors?
I’m giving this a go. I’m currently using the Universal Media Player to mash together my TV and receiver, and it is making me insane because I can’t customize the sources. I literally have two devices, an Xbox and an Apple TV, and I ultimately want to be able to tell Siri to switch to one or the other, and pick the correct inputs on both the TV and receiver when I do so. Hopefully this will achieve those aims–if not, maybe someone knows an easier way?
