Media_player.template
Hi again, it seems that amp does not support JSON API or the ssh but only uses the ancient telnet method.
You will have to use the telnet integration.
You should be able to do what you want this way.
Maybe you might want to use buttons instead of switches.
However, If your amp asks for a password with telnet, I don’t know how the telnet integration supports passwords.
Hi @Sennevds,
I just realized I’m getting this error in the log:
Log details (WARNING)
Logger: homeassistant.helpers.entity
Source: helpers/entity.py:1607
First occurred: 5:12:52 PM (3 occurrences)
Last logged: 5:12:52 PM
* Entity media_player.receiver (<class 'custom_components.media_player_template.media_player.MediaPlayerTemplate'>) is using deprecated supported features values which will be removed in HA Core 2025.1.
Instead it should use <MediaPlayerEntityFeature.PAUSE|SEEK|VOLUME_SET|VOLUME_MUTE|PREVIOUS_TRACK|NEXT_TRACK|TURN_ON|TURN_OFF|VOLUME_STEP|SELECT_SOURCE|STOP|PLAY|SELECT_SOUND_MODE: 89535>,
please create a bug report at https://github.com/Sennevds/media_player.template/issues and reference https://developers.home-assistant.io/blog/2023/12/28/support-feature-magic-numbers-deprecation
Apparently there already is an issue posted on the GitHub.
Have you abandoned the project or will you fix it at some point?
I have made a example universal media player and a template media player for a android device running the hass app:
- platform: universal
  unique_id: bluscream_phone
  device_class: tv
  commands:
    turn_on:
      service: notify.mobile_app_timos_handy
        message: command_media
          media_command: play
    turn_off:
          media_command: pause
    volume_set:
        message: command_volume_level
          media_stream: music_stream
          command: "{{ volume_level }}"
    volume_up:
          media_command: volume_up
    volume_down:
          media_command: volume_down
    volume_mute:
        message: "command_volume_level"
          media_stream: "music_stream"
          command: "{{0 if is_volume_muted else 15}}"
    media_play:
          media_command: play
    media_pause:
    media_stop:
          media_command: stop
    media_previous_track:
          media_command: previous
    media_next_track:
          media_command: next
  attributes:
    state: sensor.timos_handy_media_session
    is_volume_muted: >
      {{ "on" if states('sensor.timos_handy_volume_level_music') == 0 else "off" }}
    volume_level: sensor.timos_handy_volume_level_music
    # source: media_player.receiver|source
    # source_list: media_player.receiver|source_list
- platform: media_player_template
  media_players:
    receiver:
      unique_id: bluscream_phone2
      friendly_name: "Bluscream's Phone 2"
      device_class: receiver
      # current_source_template: "{{ states('input_text.selected_source') }}"
      value_template: >
        {{ 'on' if is_state("sensor.timos_handy_media_session", "Playing") else 'off' }}
      turn_on:
            media_command: play
      turn_off:
      volume_up:
      volume_down:
      # inputs:
      #   source 1:
      #     service: input_boolean.turn_on
      #     data_template:
      #       entity_id: input_boolean.source_1
      #   source 2:
      #     data_template:
      #       entity_id: input_boolean.source_2
      set_volume:
            command: "{{volume}}"
      mute:
            command: "{{0 if is_muted else 15}}"
      current_is_muted_template: >
      # album_art_template: "{{ state_attr('sensor.timos_handy_media_session','title_com.bambuna.podcastaddict') }}"
      title_template: "{{ state_attr('sensor.timos_handy_media_session','title_com.bambuna.podcastaddict') }}"
      album_template: "{{ state_attr('sensor.timos_handy_media_session','album_com.bambuna.podcastaddict') }}"
      artist_template: "{{ state_attr('sensor.timos_handy_media_session','artist_com.bambuna.podcastaddict:') }}"
Please leave some feedback and also tell me how i can do it without knowing the app package name
Is there a way to launch an app on android tv using this? E.g. call app package name to open?
My android tv project has locked adb, so adb commands don’t work.
EDIT:
Resolved using this…
