Media_player.volume_mute Toggle
A script seems way too complicated to solve a benign binary control like mute volume.
Make a int number or global. Assign it 1 meaning the sound is on,
and assume mute is off ( sound is on ) at first, because it ~always is.
If you call for mute, test if the number is 1,
then mute, decrement number
else unmute, increment number
Worst case, you have to hit it ONE more time in the beginning, to get in sync.
There, solved locally. This can be done with a boolean, template number, anything really.
cheers
Example using a global and simple assignment:
globals:
  - id: g_mute_state    #  USED TO MAKE   MUTE TOGGLE   MEDIA PLAYER CONTROL OVER NETWORK
    type: int
    initial_value: '1'  #  1 means volume ON              0 means mute is ON
switch:
    optimistic: true
    on_turn_on:   # WORKS BUT SHOULD BE  turn_on_action PER INFO
        - if:
            condition:
              lambda: 'return (id(g_mute_state) == 1);'
            then: # CALL FOR MUTE
              - logger.log: __________ MUTE __________
              - homeassistant.service:           ### MUTE
                  service: media_player.volume_mute
                    is_volume_muted: 'true'
                    entity_id: media_player.onkyoreceiver
              - lambda: '(id(g_mute_state) = 0);'
            else: # CALL FOR UNMUTE
              - logger.log: __________ UNMUTE __________
              - homeassistant.service:           ### UNMUTE
                    is_volume_muted: 'false'
              - lambda: '(id(g_mute_state) = 1);'
        - delay: 100ms
        - switch.turn_off: e32a_momentary
Your post will not work in home assistant. That’s clearly a ESPHome setup. I think you walked into the wrong thread. This will just confuse people. Not to mention, its way more complicated than a simple script.
Script
mute:
  mode: parallel
  fields:
    media_player:
      description: Media Player that will be mute or unmuted
      example: media_player.media_room
  sequence:
  - service: media_player.volume_mute
      entity_id: "{{ media_player }}"
      is_volume_muted: "{{ not state_attr(media_player , 'is_volume_muted') }}"
Use in automation action section or a script sequence
- service: script.toggle_mute
    media_player: media_player.onkyoreceiver
Use in the UI as a button’s tap action
tap_action:
  action: call-service
  service: script.mute
  service_data:
this is my simple automation:
  - alias: Mute volume ampli
    description: with lg remote control
    mode: parallel
      platform: state
      entity_id: media_player.lg_webos_smart_tv
      attribute: is_volume_muted
        - true
        - false
      to:
        - false
        - true
      service: remote.send_command
        device: NAD 350
        command: nad_mute
        device_id: 446xxxx6fb35xxxx536e50281xxxx04
If you want to use change “entity_id” (media player) and “action” section.
gb!
Hello people I just noticed that webostv.button has a mute toogle
I put this code direct on the Android TV card
volume_mute:
    service: webostv.button
     entity_id: media_player.lg_recamara
    data:  MUTE
Works just fine!!!
fyi :
sequence:
  - if:
      - condition: template
        value_template: >-
          {{ is_state_attr('media_player.lg_webos_tv_um7400plb',
          'is_volume_muted', true) }}
    then:
      - action: media_player.volume_mute
        metadata: {}
          is_volume_muted: false
          entity_id: media_player.lg_webos_tv_um7400plb
    else:
        metadata: {}
          is_volume_muted: true
alias: tvlivingmute
description: ""
I tried using your script as a generic mute script for media players but I’m getting this error message just trying to save it.
Message malformed: extra keys not allowed @ data[‘mute_toggle’]
I assume you tried it via the UI? Then you need to remove the first line. That’s only needed when you copy it into scrips.yaml manually.
Can’t remember now to be honest, I think it was a yaml script but I probably did something else wrong. Instead I just used condition A/B to write one, will just duplicate it for any devices needing mute. Thank you though :slight_smile:
