This javascript widget really rocks. makes things o much easier. Finally I have volume buttons without automations etc. much easier than sliders on a small touchscreen.
Thanks!
Thanks!
I have one more question: Iām using the mediapalyer widget. But I do not want the volume up /down buttons and got rid of them like this:
mpd:
widget_type: media_player
entity: media_player.mpd
level_up_style: "display: none"
level_down_style: "display: none"
level_style: "display: none"
text_style: "display: none"
However the % is still visible:
How do I get rid of the % ?
you cant unless you start creating a custom mediaplayer component.
the % sign is hardcoded in HTML.
So I can clone the existing and remove it easily? I suppose it then needs to go into custom_widgets?
yes, it needs to go in custom widgets and when you clone it there you can use the same naming.
but remember that with a next AD update you can get in trouble if something changes and your custom widget has the same as an original.
