@theneweinstein, I’m getting this error:
sqlite3.IntegrityError: UNIQUE constraint failed: statistics.metadata_id, statistics.start_ts
It makes sense not to duplicate start_ts
but how to implement it?
It’s a bit hairy (my first nested SQL statement) but it works for me.
stmnt = f"""UPDATE {table}
SET metadata_id = {target_sensor_id}
WHERE metadata_id = {source_sensor_id} AND start_ts NOT IN
(SELECT s.start_ts FROM
(SELECT start_ts FROM {table}
WHERE metadata_id = {source_sensor_id}) s
INNER JOIN
WHERE metadata_id = {target_sensor_id}) t ON s.start_ts = t.start_ts);
The idea is to check for duplicated start_ts
rows and ignore them in UPDATE
Is there now a solution for people who are not experienced in SQL programming? I currently have 3 endities in the energy dashboard that are no longer updated, just so I don’t lose the information. After 6 months. I can’t/don’t want to leave the old one in every time I change a device/sensor just to keep an eye on the data from the past.
Since version 2023.4 home assistant keeps its history when you rename an entity (see link). As far as I know it is not possible to merge old entities from before that time. The script I made worked for that, but requires some understanding of SQL. I’m neither a SQL programmer, just a lot of trail and error (with a backup of the database of course) did the trick in the end.
Looks great! Is this something i can execute in phpmyadmin?
No, it is a python script that needs to be executed from HA shell (python merge.py
when in config
directory). The complete script is as below. Like other said, this should be a last resort solution and preceded with a backup of your data. I needed it once to merge entities, each with a different part of history in it.
mapping = {
'sensor.source_entity1': 'sensor.dest_entity1',
'sensor.source_entity2: 'sensor.dest_entity2',
import sqlite3
import pandas
#pandas.options.plotting.backend = "plotly"
# Read sqlite query results into a pandas DataFrame
con = sqlite3.connect("home-assistant_v2.db")
def merge(source_sensor, target_sensor, table='statistics'):
print(f"source: {source_sensor}, target: {target_sensor}")
# read data from target sensor
target_sensor_id=pandas.read_sql_query(f"""select id FROM statistics_meta
where statistic_id like '{target_sensor}';""", con).loc[0,'id']
target_df=pandas.read_sql_query(
f"select * FROM {table} where metadata_id = '{target_sensor_id}';", con
print(f"length of existing statistics for target sensor: {len(target_df)}")
min_dt = target_df["start"].min()
# read data from source sensor
source_sensor_id=pandas.read_sql_query(f"""select id FROM statistics_meta
where statistic_id like '{source_sensor}';""", con).loc[0,'id']
source_df=pandas.read_sql_query(
f"select * FROM {table} where metadata_id = '{source_sensor_id}';", con
print(f"length of existing statistics for source sensor: {len(source_df)}")
# concat new historical statistics with updated old statistics
#df = pandas.concat([source_df, target_df], ignore_index=True).sort_values("start")
# set metadata_id to the one of the target sensor
#df["metadata_id"]=target_sensor_id
stmnt2 = f"""UPDATE {table}
WHERE metadata_id = {source_sensor_id};"""
INNER JOIN
stmnt3 = f"""SELECT * FROM {table}
INNER JOIN
cur = con.cursor()
cur.execute(stmnt)
con.commit()
#res=pandas.read_sql_query(stmnt2, con)
#print(res)
def merge2(source_sensor, target_sensor):
for table in ("statistics", "statistics_short_term"):
print(table)
merge(source_sensor, target_sensor, table)
for source_sensor, target_sensor in mapping.items():
Hi! Any updates on this? I tried this script, it successfully read the data from the old sensor, but didn’t write it to the new sensor. Any ideas?
upd: it didn’t read old sensor statistics, but read statistics_short_term
Is it possible to give me a step by step instruction if i just want to replace one defect power switch for a new one and keep the history? (so basically move the energy history to the new switch).
I still read conflicting posts:
Before 2023.4:
After 2023.4 (history is retained with renaming entities)
Found this: 2023.4: Custom template macros, and many more new entity dialogs! - #621 by e-raser?
oh god this does the trick. didn’t expect to delete the old entitiy first and get it working by simply renaming the new to the old name. Thank you very much for your hint.
This is the python script adapted from @ndrwha331 to update states instead statistics:
mapping = {
'sensor.source_entity2': 'sensor.dest_entity2',
import sqlite3
import pandas
def merge(source_sensor, target_sensor):
target_sensor_id=pandas.read_sql_query(f"""select metadata_id FROM states_meta where entity_id like '{target_sensor}';""", con).loc[0, 'metadata_id']
target_df=pandas.read_sql_query(f"select * FROM states where metadata_id = '{target_sensor_id}';", con)
print(f"length of existing states for target sensor: {len(target_df)}")
source_sensor_id=pandas.read_sql_query(f"""select metadata_id FROM states_meta where entity_id like '{source_sensor}';""", con).loc[0, 'metadata_id']
source_df=pandas.read_sql_query(f"select * FROM states where metadata_id = '{source_sensor_id}';", con)
print(f"length of existing states for source sensor: {len(source_df)}")
stmnt2 = f"""UPDATE states
cur = con.cursor()
cur.execute(stmnt2)
con.commit()
I’ve tested it, but make a BACKUP for security!!!
Does this script take into account possible differences in unit_of_measurement? For instance I have two sensors I want to merge, but one of them registered energy in kWh and the other in Wh, so I’d need to account for that by multiplying the first series by 1000 so that the unit sizes match up.
not sure if this integration is already mentioned her. might be usefull to someone on this thread
I used it myself succesfully
I can confirm that in 2024.4.4 it certainly doesn’t retain history. I’ve renamed a few devices (after which it prompts to rename the identies, which I did). History is now gone.
Refresh the page.
No, it’s gone.
Just tested with another entity. If I change the name, old history disappears.
But when I change the name back to the old name, the history reappears.
So renaming an entity effectively causes the history to be ‘lost from view’.
I’m up to date with v2024.8.3 and followed the following steps:
What I see happening:
I think what effectively happens: device starts using the old entity name and records sensor data on that entity name from here on. The data of the old and new entity don’t get merged. This still leaves a gap of the historical data of the new device before it gets renamed.
Would love to get 1 historical perspective on recorded sensor data. To get to that merging the historical data of the two entities into one entity makes sense. If I understand correctly, the Python script provided in this thread will do just that. However, I fear I might corrupt the data model Home Assistant expects now or in the future.
Does anyone know if there any plans to create official support for this and make merging a replacement device into a replaced device a breeze? Maybe even through the UI?
Do not rename the new entity. History follows the entity when you rename it. You delete old entity, integrate new entity with old entities name. That is the only way. You cannot have both on the system at the same time, if you do, the migration will not occur.
There are no plans as far as I can tell. For now, you’ll have to wait for a volunteer to pick it up.
If I understand you correctly. If I’ve have been running “entity_name” for 3 months, device broke down. Then added the replacement which accidentally was named “entity_name_2” because “entity_name” was already taken. Ran under the new “entity_name_2” for another 3 months. Only then to realize the history data is now on 2 entities.
In the scenario above there is no way to merge the data. Correct?
