Thanks very much for sharing this, it was very helpful!
FWIW, this is my version, updating old entity ids instead of delete/appending.
Use at your own risk of course, Backup your DB first.
Error handling is kind of cruddy.
I run this interactively via the pyscript kernel.
import pandas as pd
import sqlite3
import pandas as pd
con = sqlite3.connect("home-assistant_v2.db")
def update_id(old_sensor_id, new_sensor_id, table):
assert table in ["statistics", "statistics_short_term", "states"]
log.warning(f"Updating {old_sensor_id} to {new_sensor_id} in {table}")
try:
if table == "states":
# States
ts_field = "last_updated_ts"
old_meta_id = pd.read_sql_query(f"""SELECT metadata_id
FROM states_meta
WHERE entity_id = '{old_sensor_id}';""", con).loc[0,"metadata_id"]
new_meta_id = pd.read_sql_query(f"""SELECT metadata_id
FROM states_meta
WHERE entity_id = '{new_sensor_id}';""", con).loc[0,"metadata_id"]
else:
# Statistics
ts_field = "start_ts"
old_meta_id = pd.read_sql_query(f"""SELECT id
FROM statistics_meta
WHERE statistic_id = '{old_sensor_id}';""", con).loc[0,"id"]
new_meta_id = pd.read_sql_query(f"""SELECT id
WHERE statistic_id = '{new_sensor_id}';""", con).loc[0,"id"]
new_ts_min = pd.read_sql_query(f"""SELECT MIN({ts_field}) as ts_min
FROM {table}
WHERE metadata_id = '{new_meta_id}';""", con).loc[0,"ts_min"]
stmnt = f"""UPDATE {table}
SET metadata_id = {new_meta_id}
WHERE metadata_id = {old_meta_id}
AND {ts_field} < {new_ts_min}
cur = con.cursor()
cur.execute(stmnt)
con.commit()
except Exception as e:
log.warning(e)
pass
# mapping of the sensors, statistics of the left ones will be merged into the right ones
mapping={
"sensor.solarman_ac_temperature": "sensor.solarman_temperature",
"sensor.solarman_current_l1": "sensor.solarman_internal_l1_current",
"sensor.solarman_current_l2": "sensor.solarman_internal_l2_current",
"sensor.solarman_inverter_l1_power": "sensor.solarman_internal_l1_power",
"sensor.solarman_inverter_l2_power": "sensor.solarman_internal_l2_power",
"sensor.solarman_grid_current_l1": "sensor.solarman_grid_l1_current",
"sensor.solarman_grid_current_l2": "sensor.solarman_grid_l2_current",
"sensor.solarman_grid_voltage_l1": "sensor.solarman_grid_l1_voltage",
"sensor.solarman_grid_voltage_l2": "sensor.solarman_grid_l2_voltage",
"sensor.solarman_total_grid_production": "sensor.solarman_total_energy",
for old_sensor_id, new_sensor_id in mapping.items():
for table in ["statistics", "statistics_short_term", "states"]:
Thanks again
