djm
September 2, 2021, 11:34am
42
This plug integrates with HA, but it only displays Power in Watts. Is it possible to display the Energy, in kWh? As it does, in Meross app?
si, devi creare un sensore in HA che trasforma i w in kwh
maurizio53
(Maurizio Fabiani)
November 24, 2022, 11:58am
44
Puoi darmi un esempio su come creare questo sensore?
Certo, scusami ho letto soltanto adesso il tuo messaggio:
maurizio53
(Maurizio Fabiani)
December 26, 2022, 3:12pm
47
Grazie, una domanda:
questo sensore traccia il consumo attuale e non quello generale dello switch, giusto?
Se volessi avere un sensore del consumo totale come potrei fare?
Con questo trasformi da w a kwh ed è un sensore totale di kwh
Samtrois
(Sam)
January 16, 2023, 1:02am
49
this might be what youre looking for
I am new to all this, so apologies if I use some wrong terminology.
I was trying to acheive something similar to create a sensor/meter to sum the Watts used on a Meross (mss310) smart plug I have.
My current method is using a ‘Riemann sum’ (trapezoidal, time unit = hours) based on the watt entity of my smart plug. This just constantly sums the W reading from my smartplug, so after a few days I’m at a few KWh. not ideal.
Then I created a ‘utility meter’ using the above riemann sum, and using a…
can we read the weekly, monthly and yearly consumption? That would add lots of info to the integration. The meross app shows these values.
