Very little of that was correctly formatted: please use the </> button, or surround with three backticks:
CODE GOES HERE
Still not clear what “starting an entity card” means. If you’re manually triggering the automation, it will immediately run the actions. Otherwise it’ll wait for the set time.
If you want to be able to enable / disable it, create a toggle helper (input_boolean) and put that in the condition block:
[quote=“Tim6, post:18, topic:670139”]
I made an entitycard:
type: entity
entity: automation.verwarming_aan_op_gegeven_tijd
name: verw aan op tijd
When I click on the card I get a window, where I can set the automation on / of.
In that window I also can click on “perform action”.
With the automation “on” nothing happens. When I click on “perform action” the temperature is set immidiatly.
The alias: “Verwarming aan op gegeven tijd” is confusing for you.
I dont want to set verwarming on / off, but set the temperature of the verwarming at a set time.
Therefore the input_boolian does not work.
Thanks you for helping me!
This is working for me:
alias: Verwarming aan op gegeven tijd
description: ""
triggers:
- trigger: time
at: input_datetime.invoer_tijd_test
conditions: []
actions:
- action: number.set_value
entity_id: number.smo_40_room_sensor_set_point_value_heating_climate_system_1
value: 21
mode: single
