I’ve had two uncovered on the balcony running pretty well for about two years. In recent months, the battery of one that gets more rain exposure now keeps getting a flat quickly (a month or so). So I thought I’d try this as a hopeful and easy trouble shooting attempt. They’re both on the same firmware/configuration etc.
I have stopped paying attention to the battery sensor and just decided to let them fail before I change the battery. So far so good. I guess they could have changed the algorithm for battery level percentage.
Hi @Gymnae How are your mi flora sensor batteries doing?
I’m on the verge of ordering some and trying to see if the 2mo battery life has been solved.
There’s a myriad of options on aliexpress and who knows what i’l actually get. Some say green is the CN version, some dont.
I’m also wondering about using them in larger planters. ~10-12" deep. There was a larger version but it seems to have fallen off the face of the earth, and never worked right from what I can find.
You guys that are putting this device out in the elements without protection are eventually going to get electronic aids. The thing ain’t protected at all from moisture. Unless things have changed during the factory assembly,
Probably quite likely that it affects the temp I guess (although I only really monitor the moisture and light sensors myself). Can’t say I’ve noticed condensation, but I guess it would make sense that it would create a greenhouse effect.
Hello everyone, joining the family of the complainers.
I was me too cursed by some sensor getting shorter and shorter life, I have 14, all outside, and now some of them are dying in just around 5 days. So I decided to find a solution.
I share the point that it must be temperature or humidity related, or both, because they always die by night.
I tried to coat them with plastidip but nothing.
So I opened one and powered it by 3V (actually 3.3V at the moment, but seems to work).
What I have noticed is that the idle power consumption is spiky but averaging on 30uA, during polling by the bridge goes at 100uA and time to time does it by its own. This matches with what I read that the chinese market version is actually actively communicating from time to time.
This alone would not be enough to justify the short life of the sensors.
BUT here comes the interesting part I realized that if I power cycle the sensor, it stays in a kind of pairing mode consuming astonishingly high 2-3mA till it gets a bridge connection which in my case is every 30 minutes. This may be the reason for my sensors suicides.
Now I assume that during cold nights the voltage of the batteries drops low enough to power cycle the sensors and then the guys when warm again get powered and jumps into this pairing mode, then wait for their death in there…
Now I’m working on a way to power them externally with a battery each 4 or 6 of them and then cut the power by night. I will keep you updated.
I’m tinkering with powering them from 3.7V 18650 lipos. It works for tests. Do you or others have thoughts on the likelihood of death from lipo voltages as opposed to 3v button cell?
Different voltages seem to radically affect results anyway (values around 20% are on 3.7V, values around 5% are on 3V). I wonder how much this factor affects readings over the voltage range of the cells battery life?
Maybe I’ll look at cheap/efficient ways to step down 3.7V to 3V. If anyone has any pointers (@tom_l ?) please shout out, otherwise I’ll get Googling. Like I found this [TPS63031], but I don’t know what I’m doing yet…
Hi, to try reducing the battery consumption I bought a Xiaomi Gateway v3 and I connected it with HA using the following addon: https://github.com/AlexxIT/XiaomiGateway3
I’m also feeding Influxdb for data analysis
Let’s see how long the batteries work
