This is possible, however I would add an IR LED to the dongle instead of sending IR commands from another device, way easier since you don’t have to configure all the IR codes corresponding to a current temperature.
This is a section out of one of my dongles, I use the dongle designed by Sergey Dudanov with a wire connected from the dongle to the ACs IR receiver.
I have a Midea A/C and bought a USB WiFi module to controle it through the MSartHome application (former MideaAir). Now I Googled about integrating it in HomeAssistant and I saw that v0.8.1 was just released with better app support (Release v0.8.1 · nbogojevic/homeassistant-midea-air-appliances-lan · GitHub)
Now I’ve succesfully got my Midea HVAC split unit into HomeAssistant, the only problem is I can’t get it turned on and off…
When added it comes with only 1 sensor and 2 entities.
So, I’ve added the climate.airco_devicename into my dashboard but I can not get it to turn on or off… As the “beep” thing is a switch I’d reckon that would do the job but when I call the beep option I can hear a beep on the device but the display is not turning on nor the device is active. When I move the slider to change temprature the device beeps so it’s reacting to input from HA but it’s not turning the AC on.
When I tap the switch button I also get an error in my frontend “Can’t call sensor/turn_off Service not found”
Just came to the conclusion that when I turn on the A/C with the remote and then try to change the state in HA it turns itself off… I’m flabberguested…
What? Picture please. I have this dongle. Would like to replicate what you did here.
I would love to do some of those midea_ac actions but do not understand the syntax of ESP. Is this saying, when a value is found, turn on follow_me with the value just received?
Hi, I have two Midea mini split units working with the ESP-01s and the adapter module. Everything is working fine but there’s an issue with setting the temperature to 16°C (60°F), it bounce back to 18°C. Is anyone else having this issue?
climate:
- platform: midea
period: 2s
timeout: 4s
num_attempts: 3
autoconf: true
beeper: true
visual:
min_temperature: 17 °C
max_temperature: 30 °C
temperature_step: 1 °C
With the remote and the Midea App you can set the temperature down to 16. With espHome I can set 16 if I set the target temp to 17 in home assistant. I tried changing the min_temperature to 16 in the visual section but it has the same behavior.
I’m so excited to do this thank you for all the work!!! I have a possibly dumb question, I have a Mr Cool diy 12k and I’m wondering if I can use an esp32 instead of an esp-01 since I have a few extra 32s. Would it be more trouble then it’s worth? Will I still need a logic level converter?
Should be fine, esp32 is basically a newer and better version of the esp8266….
and yes, you’d still need the level shifter,
Esp’s are 3,3volt while AC is 5v.
Chance is it would work, but it could also damage the AC, so i wouldn’t take the risk
Thank you! It was a bad adapter so It works now, although now I’m trying to add the IR transmitter. I soldered it in directly and it seems that’s not the right way of doing it according to some pictures, is there a place I can see how it needs to be soldered?
