As I don’t speak Czech, I can’t say, sorry! Your best bet is, get the app they’re offering and investigate it. Normally you can find at least some information, that might point into a Midea direction.
Look at the app, compare the design to the Midea standard app, track, where the app is connecting to.
Hi @paddy0174, thanks for response! This is not a Czech specific AC it should be solved all over the world. Also the brand Inverter is mentioned as supported on esphome sides (and this is Inventor V5MDI32). I do not have the AC yet, but I am considering buying it so I would like to know if it can be controlled locally by HA.
P.S. if it could be controlled, how the follow me feature works? Can I send the room temperature from HA to AC so I do not have to have original thermostat? Is it sent via the USB?
Hi. My AC’s dongle is not exactly a typical USB type. It has different shape and the ordinary USB male will not fit. Check attached photo. Any suggestions please?
Ok, i did the hack with cutting the edges.
Now i can see the status , i can see the temperature, i can change the speed fan but i cannot change the mode and also cannot turn it on or off.
In logs i can see this →
Thanks mate, just coming back to this. I saw your page and have bought one of your controllers back in December. What throws me off is that I only have P,Q,E for coms and nothing labeled X1 or A/B
Those connections (A, B, E, H1, H2) should be in the remote controller of the heat pump. The remote controller is the display which could be built (screwed) in in the internal unit.
sorry for just asking but I lost track reading 1000+ posts in this thread. I’d like to integrate my AC’s in HA. Regarding the pictures here I have the suspicion that my “Airwell” AC might be a Midea-rebrand.
Could you guys tell me if this might work out and what I would need to order? Best case some ready-made USB-stick (" iot-uni-dongle" ?) in the EU or Germany.
If this ain’t possible I can solder myself as well if needed.
Hi all,
Has anyone by any chance tried to communicate directly to the interface on the display? I have a unit that has no populated CN3 or wifi compatibility.
I noticed that the little screen daughter board with the IR receiver communicates to the unit via UART 2400 baud, the daughter board doesn’t seem to be stupid as it only activates and functions.when it receives feedback from the main unit. It could be interesting to extend support to “incompatible” units. I have a few of these midea minisplits (comfee), they’re currently being controlled through an IR transmitter with esphome but it often gets annoying as the units are controlled remotely and sometimes they do not turn on or off
Hi all, I’ve received the SLWF-01pro (v.2.10) today. I didn’t manage to get the toggle buttons working (Display Toggle & Swing Step). Also the following sensors are not available/showing:
As for the toggles; it gives the following errors in ESP:
16:36:48 [W] [component:237]
Component web_server took a long time for an operation (187 ms).
16:36:48 [W] [component:238]
Components should block for at most 30 ms.
I am on the same boat. I cut out the little ends on my MrCool unit, and plugged in the usb, everything works except for those things above.
I am also trying to change to F from C. I can’t seem to figure it out. I really want the display to turn off like it does when you click the led button on the physical remote.
There is a humidity sensor on this unit at least its on the remote (which is where it shows up)
Either way, I just need the led to turn off. I can do it with the remote, its an option on the controller but it doesn’t work
Hi everyone.I’m using SMARTLIGHT esp module with ESPHome. Everything works fine except lack of accuracy of built in temperature sensor. I am wondering if there is a way to change configutation and make AC use external temperature sensor connected to HA?
If yes, will it impact AC’s algorithmm of work, or just will change the source for displaying temperarture
