Midea branded AC’s with ESPhome (no cloud)
Yes, I understand; what you need is the follow-me option.
Then you can use any temp.sensor from HA as temperature sensor for the AC…
  - platform: homeassistant
    entity_id: sensor.room_sensor   # Sensor from HASS
    internal: true
    filters:
      - throttle: 10s
      - heartbeat: 2min             # Maximum interval between updates.
      - debounce: 1s
    on_value:
      midea_ac.follow_me:
        temperature: !lambda "return x;"
        beeper: false               # Optional. Beep on update.
Hi @dbaq and what’s next? I have the same already on my AC… would the 5 pin out cable need something to drive a wifi stick like slwf-01? Or you got a wf-60A1 from Midea? Does it need a https://www.aliexpress.com/i/1005006460978775.html (Carrier CE-26GY-2.4G 17122000046741) Thanks!!
Thanks, I got it!
What does this plug into with it’s 4/5 pin connector? For the other end, I have the SLWF-01…
Tell me more, do I need to turn on the follow-me function on the remote control to work? Or will it work automatically anyway? And yet, the thermostat still displays the temperature of the sensor that stands on the indoor unit. I’ll probably set everything up with automation anyway, but it’s somehow easier to monitor the thermostat… Well, I want to understand the algorithm for myself (at the moment, the complete system cannot be checked).
Follow Me Functionality in Midea AC Units
1. One-Way Communication:
The remote control communicates one way—from the remote to the indoor unit.
2. Follow Me Behavior:
  • The “Follow Me” feature typically does not have an on/off state on the indoor unit itself.
  • It sends a temperature value to the unit. However, in Fan and Dry modes, the temperature displayed comes from the indoor unit’s sensor since no temperature regulation occurs in these modes.
3. Follow Me Packet:
  • The “Follow Me” packet overrides the indoor temperature sensor with a timeout.
  • When the indoor unit receives the packet, it uses the provided temperature value for a duration specified in the unit’s manual. If no new packet arrives within that period, the unit reverts to using its internal air temperature sensor.
4. Packet Details:
  • The “Follow Me” packet contains:
    • A temperature value.
    • The unit (°C or °F).
  • Timeout: The timeout is determined by the indoor unit, not by the packet data.
  • Practical Use: Fahrenheit is only useful for display purposes, as the indoor unit operates internally in Celsius.
5. Packet Types:
There are three types of “Follow Me” packets:
  1. On Packet: Beeps on reception and uses the provided temperature (with unit).
  2. Update Packet: Does not beep on reception but still uses the provided temperature (with unit).
  3. Off Packet: Beeps on reception and switches back to the indoor unit’s integrated temperature sensor.
If no On or Update packet is received within the timeout period, the indoor unit automatically reverts to using its internal temperature sensor.
6. Midea_AC Protocol Support:
  • Midea_AC can send both On and Update packets. The difference lies in the beep parameter.
7. Temperature Unit Behavior:
  • Indoor units always parse the temperature unit and value from the packet:
    • If the value is in Celsius, it is used directly.
    • If the value is in Fahrenheit, it is converted to Celsius for internal use.
  • The backend logic always operates in Celsius, while Fahrenheit is only for remote and display purposes.
8. Display Variations:
  • Some indoor unit displays will switch the temperature unit based on every “Follow Me” packet received.
  • Others, like my AR12TXHQASINEU-AR3500, remain in Celsius regardless of the packet unit. For my unit, the only way to change the display temperature unit is by sending control packets with temperatures in Fahrenheit.
9. My Contribution to ESPHome:
This variation in behavior is why I implemented this:
GitHub Pull Request #7762
If needed, support for the Follow Me Off packet could be added as a new action.
10. Verifying Follow Me Behavior:
To check if a “Follow Me” packet was received correctly:
  • Monitor the current indoor temperature reported by the unit.
    • In the ESPHome climate component, the current temperature reflects the value used by the internal control logic.
    • This will either be the value of the indoor temperature sensor or the last “Follow Me” packet value (if the timeout hasn’t occurred).
I have the same issue(s) sadly.
I don’t think even the current RE of the protocol is correct … that field certainly isn’t current (at least not always).
Similar for me, all temperatures are wrong. This is how it looks for me:
The “61F” number seems pretty random and not related to the actual temperature from the thermostat. Outside Coil Temp is always zero. Inside Coil Temp makes more sense.
Which heat pump do you have, which controller and how it’s connected (pictures would he pretty helpful).
Hi @dbaq , didn’t figure it out yet. Since you have the same controller as me I’d be super happy if you could take some more pics so I can better understand which system you have and how it’s connected together.
For example, I am particularly interested in where exactly the cable from 485COM connector on your wired controller goes. Or if you have HA/HB connected somewhere. And which airhandler you have.
Thanks!
Hello
I have a media heat pump that does not have a touch panel. I want to turn on the heat pump without using the touch panel with the RS485 to USB converter, is it possible?
I do not know, i use the wifi module; not involved in the serial protocols…
Hey, I am in the same spot as you. As far as I know there are a couple people working on it but nothing concrete.
The touch panel of the heat pump also works using Modbus RTU protocol and sends messages to the heat pump. I want to know what kind of data it sends to the heat pump.
I use Modbus Pol software to send data to the heat pump, I just want to know how to read the master address and the address of the registers.
Hey Everyone, I have a Midea MHC-V12W/D2RN7-ER90 Heat pump which stands from a single outdoor unit and a wired controller. I plan to control the device from HA via ESPHOME. I’m using an ESP32 NodeMCU board and TTL-RS485-SCM module.
As I understand from installation manual, this should be connected to the wired controller’s H1, H2 and E port:
I’m not sure if it’s important, but the wired controller type is KJRH-120L.
The code I have is pretty simple, first I only want to read a register:
substitutions:
  devicename: heatpump
  description: Heatpump Controller
globals:
  - id: unmasked_value_register_0
    type: uint16_t
    restore_value: no
    initial_value: '0'
  - id: unmasked_value_register_5
    type: uint16_t
    restore_value: no
    initial_value: '0'
  - id: unmasked_value_water_temperature_t1s
    type: uint16_t
    restore_value: no
    initial_value: '0'
  - id: unmasked_curve_selection
    type: uint16_t
    restore_value: no
    initial_value: '0'
  - id: unmasked_value_register_210
    type: uint16_t
    restore_value: no
    initial_value: '0'
  - id: unmasked_value_register_211
    type: uint16_t
    restore_value: no
    initial_value: '0'
  - id: unmasked_value_register_270
    type: uint16_t
    restore_value: no
    initial_value: '0'
  - id: unmasked_value_register_272
    type: uint16_t
    restore_value: no
    initial_value: '0'
esphome:
  comment: "${description}"
  friendly_name: "${description}"
  project:
    version: 5.1.0
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
#  level: INFO
#  baud_rate: 0
# Enable Home Assistant API
api:
  encryption:
    key: "cVtA8G27CUyYaZRZZLTKJvgDwC4hRRL3ZN3WyUoyfcI="
web_server:
  port: 80
  version: 3
ota:
  - platform: esphome
    password: "611752b7cb67e55b125b53d6242b7299"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Heatpump Fallback Hotspot"
    password: "I7Uhm1dnQwPx"
captive_portal:
uart:
  tx_pin: GPIO17
  rx_pin: GPIO16
  baud_rate: 9600
  stop_bits: 1
modbus:
  flow_control_pin: GPIO5
modbus_controller:
  - id: "${devicename}"
    ## the Modbus device addr
    address: 0x1
    modbus_id: heatpump_modbus
    setup_priority: -10
    update_interval: 15s
#by registry number, like : _100
  - platform: modbus_controller
    state_class: measurement
    register_type: holding
    address: 0x64 #dec 100
    unit_of_measurement: "Hz"
    value_type: S_WORD
    address: 0x66
    unit_of_measurement: "pwm"
    value_type: S_WORD
But seems ESP is not able to connect to the controller and get no answer.
Modbus device=1 set offline
I checked the HMI address and it’s 1, so the address should be fine. As well as the number of stop bits and baud rate. I measured the voltage level between H2/B- and E and it is +0.2V while H1/A and E is +4.6V
I’m strugling with the troubleshooting for a while now, so any idea on how could I make this work is welcomed
Managed to make it work. Seems the rs485-ttl module got broken somehow. After replacing it my config works fine :slight_smile:
I have the KSACN1001AAA “wired controller” with a 40MBAB ducted air handler and 38MARB heat pump (Carrier branded, but it’s a Midea). Unfortunately, my controller uses HA/HB and I haven’t found a good starting point for tapping those comms. My air handler board, however, had XYE terminals that were unused. I managed to get RS-485 comms established on the X/Y terminals, did some VERY basic documentation of it on github if anyone else is stuck with HA/HB and wants to try something else:
@Bowser789 Hey, thanks for your post. I have been interested in doing this for a while and feel more confident with your instructions. I will give it a try in the next few days!
Wondering if you can share your ESPHome config for the XYE connected ESP8266?
I appreciate all the information that this thread has provided over the year. Fortunely, I did not need to go through the work of putting together my own dongle. Although it would have been good experience with small electronic soldering.
I purchased this dongle for $20.48 shipped.
I had this machine from home depot: Advantage 3rd Gen 24,000 BTU 2 Ton Ductless Mini Split Air Conditioner and Heat Pump with Mini Stat 230V/60Hz
It plugged in and worked immediately. My only issue was that the USB dongle did not fit my non-standard USB A port on the unit. I had an extra USB extension cable. I notched out the male side by just removing the the top open side of the metal. I did need to remove much. It plugged in just fine. Then I used the extra length to wrap it over top of the unit and have the dongle exposed on the outside for better signal (not really needed, I’m sure).
I wonder if you’ve tried passively listening on the XYE terminals (sniffing) when the thermostat is sending data?
I need to pick up one of the 4-wire (485) thermostats when it goes on sale to see if there are any other interesting control/query messages that can be sent, and/or if the XYE and 4-wire (485) port use the same protocol. We’re all working off the same reverse-engineering (Codeberg repo) done using a CCM unit, which is pretty limited. The UART protocol is better documented, because someone dug up protocol info straight from Midea engineers, but I’ve never seen anything documented about the 485/XYE protocol besides what’s in the original XYE repo.
