I have the integration working and I can read all the stats and info from my dishwashing but I am now trying to start it from an automation in NodeRed. I have put the dishwasher into remote mode and it starts from the miele@home app, but I can’t get it to start from home assistant / NodeRed with service call.
Has anybody had ayn success with this or any idea of what I may be doing wrong? I have attached my call service node.
Please try to kick off the action from within the homeassistant developer tools. (services tabs) I recently did fix an issue with the actions so possibly it is already solved.
On another note Miele claims a lot of actions are available. But when you do Get action from their API there are very minimal actions available (for my diswasher only change name and turn off, while the app allows everything). The miele API can be checked here : https://www.miele.com/developer/swagger-ui/swagger.html
It should be able to refresh the token automatically now, I pushed an update some weeks ago If it doesn’t please let me know on github https://github.com/HomeAssistant-Mods/home-assistant-miele if it does still happen the token is probably refreshed after it’s expired. I can than just change the refreshing timing and try to refresh it one day in advance.
The only way I have managed to get my dishwasher to start using processAction: 1 was to manually select the programme and then set it with the timer. Then use processAction:1 say when electricity prices are low.
There must be other commands to set the programme since with the miele app its possible to set the program and select the start time, but try as I might I have not been able to find them.
Anyone else having trouble linking the account? Tried logging on both through HA and https://www.miele.com/developer/swagger-ui/swagger.html with different browsers. No success.
I get this error message: “miele.com
Kontoverknüpfung fehlgeschlagen!
Bitte überprüfen Sie ihre Zugangsdaten.
Nach 5 Sekunden werden Sie automatisch zurück zum Login weitergeleitet.”
Which means account linking failed.
Yep, I have the same faillure.
Last weekend I wanted to reconnect our Miele Account again but got the same message all the time.
Today I recieved a message in the Miele app:
(translated from dutch)
"we will be performing maintenance on the server shortly. As a result, some functions of the app can be used to a limited extent.
From 2/16/2021 7:00 AM until 02/16/2021 10:00 AM"
Maybe it will work again after that?
I will give it a try at the end of the week.
just got it up and running - I really like the ease of it. Is there any view on when we see the sensors being extended? The app does show things like water and power consumption, but I guess the API does not offer them (yet?).
I’m trying to use miele.action, but without success.
For example I tried to call this action
‘entity_id’: ‘miele.washing_machine’,
‘body’: { ‘powerOn’: true }
More people seemed to have this issue. unfortunately it seems to be on Miele’s side. For some users it helped to refresh their clientId and Secret. After that it worked again.
Is there any plan to make this an “official” HA Integration? Would be great for “non-technical” users like me to have a simple solution to use. I have a Miele Washing Machine at home.
Unfortunately this is not on my roadmap. Also this would only make the installation only a small bit easier. You will still need to request a clientID and secret at miele and set-up your configuration. You only wouldn’t need to install HACS.
What part of the process exactly makes it to hard to install for you? Possibly I can make some improvements on that than :-)! Or is it because of HACS?
I started up on the Miele component but it keeps generating this error. Can anybody help?
Error during setup of component miele
File “/usr/src/homeassistant/homeassistant/setup.py”, line 213, in _async_setup_component
result = await task
File “/config/custom_components/miele/init.py”, line 111, in async_setup
callback_url = ‘{}{}’.format(hass.config.api.base_url, AUTH_CALLBACK_PATH)
AttributeError: ‘ApiConfig’ object has no attribute ‘base_url’
