I’ve successfully setup and configure Hassos on a Pi zero w with the sole intention of using MiFlora components to communicate via MQTT to my main HA instance.
According to the MiFlora docs “On Hass.io: Miflora will work out of the box.” but I can’t seem to use either:
sudo hcitool lescan
or
bluetoothctl
To scan for Mac addresses.
I’ve read that there is issues with Bluetooth and Hassos. Have I hit this issue or am I doing something wrong. I know Hassos used bluez as it’s BT, is there another scan function?
I do not know the answer to your question but it seems a bit over complicated to use hassos for this. Just install something like dietpi and this. Works perfectly.
I have setup as you suggested and all working great. Can see the data in MQTT.fx great however I’m having issue however pulling the data into HA with MQTT. Could you share your config for the MQTT template in HA?
