I copied the security keys from HomeSeer.
Did you restart the Z-net or ser2net process after the change you made?
where do you find the security keys in HS? And yest, I restarted the Z-Net after the change.
In the Z-wave ini file. You’ll have to format them correctly for Home Assistant. There are threads on the HomeSeer board about how to do this.
I only see one key in my zwave.ini. I am running HS V3, so maybe that’s different, or can I use the key at the top of the file? Below is my zwave.ini file.
Can you think of anything else I can try, I would really, really like to get this working.
[Z-Wave]
Key=95-55-A3-1B-56-A3-3E-C1-3D-8D-6E-98-AB-7E-79-82
[Net_0184D441]
gZwavePollFailures=2
NoHSZWave=False
AlwaysAllowNonSceneDevices=False
LogZWPollErrors=False
[Settings]
Networks=0184D441
gConfigFilename2=C:\Program Files (x86)\HomeSeer HS3\Data\Z-Wave\Z-Wave2.db
[Net_DCC18F23]
NoHSZWave=False
[Net_FDF9B6A6]
NoHSZWave=False
[Net_E262B963]
NoHSZWave=False
[Net_Friendly]
HomeID_0=E262B963
Name_0=Network E262B963
HomeID_1=0184D441
Name_1=Network 0184D441
[BACKUP_Interfaces]
IFace_0_Name=Z-Net
IFace_0_Unique=4F7A6D0D5EB5
IFace_0_IsMain=True
IFace_0_HomeID=01-84-D4-41
IFace_0_Node=1
IFace_0_Model=1
IFace_0_COMPort=COM4
IFace_0_EthernetIP=192.168.0.79
IFace_0_EthernetPort=2001
IFace_0_Disabled=False
IFace_0_ZNETName=Auto
[Interfaces]
IFace_0_Name=Z-Net
IFace_0_IsMain=True
IFace_0_Node=1
IFace_0_Model=1
