Migration from Fibaro HC2 to HAOS
Hi
As far as I know,
ANY Z-wave controller can exclude ANY Z-Wave device.
It doesn’t matter if the device was initially a member of a different master.
Exclusion should work with every Z-wave master with the correct frequency.
Cheers
I don’t think this is correct, the controller has to send the unique security keys for the particular network.
Otherwise it would be quite simple to destroy my neighbors’ ZWave network.
No, @juergen3 is correct. You can’t destroy your neighbor’s Z-wave network because his device has to participate in the exclusion process (usually by pressing a button) so physical access is required. Also, encryption keys are only used for S0 or S2 included devices. You can include devices unencrypted.
Correct :slight_smile:
