Miio Xiaomi Air Purifier availability blinking
Are you saying setting up a NAT massacred rule stopped your purifier from flapping? Could you expand on what your rule / setting you setup? I’m using Unifi UDM if it helps.
Have fun: Some devices not responding across subnets. · Issue #422 · rytilahti/python-miio · GitHub
Thanks very much for the link. Sorry I was unfamiliar with NAT Mascaraed and I also missed the context of your comment that you were having issues with comms across subnets. My HA instance and air purifier are in the the same subnet so doesn’t look like it will apply to me.
I’ve also found, that there is also an open PR on the Miio repository that might generally help with the issue.
I’m still having this problem.
My HA has an IOT interface that is on the same subnet as the Purifier. Everyone is talking about VLANs, masquerading and NAT, although something else seems to be the issue.
Has anyone managed to solve this? (I’m also running pfsense)
HA version: 2024.2.1. Issue still exists. My purifier is in the same subnet as HA is. Any suggestion how to fix it?
