Milfra Motion Sensor Light Switch (MFA05)
I’ll post my yaml file when I get home from work.
FYI I was never able to OTA the esphome bin file when the switch had tasmota on it. I had to open it up and flash via UART. There are no pin headers, only solder pads. So, some light soldering may (will) be required.
# https://templates.blakadder.com/cloudfree_SWM1.html
# https://templates.blakadder.com/milfra_MFA05.html
# | GPIO   | Component |
# | GPIO0  | button |
# | GPIO5  | motion |
# | GPIO12 | relay |
# | GPIO13 | blue led |
# | GPIO14 | light sensor |
# | GPIO16 | green led |
# GPIO16 boots HIGH which means the green led is ON.
# This is an issue because of the green led takes precendence over the blue led
# To deal with this, GPIO16 must be set LOW after boot which is done using the output component.
# This component defaults to OFF so the user DOES NOT need to use
#    (I) output.turn_off
#     or (II) digitalWrite(16, LOW) after boot
substitutions:
  node_name: cloudfree-motion-light-switch
  friendly_name: CloudFree Motion Light Switch
esphome:
  build_path: ./build/${node_name}
  comment: CloudFree SWM1 Motion Light Switch
  name_add_mac_suffix: true
esp8266:
  board: esp01_1m
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: ${node_name}_AP
    ap_timeout: 3min
api:
  encryption:
    key: !secret esphome_encryption_key
  reboot_timeout: 0s
captive_portal:
improv_serial:
logger:
ota:
button:
  - platform: restart
  - platform: safe_mode
    name: "${friendly_name} Restart (Safe Mode)"
text_sensor:
  - platform: version
    name: "${friendly_name} ESPHome Version"
  - platform: wifi_info
    ip_address:
      name: "${friendly_name} IP Address"
    mac_address:
      name: "${friendly_name} MAC Address"
number:
  - platform: template # time the relay is ON when triggered by motion
    name: ${friendly_name} Motion Delay
    optimistic: true
    restore_value: true
    entity_category: config
    step: 5
    min_value: 15
    max_value: 300
    initial_value: 30
    mode: box
    unit_of_measurement: s
  - platform: template # time the relay is ON when triggered by button
    name: ${friendly_name} Button Delay
    optimistic: true
    restore_value: true
    step: 5
    min_value: 60
    max_value: 600
    initial_value: 180
    mode: box
  - platform: template # cooldown time when physical button is pressed
    name: ${friendly_name} Motion Cooldown
    optimistic: true
    restore_value: true
    step: 5
    min_value: 10
    max_value: 300
    initial_value: 60
    mode: box
output:
  - platform: gpio # green LED
    pin: GPIO16
light:
  - platform: status_led # blue LED
    name: ${friendly_name} Blue LED
    pin:
      number: GPIO13
      inverted: true
    effects:
      - strobe:
          colors:
            - state: true
              duration: 250ms
            - state: false
              duration: 250ms
binary_sensor:
  - platform: gpio # physical button
    pin:
      number: GPIO0
      mode: INPUT_PULLUP
      inverted: True
    on_multi_click:
      - timing: # toggle relay & motion / button timeouts
          - ON for at most 1s
          - OFF for at least 0.2s
        then:
          - switch.toggle: relay
          - if:
                - switch.is_on: motion_enabled
              then:
                - script.execute: cooldown
              else:
                if:
                    not:
                      - script.is_running: cooldown
                  then:
                    - script.execute: button_timeout
          - delay: 100ms
          - wait_until:
                - not:
                - not:
                    script.is_running: button_timeout
          - if:
                - binary_sensor.is_off: motion
              then:
                - switch.turn_off: relay
      - timing: # enable / disable motion
          - ON for 2s to 5s
        then:
          - script.execute: motion_toggle
      - timing: # software restart
          - ON for 6s to 9s
        then:
          - button.press: restart_button
      - timing: # software restart into safe mode
          - ON for at least 10s
        then:
          - button.press: restart_button_safe_mode
  - platform: gpio # motion sensor
    pin:
      number: GPIO5
      inverted: true
    device_class: motion
    filters:
      - delayed_off: 5s
    on_press:
      - script.stop: motion_timeout
      - if:
          then:
            - switch.turn_on: relay
    on_release:
      - script.execute: motion_timeout
  - platform: gpio # light sensor
    pin: GPIO14
    device_class: light
    filters:
      - delayed_on: 5s
      - delayed_off: 5s
    on_press:
      - if:
            - switch.is_on: nightlight_enabled
          then:
            - light.turn_off: blue_status
    on_release:
      - if:
          then:
            - light.turn_on: blue_status
switch:
  - platform: gpio # relay
    pin: GPIO12
  - platform: template # enable / disable motion
    name: ${friendly_name} Motion Enabled
    restore_state: true
    optimistic: true
    device_class: switch
  - platform: template # enable / disable nightlight
    name: ${friendly_name} Nightlight Enabled
    restore_state: true
    optimistic: true
script:
  # not in motion sensor on_release because of an issue with on_press not cancelling the delay
  - id: motion_timeout
    mode: restart
    then:
      # subtract 5 for the delayed_off of the motion sensor
      - delay:  !lambda 'return (id(motion_delay).state - 5) * 1000;'
      - if:
          then:
  - id: motion_toggle
    mode: queued
    then:
      - switch.toggle: motion_enabled
      - if:
            - switch.is_off: relay
          then:
            - light.turn_on:
                effect: Fast Flash
            - delay: 1600ms
  # if mode: restart, this causes motion to not be re-enabled
  - id: cooldown
    then:
      - switch.turn_off: motion_enabled
      - delay: !lambda 'return id(motion_cooldown).state * 1000;'
      - switch.turn_on: motion_enabled
  - id: button_timeout
    mode: restart
    then:
      - delay: !lambda 'return id(button_delay).state * 1000;'
[EDIT: include yaml file]
