Correct, if you use MQTT integration there’s no need for UDP
I don’t have any integrations yet. Although not mqtt ones
Thank you very much for your time!!
I will check tomorrow some settings.
Glad that the upd part isn’t necessary.
@Petrica New update:
I can see in MQTT Explorer that there are messages sent over. But the bulb doesn’t react on them.
So in my opinion is HA good (I have struggled a lot to get mqtt working) But maybe on the espMH site there has to be some issue.
Who can help me with that?
Thanks for the support. It works fine! Now I’am able to see changes
Hello @Bastiaan1977
Also post the MQTT log from HA (basically the HA setting is wrong, since you can control the lights from Milight interface and this should match HA).
Hello @Petrica,
Finally it works! My lights.yaml:
- platform: mqtt
schema: json
state_topic: "milight/state/0x21A/rgb_cct/1"
command_topic: "milight/command/0x21A/rgb_cct/1"
rgb: true
brightness: true
qos: 1
optimistic: false
retain: true
#-- Bulb configuration
color_temp: true
# HA missing scale temp feature. On todo list...
#color_temp_min: 0
#color_temp_max: 100
# Milight hub command is "saturation", so white_value doesn't take effect. On todo list...
#white_value: true
effect: true
#Effect list 0=Full, 1=White, 2=RGB, 3=Full hard, 4=Disco, 5=Red Flash, 6=Green Flash, 7=Blue Flash, 8=White Flash]
effect_list: [0, 1, 2, 3, 4 ,5, 6, 7, 8]
#effect_speed: true # Milight hub support it. HA missing feature.
#-- Milight bulb doesn't support it :(. Need workaround to be done via software on HA or Milight hub
#transition: true
I am so happy that it works, puzzling for days and not solving it … But with your help I got it out. thanks again. on to the next project.
Cheers
Bastiaan
After so many fails I gopt it partially working, but what wonders me is I see the youtube examples and I see with the milight hub that when chris or whoever presses the buttons on the remote, the values change in HA too.
Now is my question how is that done for i get a nice auto MQTT discovery, all manuals faild, but it does not give me the option of remote HA feedback.???
Hi JayJay,
I don’t understand your question.
Hi Bastiaan, I guess topic closed I got it running with the Milight hub on an esp8266.
I went through this process just now and for those that do not necessarily want Mosquitto but just the limitlessled integration, mine work perfectly as follows:
- You have built out the board and have it all working as expected
- I would note I prefer fixed IP addresses so I setup my system with a fixed IP address
- Since I am replacing my MiBoxer hubs with this, I left them in place and used the “Start Stiffing” in the web app and changed some lights to get the Device ID
- WIth that device ID, I went to the web GUI for the board and picked an unused UDP port and used the Device ID as follows:
- Then in my YAML for LimitlessLED lights I have this:
- host: 192.168.2.239
port: 29001
groups:
- number: 4
name: Pergola LEDs New
type: rgbww
Of course the port is the UDP port and the IP is the fixed IP address of the built-out board. IN this case that are RGB+CCT lights which is RGBWW in LimitlessLED.
- Reboot and light.pergola_leds_new appears and can be controlled.
Works perfect for my use case. I am now adding the other 7 groups into this one controller and pulling the MiBoxer Hubs as they are no longer needed once this is finished. Perfectly times because I plan on expanding to another 7 or 8 groups and did not want to but extra hubs just to do it.
Although a comment above says MQTT is far superior, I would like to understand in what way this is the case.
Also, if anyone has a good link to inexpensive case to house the NodeMCU + NRF24L01+ Antenna let me know what you used.
