As long as you understand that the value won’t update live on screen. Only when you refresh the page.
custom button card with that code I’ve posted in previous post is updated live on screen.
Please post in English
Sorry, I had auto translation activated, but porbably already found a solution via KI I would like to share.
I got charge and decharge limits activated at my Zendure setup (20%min , 85%max). Here is my KI solution that need to check tomorrow and might be improved:
sensors:
battery_charge_hours:
value_template: >
{% set ct = states('sensor.remainInputTime') | int %}
{% set current_level = states('sensor.electriclevel') | int %}
{% set charge_limit = 85 %}
{% set remaining_charge = charge_limit - current_level %}
{% set adjusted_ct = (ct * remaining_charge) / (100 - current_level) %}
{% if adjusted_ct == 0 %}
Unavailable
{% elif adjusted_ct > 60 %}
{{ adjusted_ct // 60 }}:{{ '{:0>2d}'.format(adjusted_ct%60) }}
{% else %}
{{ adjusted_ct }} minutes
{% endif %}
charge_finish_time:
value_template: >
{% if is_state('sensor.remainInputTime','unavailable') %}
Unavailable
{% else %}
Done
{% else %}
{{ (as_timestamp(now()) + adjusted_ct * 60) | timestamp_custom("%H:%M") }}
{% endif %}
{% endif %}
battery_remain_hours:
value_template: >
{% set ct = states('sensor.remainOutTime') | int %}
{% set discharge_limit = 20 %}
{% set remaining_discharge = current_level - discharge_limit %}
{% set adjusted_ct = (ct * remaining_discharge) / current_level %}
Unavailable
{% else %}
{% endif %}
decharge_finish_time:
value_template: >
{% if is_state('sensor.remainOutTime','unavailable') %}
Unavailable
{% else %}
Done
{% else %}
{% endif %}
{% endif %}
Hi Guys
Thanks SO much for all the information on this page, without the HA community I would genuinely be lost. I’ve copied what cgtobi has said and it works. AWESOME stuff. However, when I try and display the results in a card, or in fact in Developer Tools . . . I get a lot of other output which makes the card rather messy. Is there anyway to just display the Hours and Minutes without all the extra text.
This is what I get in Dev Tools and is also displayed in my entities card
RESULT
platform: template
sensors:
minutes_to_hours:
value_template: >3:41 hours
