I’m a little curious if “someone” did pick up the work on this component, specially to get the energy metering part in to HA.
I tried to activate this plugin but I can’t get the config correct
This error is shown when I check the config
Error loading /config/configuration.yaml: while scanning for the next token
found character '\t' that cannot start any token
in "/config/configuration.yaml", line 64, column 2
I have used the config below and climate.py from the GitHub repo
# Melcloud
climate:
- platform: melcloud
email: <email>
password: <melcloudpwd>
Can someone please help me?
Hi guys, there is a way to put this custom component (o0Zz version) on custom updater?
After upgrading to version 0.92.0 I get error:
Integration melcloud not found when trying to verify its climate platform.
Is there any solution regarding that?
create a empty file named __init__.py
inside the melcloud folder and delete the folder __pycache__
Yea… I figured out…
Solution was to download latest version from:
https://github.com/CookieMonster87/pymelcloud
And delete all from inside MelCloud folder and to make restart HA. Now it’s working back…
I tried your solution, but no luck for me.
Other suggestions I may try? I’m on Home Assistant 0.92.1
I’m on HA 0.92.1 as well and the custom component from the link above works nicely on my system. So in general it should work.
Hi everybody,
I’m just starting with this nice tool ^^
I just saw that you guys created a plugin based on the same plugin someone did for jeedom (a french tool, not as good as home assistant )
on jeedom my heat pump is working without any issue.
Is the plugin on HA only for air conditionner or does it read all melcloud values ?
I’m asking because I didn’t managed to make it work.
of course I did the stuff written in the last messages, like adding an init file
but still not managed to make it work
any help greatly appreciated
for info in my logs i can see that melcloud did a login as my adress and some data from the heat pump are read, but a few lines after I saw this
2019-05-08 21:53:45 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform melcloud
File “/home/alain/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py”, line 126, in _async_setup
_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File “/usr/lib/python3.5/asyncio/tasks.py”, line 400, in wait_for
return fut.result()
File “/usr/lib/python3.5/asyncio/futures.py”, line 293, in result
raise self._exception
File “/usr/lib/python3.5/concurrent/futures/thread.py”, line 55, in run
File “/home/alain/.homeassistant/custom_components/melcloud/climate.py”, line 575, in setup_platform
devices = mc.getDevicesList()
File “/home/alain/.homeassistant/custom_components/melcloud/climate.py”, line 376, in getDevicesList
devices.append( MelCloudDevice(device[“DeviceID”], device[“BuildingID”], device[“DeviceName”], self._authentication) )
File “/home/alain/.homeassistant/custom_components/melcloud/climate.py”, line 152, in init
self._refresh_device_info()
File “/home/alain/.homeassistant/custom_components/melcloud/climate.py”, line 180, in _refresh_device_info
self._temp_list.append(self._json[“RoomTemperature”])
KeyError: ‘RoomTemperature’
2019-05-08 21:53:45 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=climate, service=set_away_mode>
This component only works with Air Conditioning units. When I add my Ecodan Water/Heat pump to MelCloud, this component stops working. I guess the solution is just a few lines of code to read the extra values from the Melcaloud account (water temp, etc), but that can only be done by someone with coding knowledge.
No, I ended up getting a different brand (Fujitsu), so didn’t have a need for it.
Hi all! Anybody using this component through haaska Alexa integration?
I can actually control my Mitsubishi with Alexa, but she keeps saying that it’s not responding and that is pretty annoying.
In the log I can see:
2019-06-17 22:14:26 INFO (MainThread) [custom_components.melcloud.climate] Device info lease timeout, refreshing...
2019-06-17 22:14:26 DEBUG (MainThread) [homeassistant.components.http.view] Serving /api/alexa/smart_home to 54.154.153.205 (auth: True)
2019-06-17 22:14:26 DEBUG (MainThread) [homeassistant.components.alexa.smart_home] Received Alexa Smart Home request: {'directive': {'header': {'namespace': 'Alexa.PowerController', 'name': 'TurnOn', 'payloadVersion': '3', 'messageId': 'be1b91da-ce95-4faa-ad75-6468295fdd6a', 'correlationToken': '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'}, 'endpoint': {'scope': {'type': 'BearerToken', 'token': 'Atza|IwEBIBBBG7bEyDOv-UI8fR8uqogro_m1XREsiunZSSZtuDUpl6C0bdF4SVYDjsNCEAMSiPdCinof0_zLGUtTa9EUtgg6xndX9YklI2yU2wiu2JXfQ_xp8DMokFNF9g6vvkmL0oFvxPX3YZ5pJvB9hUeeQgKYvTK0jjifnQl1GaY_n02S5mwrOcTdRKccH3K7rOiSvKHASNPbBe_6qoz-s3iu4CVJy0sCwqTdn1xBGChb5okyDQiHeFM6TbqMb_p4PfuiSepWsc0Pac-HahXYLpSASRdE_IxFVBhzyOs8YpTV3BtaaUhyHKZiEVL0RDwdJpq4WQpXPGiJfCRDN2OjzZxTq7TezaLcy6dZmFFK7FPKYRE7LWl04D-rf_AbJjMmh8DeqKqB7lpn8_dGqutndTY6L1GxPlys5yl4PWxcOkOxkrfXfHGDWvB7yE4ce1-yomvJsb5GY8BX2y8yFpze_GxU8F4o_JpqsaEYwDNO0oPSry_-tYKMmPdB8TuVSrY84pHMLpLafIILwcVoZMDoq4smvB1Q'}, 'endpointId': 'climate#melcloud_sala_XXXXXX', 'cookie': {}}, 'payload': {}}}
2019-06-17 22:14:26 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=climate, service=turn_on, service_data=entity_id=climate.melcloud_sala_XXXXXX>
2019-06-17 22:14:26 ERROR (MainThread) [homeassistant.components.alexa.smart_home] climate.melcloud_sala_XXXXXX (<class 'homeassistant.core.State'>) has unsupported operation_mode value 'Off'
2019-06-17 22:14:26 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
resp = await task
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/real_ip.py", line 33, in real_ip_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 67, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 216, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 115, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/alexa/smart_home.py", line 1155, in post
context=ha.Context(user_id=user.id)
File "/usr/src/homeassistant/homeassistant/components/alexa/smart_home.py", line 1370, in async_handle_message
response.merge_context_properties(directive.endpoint)
File "/usr/src/homeassistant/homeassistant/components/alexa/smart_home.py", line 1329, in merge_context_properties
for prop in endpoint.serialize_properties():
File "/usr/src/homeassistant/homeassistant/components/alexa/smart_home.py", line 312, in serialize_properties
for prop in interface.serialize_properties():
File "/usr/src/homeassistant/homeassistant/components/alexa/smart_home.py", line 388, in serialize_properties
prop_value = self.get_property(prop_name)
File "/usr/src/homeassistant/homeassistant/components/alexa/smart_home.py", line 790, in get_property
raise _UnsupportedProperty(name)
homeassistant.components.alexa.smart_home._UnsupportedProperty: thermostatMode
2019-06-17 22:14:28 INFO (SyncWorker_1) [custom_components.melcloud.climate] Device configuration successfully applied
2019-06-17 22:14:28 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=climate.melcloud_sala_XXXXXX, old_state=<state climate.melcloud_sala_XXXXXX=off; current_temperature=25.6, min_temp=7, max_temp=35, temperature=25.0, fan_mode=Speed 1 (Min), fan_list=['Speed Auto', 'Speed 1 (Min)', 'Speed 2', 'Speed 3', 'Speed 4', 'Speed 5 (Max)'], operation_mode=Off, operation_list=['Heat', 'Cool', 'Dry', 'Fan', 'Auto', 'Off'], swing_mode=Top, swing_list=['Auto', 'Top', 'MiddleTop', 'Middle', 'MiddleBottom', 'Bottom', 'Swing'], friendly_name=MELCloud Sala (XXXXXX), supported_features=4801 @ 2019-06-17T22:13:09.543743+02:00>, new_state=<state climate.melcloud_sala_XXXXXX=Cool; current_temperature=25.6, min_temp=7, max_temp=35, temperature=25.0, fan_mode=Speed 1 (Min), fan_list=['Speed Auto', 'Speed 1 (Min)', 'Speed 2', 'Speed 3', 'Speed 4', 'Speed 5 (Max)'], operation_mode=Cool, operation_list=['Heat', 'Cool', 'Dry', 'Fan', 'Auto', 'Off'], swing_mode=Top, swing_list=['Auto', 'Top', 'MiddleTop', 'Middle', 'MiddleBottom', 'Bottom', 'Swing'], friendly_name=MELCloud Sala (XXXXXX), supported_features=4801 @ 2019-06-17T22:14:28.344154+02:00>>
2019-06-17 22:14:28 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.139897433593168] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=climate.melcloud_sala_XXXXXX, old_state=<state climate.melcloud_sala_XXXXXX=off; current_temperature=25.6, min_temp=7, max_temp=35, temperature=25.0, fan_mode=Speed 1 (Min), fan_list=['Speed Auto', 'Speed 1 (Min)', 'Speed 2', 'Speed 3', 'Speed 4', 'Speed 5 (Max)'], operation_mode=Off, operation_list=['Heat', 'Cool', 'Dry', 'Fan', 'Auto', 'Off'], swing_mode=Top, swing_list=['Auto', 'Top', 'MiddleTop', 'Middle', 'MiddleBottom', 'Bottom', 'Swing'], friendly_name=MELCloud Sala (XXXXXX), supported_features=4801 @ 2019-06-17T22:13:09.543743+02:00>, new_state=<state climate.melcloud_sala_XXXXXX=Cool; current_temperature=25.6, min_temp=7, max_temp=35, temperature=25.0, fan_mode=Speed 1 (Min), fan_list=['Speed Auto', 'Speed 1 (Min)', 'Speed 2', 'Speed 3', 'Speed 4', 'Speed 5 (Max)'], operation_mode=Cool, operation_list=['Heat', 'Cool', 'Dry', 'Fan', 'Auto', 'Off'], swing_mode=Top, swing_list=['Auto', 'Top', 'MiddleTop', 'Middle', 'MiddleBottom', 'Bottom', 'Swing'], friendly_name=MELCloud Sala (XXXXXX), supported_features=4801 @ 2019-06-17T22:14:28.344154+02:00>>}
2019-06-17 22:14:33 DEBUG (MainThread) [homeassistant.components.http.view] Serving /api/hassio_ingress/UcSAIGQAjZOn_wKC6olXQaVnMzrglIwDzDpBF_qZpW0/api/file to 192.168.104.32 (auth: False)
Can anyone help me? Or is it a problem of Alexa integration?
Thank You
ok, I’ve found a solution to this issue.
I’ve modified the file climate.py and set:
OPERATION_HEAT_STR = ‘heat’
OPERATION_COOL_STR = ‘cool’
OPERATION_FAN_STR = ‘fan’
OPERATION_AUTO_STR = ‘auto’
OPERATION_OFF_STR = ‘off’
OPERATION_DRY_STR = ‘dry’
The original file has Heat, Cool, Fan, Auto, Off and Dry (first capital letter).
Is it possible to change it on github for future upgrades?
Bye
I never had the “operation_mode” working.
I have an automation like this:
- alias: 'AIRCO KAMER Nacht modus zomer ON'
initial_state: true
hide_entity: True
- platform: state
entity_id: input_boolean.airco_kamer_nachtmodus
to: 'on'
- service: climate.turn_on
entity_id: climate.melcloud_zolder_117363
- service: climate.set_temperature
data_template:
temperature: 23
operation_mode: Cool
- service: climate.set_fan_mode
fan_mode: Speed 1 (Min)
Everything works only the airco always uses the last used operation_mode. So when I put the airco in “heat” mode and then run this automation the airco starts again in heat mode . Temperature & fan_mode are set correctly to 23° & Speed 1.
Does anyone got this to work?
Thanks,
Erik
Isn’t climate working on way that remember last run option ?
If I am correct then if you run as Cool and shutdown climate as Cool mode, then next time it will be started as Cool.
But if you run climate with remote control, then it will use last remote control settings…
I got it working in the mean while.
THX
E.
Sorry, I can’t do any coding or I don’t know what to do with those ready github python files. Could someone be so kind and like tell me how to get started and what to do. The purpose is that i would get Voice Control (through Google Home) to MelCloud Mitsubishi’s AC’s.
This custom component will stop working on 0.96 releasing this week.
Multiple breaking changes to climate. I have created a issue. But not sure if it will be updated before hass 0.96 is released.
