device_id: 273318dbedeb3e47b6fd7f3ac458b4eb
domain: mobile_app
type: notify
message: "SEWER PUMP ALARM "
ttl: 0
Priority: high
car_ui: true
channel: ha_notifications
importance: high
Notification on motion detection in garage
actualy disregard my last message.
should be
priority: high
case sensitive
Edit: both pasted examples show the incorrect casing
I have it both ways doesnt matter tried that too. This is one i didnt chnage back
thats not what I meant, whats your phone? samsung? Xiaomi? Pixel?
Will switch bith back and see but ive tried denovo notifications copied directly from link and changing my entity, doesnt work
it indeed matters what casing you put in regardless of functionality, YAML is a case sensitive language.
not consistent becaue car ui can be lowercase and it works
they sll need to be lowercase, look at the provided examples in the official docs
https://companion.home-assistant.io/docs/notifications/notifications-basic
I will change it back and see. As I said I copied the example from the link you sent changed my entity and had the same response so it doesnāt appear to make a difference but I will redo those notifications and see what happens.
In those I know there wasnāt a typo because it was a direct copy and paste and the only thing I changed was my entity but weirder things have happened Iām willing to give it a shot. I appreciate your help
Still happening.
alias: Garage motion group test
description: ""
- platform: state
entity_id:
- binary_sensor.garage_motion_sensors
to: "on"
condition: []
- service: notify.mobile_app_shawn_cell
message: Garage Motion
importance: high
ttl: 0
priority: high
car_ui: true
vibrationPattern: 100, 1000, 100, 1000, 100
mode: single
what phone is this happening on?
I have noticed this since late last year too. Iām on a pixel 7 pro
here is an example of a notification i have had setup for years, used to be near instant and now is slow sometimes 30sec to a minute.
one thing i did notice last week was my ring camera notification is still instant, and if i get a ring notification i get the HA camera notification at the same time. if i trigger a camera thats not near the ring camera and the phone is idle it will take a long time.
service: notify.mobile_app_chris_p7p
message: >-
{{trigger.to_state.name[:-7]}} Camera triggered by a {{ states('sensor.'
~trigger.to_state.name[:-7]~'detections')}} at {{ as_timestamp(now()) |
timestamp_custom('%H:%M') }}
title: Motion Alarm
color: red
notification_icon: mdi:motion-sensor
channel: MotionDetect
ttl: 0
importance: high
priority: high
vibrationPattern: "100, 1000, 100, 1000, 100, 250, 1000, 250 "
clickAction: /lovelace/motion-sensors
actions:
- action: alarm
title: Alarm!
- action: URI
title: Snooze all cameras
uri: entityId:input_number.motion_global_snooze_time
- action: URI
title: Snooze this camera
uri: >-
{{ 'entityId:input_number.' ~trigger.to_state.object_id~'_snooze_time'
image: /api/camera_proxy/camera.{{trigger.to_state.object_id}}_snap
does the app have background access?
i donāt have my phone with me right now to check, iām pretty sure it does.
i have noticed every time i open the app it takes ages to connect. and the quick tiles take a bit to refresh, and they donāt all refresh at the same time.
in the docs it mentions this: For Android, notifications will appear immediately in most cases. However, in some cases (such as phone being stationary or when screen has been turned off for prolonged period of time), default notifications will not ring the phone until screen is turned on.
which is exactly whatās happening even with priority: high
and ttl: 0
so these have nothing to do with the device receiving a notification, if you look at the apps notification history you will see a date printed with each message. That is the actual timestamp the app received the notification from firebase.
According to the firebase docs this is what is needed in order to show a notification immediately. For me on my Pixel 8 Pro with background access granted to the app my notifications always show up timely when using these parameters.
I know some manufacturers like Samsung like to add additional battery saving methods that needs to be disabled. Thigns like data saver, power saving etcā¦
Iām on a Samsung Galaxy s23 Ultra. Itās better in the last few days but still not 100%.
I noticed thereās a blueprint available to create a actionable notification and it comes directly from home assistant as the author of The blueprint. I played with it so Iām thinking maybe some of the subtleties of the yaml code and those issues might be removed if I were just running the blueprint.
But I donāt see any way to add the necessary Android specific priority measures to the blueprint. Is there an easy way to do this? Iām fine running a blueprint and creating a script itās a lot less labor intensive but it doesnāt help me if it spits out a generic notification thatās going to be riddled with the same problems.
It might be nice to have a checkbox to allow you to add the priority the channels and the other specs if needed.
At this moment April 25 2024 it is more worse sometimes it takes 12 minutes to deliver
What type of phone? Does it make any difference if the phone is unlocked and screen active? If android do you have ttl: 0
and priority: high
in data for android or interruption-level: time_sensitive/critical
in ios?
are you not following the critical format? they show up immediately everytime when you do.
https://companion.home-assistant.io/docs/notifications/critical-notifications#android
