📱 Mobile First Dashboard - A minimalist and user-friendly UI for your dashboard
I have, in my case, simply used the default person entity instead of a custom person sensor. I did not see any added value in the use of a custom person sensor. So it now simply uses the image of the peron entities:
homeassistant/lovelace.yaml at main · CM000n/homeassistant (github.com)
4556453645t
I did that and nothing
I have a card with name and state battery and geolocation but not in your style
I will give that a try, thanks.
I am also finding when navigating to the dashboard, it automatically takes it to a sub-view instead of the main view and you cannot navigate back to it. Dunno what I did there haha.
Did you changed the navigation path of the default_view? Than you have to change the navigation paths for the exit “x” buttons on the sub views also accordingly.
Yep I did and updated all paths, however it just takes me to /lovelace instead of /lovelace/home (which is what I set the home page URL to)
you must be use this: /lovelace/1 or the number that you want to go.
My only other issue is the media player, most of the time the buttons do not appear…
do you mind sharing your script.yaml as well?
How can we change the color of the icons in the persons card??? Icons are blue and don’t see them good because of blue background. Want the icons in white
Can you build any of this using the Lovelace UI or did you do it all via yaml?
You can start off doing it that way, but all the CSS mods you will have to do via YAML
I did it exclusively in the UI, but mainly in YAML mode.
Nice. I’ll have to play around with it.
this looks great! going to give it a try - with your design background, have you thought about multi-room audio? Not figured out a good way to use Sonos across the various devices yet
Same problem:
Bonjour Cloos,
Est ce que tu pourrait adapter la carte météo et atomic calendar et mettre que le calendrier à la place dans cette petite carte?
J’ai essayer mais ca ne va pas chez moi
Merci d avance
Please rewrite your post. This is an english speaking forum :wink:
Simon,
i saw that the person that made the dashboard speaks French and i could better ask my question in French :wink:
Yes I understand that. But this does not correspond to the convention here and thereby you exclude all others from the discussion who do not know French. We do not want Babylonian conditions here :wink:
Hey guys, sorry for bothering you but I have kind of a problem with readapting this for myself. First of all the YAML kinda scares me so I am currently just cherry picking stuff from here but even with almost everything coppied I am running into issues regarding sizes and overlaying/colors.
  1. Temperature graph doesnt want to go under the main time/temp row - I believe I coppied all the styling stuff also with the theme just in case there was an update but still dunno where to look, any hints on that would be appreciated
  2. Cant find the place where the height of the tyles is specified, when I run it on pohe it is kidna OK until I swiitch into Landscape, PC is even worse as you can see.
  3. Background of tiles - instead of boing separate between the two tiles it is one big background between the two not respecting the tile borders.
    Thanks in advance for any tips
  - theme: noctis
    title: NewMain
    path: newmainewmain
    type: sidebar
    badges: []
    cards:
      - type: custom:mini-graph-card
        entities:
          - entity: sensor.avg_temp
            color: var(--accent-color)
        hours_to_show: 24
        hour24: true
        animate: true
        update_interval: 30
        aggregate_func: avg
        line_width: 1
        bar_spacing: 10
        height: 70
        group: true
        show:
          labels: false
          fill: false
          state: false
          icon: false
        style: |
          ha-card {
            box-shadow: none;
            background: none;
            border-radius: 0;
            margin-bottom: -90px;
            opacity: 0.3;
            margin-left: -0.6em;
            margin-right: -0.6em;
      - type: custom:paper-buttons-row
        styles:
          justify-content: space-between
          background: none
          margin: 34px 20px 8px
        buttons:
          - name: '{{ now().strftime(''%H'') }}:{{ now().strftime(''%M'')}}'
            styles:
              name:
                font-weight: 300
                font-size: 40px
                letter-spacing: '-1px'
                margin-left: 2px
                position: relative
                left: '-10px'
              button:
                pointer-events: none
          - layout: name_state
            name: '{{ states(''sensor.nameday_cz'') }}'
            state: '{{ now().strftime(''%A'') }}'
            styles:
              button:
                width: 200px
                height: 32px
                position: relative
              name:
                position: absolute
                left: '-10px'
                top: 0
                font-weight: 400
                white-space: nowrap
              state:
                position: absolute
                left: '-10px'
                bottom: 0
                font-weight: 600
                white-space: nowrap
          - name: '{{ state_attr(''weather.openweathermap'',''temperature'') }}°C'
            icon: mdi:thermometer
            layout: icon|name
            styles:
              name:
                font-size: 18px
                margin-left: '-2px'
              button:
          - name: '{{ states(''sensor.avg_temp'') }}°C'
            icon: mdi:home-thermometer
            layout: icon|name
            styles:
              name:
                font-size: 18px
                margin-left: 2px
              button:
                margin-right: '-6px'
        style: |
          ha-card {
            background: none !important;
            margin: 15px 20px;
            border-radius: 26px;
          ha-card:before {
            content: '';
            display: block;
            background: var( --ha-card-background, var(--card-background-color, white) );
            position: absolute;
            right: 0;
            width: 76%;
            height: 54px;
      - type: custom:vertical-stack-in-card
        cards:
          - type: horizontal-stack
            cards:
              - type: grid
                square: true
                columns: 2
                cards:
                    cards:
                      - type: custom:weather-card
                        entity: weather.openweathermap
                        icons: /local/icons/weather_icons/animated/
                        number_of_forecasts: '3'
                        current: false
                        details: false
                        style: |
                          ha-card {
                            #margin: 12% 0 2% !important;
                            background: rgba(0,0,0,0);
                            box-shadow: none;
                            padding: 0 !important;
                            font-size: 12px;
                          div.precipitation {
                            display: none;
                          div.precipitation_probability {
                            display: none;
                          i.icon {
                            transform: scale(0.17);
                            transform-origin: 0 19.5%;
                            margin-left: -1.4em !important;
                            position: absolute;
                            top: -18px;
                            #right: 0;
                            padding: 0;
                            #background-size: 75% !important;
                            height: 240% !important;
                            width: 240% !important;
                          .dayname:after {
                            content:'';
                            height: 3.4em;
                            width: 3.5em;
                            display: block;
                            margin-top: -20px;
                          .dayname {
                            margin-top: -6px
                          div.day {
                            border-right: 0.06em solid rgb(26,137,245,0.3);
                          div.lowTemp {
                            margin-top: -10px;
                        forecast: true
                        hourly_forecast: true
                    style: |
                      ha-card {
                        box-shadow: none;
                        height: 100% !important;
                        padding: 12% 7%;
                    cards:
                      - type: custom:atomic-calendar-revive
                        entities:
                          - entity: calendar.ceske_statni_svatky
                            color: white
                            max_results: 12
                            icon: mdi:calendar
                          - entity: calendar.okylisterhome_gmail_com
                            color: white
                            icon: mdi:calendar
                        firstDayOfWeek: 1
                        refreshInterval: 60
                        style: |
                          ha-card {
                            box-shadow: none;
                            font-size: 12px;
                          ha-card > div > table > tbody > tr.daywrap {
                            border-top: none;
                          ha-card > div > table > tbody {
                            padding: 0px !important;
                          ha-card > div > table {
                            margin-top: -10px !important;
                            animation: scroll 15s ease infinite;
                          ha-card > div > table > tbody > tr > td {
                            padding-bottom: 20px !important;
                            padding-top: 2px !important;
                          ha-card > div {
                            padding-top: 0.3em !important;
                            margin: 0 !important;
                          div.event-main {
                            width: 100% !important;
                            #white-space: nowrap !important;
                            #overflow: visible !important;
                            text-overflow: ellipsis !important;
                            height: 3em !important;
                            font-size: 13px;
                            line-height: 18px;
                          div.relativeTime {
                            display: none;
                          @keyframes scroll {
                            0% { opacity: 0; transform: translateY(0); }
                            3% { opacity: 1; transform: translateY(0); }
                            20% { opacity: 1; transform: translateY(0); }
                            23% { opacity: 0; transform: translateY(0); }
                            26% { transform: translateY(calc(-25%)); opacity: 0;}
                            29% { transform: translateY(calc(-25%)); opacity: 1;}
                            46% { transform: translateY(calc(-25%)); opacity: 1;}
                            49% { transform: translateY(calc(-25%)); opacity: 0;}
                            52% { transform: translateY(calc(-50%)); opacity: 0;}
                            55% { transform: translateY(calc(-50%)); opacity: 1;}
                            72% { transform: translateY(calc(-50%)); opacity: 1;}
                            75% { transform: translateY(calc(-50%)); opacity: 0;}
                            78% { transform: translateY(calc(-75%)); opacity: 0;}
                            81% { transform: translateY(calc(-75%)); opacity: 1;}
                            97% { transform: translateY(calc(-75%)); opacity: 1;}
                            100% { transform: translateY(calc(-75%)); opacity: 0;}
                        showDate: false
                        hideDuplicates: false
                        hideFinishedEvents: true
                        showCurrentEventLine: false
                        showProgressBar: false
                        showMonth: true
                        showWeekDay: false
                        showDescription: false
                        disableEventLink: true
                        showFullDayProgress: false
                        showEventIcon: false
                        showHiddenText: false
                        showCalendarName: false
                        showWeekNumber: false
                        calShowDescription: false
                        showLastCalendarWeek: false
                        dimFinishedEvents: true
                        disableCalLink: true
                        disableCalLocationLink: true
                        disableCalEventLink: truemaxEventCount
                        noEventsForNextDaysText: Neni nic naplanovano
                        showLoader: false
                        maxEventCount: 4
                        cardHeight: 210px
                        maxDaysToShow: 90
                    style: |
                      ha-card {
        style: |
          ha-card {
            margin: 14px 20px !important;
            background: none;
          .type-custom-vertical-stack-in-card {
        cards:
            cards:
              - type: grid
                square: true
                columns: 2
                cards:
                  - type: entities
                    show_header_toggle: false
                    style: |
                        padding: 0px;
                      h1.card-header {
                        padding: 10px;
                        margin-top: -4px
                      #states {
                        padding: 10px;
                      ha-card {
                        {% if is_state('sensor.roborock_s5e_a930_status','Uklízí') %}
                        background: radial-gradient(at bottom, rgba(255,255,255, 0.26) 0%, rgba(43,55,78,0) 70%);
                        background-size: 140% 70%;
                        background-repeat: no-repeat;
                        background-position: 50% 100%;
                        background-color: #3e4c69;
                        transition: background 1.5s, background-position 2s, background-color 1.5s;
                        transition-delay: 0.6s;
                        {% else %}
                        transition: background 1.5s;
                        transition-delay: 0.2s;
                        background-color: var( --ha-card-background, var(--card-background-color, white) );
                        background-position: 50% 360%;
                        {% endif %}
                    entities:
                      - entity: vacuum.roborock_s5e_a930_robot_cleaner
                        state_color: false
                        icon: mdi:robot-mower-outline
                          {{ states("sensor.roborock_s5e_a930_battery_level")
                        style: |
                          hui-generic-entity-row {
                            margin-bottom: 14px;
                            margin-top: -2px;
                            padding-right: 0.6em;
                          hui-generic-entity-row > div {
                            width: max-content !important;
                      - type: section
                        label: Robot
                        style: |
                          div.divider {
                            display: none;
                          div.label {
                            margin-top: -12px;
                            margin-bottom: 10px;
                            font-size: 17px;
                            font-weight: 600
                        type: custom:multiple-entity-row
                        icon: mdi:battery
                        attribute: battery_level
                        unit: '%'
                        style:
                          hui-generic-entity-row$: |
                            div {
                              display: none !important;
                              position: absolute !important;
                              top: -14px !important;
                              margin-left: -7px !important;
                              transform: scale(0.9, 0.9);
                    footer:
                      styles:
                        justify-content: space-between;
                        padding: 8px;
                        width: auto;
                        margin-top: '-6px;'
                        margin-bottom: 0px;
                        filter: drop-shadow(0px 2px 2px rgba(0,0,0,0.5));
                      buttons:
                        - name: false
                          icon: mdi:play
                          tap_action:
                            action: call-service
                            service: vacuum.start
                              entity_id: vacuum.herbicat
                        - name: false
                          icon: mdi:pause
                          tap_action:
                            service: vacuum.pause
                        - name: false
                          icon: mdi:home-map-marker
                          tap_action:
                            service: vacuum.vacuum.return_to_base
        style: |
          ha-card {
            background: none;
            box-shadow: none;
          #states > :last-child {
            z-index: 10;
        cards:
          - type: custom:slider-button-card
            entity: light.bulb_lamp_m
            slider:
              direction: left-right
              background: gradient
              use_state_color: true
              use_percentage_bg_opacity: true
              show_track: false
              toggle_on_click: false
              force_square: false
            show_name: true
            show_state: false
            compact: true
            icon:
              show: true
              use_state_color: false
              tap_action:
                action: more-info
              icon: mdi:home-lightbulb
            action_button:
              show: false
            style: |
              :host {
                font-weight: 600;
              div.icon {
                margin: 4px;
                font-size: 10px;
            styles:
              position: absolute;
              top: 0;
              right: 0;
            buttons:
              - icon: mdi:plus
                tap_action:
                  action: navigate
                  navigation_path: livingroom
                styles:
                  icon:
                    '--mdc-icon-size': 34px
                    margin: 1px
        style: |
          ha-card {
            background: none;
        cards:
            entity: light.bulb_bed_d
            slider:
              show_track: false
              force_square: false
            show_name: true
            show_state: false
            compact: true
            icon:
              show: true
              tap_action:
                action: more-info
              icon: mdi:sofa
            action_button:
              mode: toggle
              icon: mdi:power
              show: false
              show_spinner: true
              tap_action:
                action: toggle
            style: |
              :host {
                font-weight: 600;
              div.icon {
                margin: 4px;
                font-size: 10px;
            styles:
              position: absolute;
              top: 0;
              right: 0;
            buttons:
              - icon: mdi:plus
                tap_action:
                  action: navigate
                  navigation_path: bedroom
                styles:
                  icon:
                    margin: 1px
        style: |
          ha-card {
            background: none;
            box-shadow: none;
          ha-card:before {
            content: '';
            display: block;
            width: 100%;
            height: 100%;
            position: absolute;
            top: 0;
            left: 0;
            outline-right: 10px solid blue !important;
            box-shadow: inset -1px 0px 0px 0px var(--ha-card-background) !important;
            z-index: 1;
            pointer-events: none;
      - type: custom:mushroom-vacuum-card
        commands:
          - on_off
          - start_pause
          - stop
          - locate
          - clean_spot
          - return_home
        icon_animation: true
        fill_container: false
        layout: horizontal
        hold_action:
          action: more-info
