Modbus Climate: multiple target temp register
You could map a different HVAC Home Assistant value to your Eco or confort. Probably it is not the best thing to view, but it should work.
In example:
  # ACS Example Climate
- name: "ACS Example"
  unique_id: "fc_acs_example"
  device_address: 100
  scan_interval: 32
  input_type: depending on your system
  address: your address for current temp
  precision: 1
  scale: 0.01
  hvac_mode_register:
    address: your reg for hvac
    write_registers: depending on your system
    values:
      state_off: depending on your system
      state_heat: depending on your system
      state_auto: depending on your system -> this could be your eco
      state_heatcool: depending on your system -> this could your  confort
  hvac_onoff_register: reg, depending on your system
  max_temp: 35
  min_temp: 15
  temp_step: 1
  target_temp_register: [REG_AUTO, REG_COOL, REG_DRY, REG_FAN, REG_HEAT, REG_HEAT_COOL, REG_OFF]
  target_temp_write_registers: depending on your system
  fan_mode_register:
    address: reg, depending on your system
    values:
      state_fan_off: depending on your system
      state_fan_low: depending on your system
      state_fan_medium: depending on your system
      state_fan_high: depending on your system
