MODBUS data from SMA Inverter
Thanks All. I tried all the various variations but still have no success. Although I do have a different error message now. Considering the errors and the tips @techs gave then I’m getting the feeling the problem is in properly connecting to modbus in the first place rather than reading the registers. Does this error mean anything to anyone?
Error while setting up platform modbus
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 126, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT)
  File "/usr/local/lib/python3.7/asyncio/tasks.py", line 416, in wait_for
    return fut.result()
  File "/usr/src/homeassistant/homeassistant/components/modbus/sensor.py", line 92, in setup_platform
    hub = hass.data[MODBUS_DOMAIN][hub_name]
KeyError: 'default'
I think I have the solution. I just tried this out with my Sunny Tripower STB 6000TL-20
With slave ID 3 I get the right results with one addition to the sensor definition: register_type: input
Without it I get no data.
here my two snippets:
modbus:
  type: tcp
  host: 192.168.178.101
  port: 502
sensors:
  - platform: modbus
    scan_interval: 30
    registers:
      - name: Gesamtertrag
        hub: sma
        unit_of_measurement: kWh
        slave: 3
        register: 30531
        count: 2
have u done any changes exept enable modbus udp and tcp at the inverter via sunny explorer ?
I try to connect to my stp 10000tl-20 with no luck so far .The Ip Adresses are choosen automaticaly so i try to get to the modbus via my sunny homemanager 2.0.
Hi morpheus,
To enable this I only activated modbus tcp on the inverter. You must use the IP address from the inverter however.
I also have a home manager 2.0 setup. and I was not able to get any modbus communication with home Manager via tcp going so far. But I realized that the HomeManager 2.0 sends udp multicast messages every second with data from the built in energy meter.
So my approach is twofold.
  • I use a Node Red Flow to intercept the udp muticast messages from Home Manager 2.0 to get Energy in and out (current values and meters). see here: SMA Energy Meter in Home Assistant
  • I use the HA modbus integration to read the inverter.
So to get this to work you need to use the IP address from your inverter in the host section.
@chris_ka thankyou. I just tried slave 3 and it finally started returning some sort of data. Although the data ins’t totally meaningful. I’m getting -1 as the result. For some other registers I’m getting some sort of number other than -1 but none are correct. Is it the “count” or something else I should be looking at?
OK let’s do this step by step.
Prerequisites:
  1. Get the IP address of the inverter in your local Network. At daytime when the Inverter is sending data you can check your router to find the ip address. (note it down)
  2. Start Sunny Explorer and connect to your Inverter. Go to Settings and open External Communication: You should find something similar to this
  3. Note down the UnitID and TCP-Server port. Ensure that TCP-Server is active. If not change it!
  4. Now get this document: http://files.sma.de/dl/2585/WEBBOX-MODBUS-TB-en-19.pdf
    and have a look on page 28 Section 5.4.1 common Addresses of all SMA Devices. here you find the values for all relevant registers (ADR), the count (CNT) and their description.
  5. configure modbus integration in Home Manager configuration
modbus:
  type: tcp
  host: 192.168.178.101    # use the ip address for your inverter as mentioned in the text
  port: 502                # use the port you saw in sunny explorer
  1. configure modbus sensors in HA
sensors:
  - platform: modbus
    scan_interval: 30
    registers:
        hub: sma
        unit_of_measurement: kWh   # see register description in section 5.4.1 of the document
        slave: 3                   # use the UnitID you found in Sunny Explorer
        register: 30531            # use a register from section 5.4.1 of the document
        register_type: input       # all registers starting with 3 need to have the type input
        count: 2                   # use the correct count for the register see section 5.4.1 of the document
  1. Have fun
Ah turns out getting the slave number, register and count right as per the SMA specs right can lead to point 7.
All seems to be working well except for a couple of registers such as model ID. Maybe my model is actually -1. in any case, it’ unimportant as the other values are working as expected.
Just noting that I fount there are 2 different sets of Sunny Island (SI) register specifications. The Excel one that is found on the SMA website seems to be only partially correct which this one http://files.sma.de/dl/2585/WEBBOX-MODBUS-TB-en-19.pdf has registers that mostly work.
I use the following. This gets data out of the SMA Tripower 8.0. Not all registers seem to have the right variables I think. And if the power generated by the solar panels is to low or none, the most of the registers will go to the maximum value in the variable or so. Few still make sense like SMA total.
Does anyone else has the same experience?
configuration.yaml:
modbus:
  type: tcp
  host: 192.168.15.35
  port: 502
sensor.yaml
  - platform: modbus
    scan_interval: 10
    registers:
    - name: SMA Power L1
      slave: 3
      register: 30777
      count: 2
      data_type: uint
      scale: 0.001
      precision: 2
    - name: SMA Power L2
      slave: 3
      register: 30779
      count: 2
      data_type: uint
      scale: 0.001
      precision: 2
    - name: SMA Power L3
      slave: 3
      register: 30781
      count: 2
      data_type: uint
      scale: 0.001
      precision: 2
    - name: SMA Stroom L1
      unit_of_measurement: A
      slave: 3
      register: 30977
      count: 2
      data_type: uint
      scale: 0.001
      precision: 2
    - name: SMA Stroom L2
      slave: 3
      register: 30979
      count: 2
      data_type: uint
      scale: 0.001
      precision: 2
    - name: SMA Stroom L3
      slave: 3
      register: 30981
      count: 2
      data_type: uint
      scale: 0.001
      precision: 2
    - name: SMA Spanning L1
      unit_of_measurement: V
      slave: 3
      register: 30783
      count: 2
      data_type: uint
      scale: 0.01
      precision: 1
    - name: SMA Spanning L2
      slave: 3
      register: 30785
      count: 2
      data_type: uint
      scale: 0.01
      precision: 1
    - name: SMA Spanning L3
      slave: 3
      register: 30787
      count: 2
      data_type: uint
      scale: 0.01
      precision: 1
    - name: SMA Netfrequentie
      unit_of_measurement: Hz
      slave: 3
      register: 30803
      count: 2
      data_type: uint
      scale: 0.01
      precision: 2
    - name: SMA power
      slave: 3
      register: 30775
      count: 2
      data_type: int
      scale: 0.001
      precision: 2
    - name: SMA Total
      slave: 3
      register: 30529
      count: 2
      data_type: uint
      scale: 0.001
      precision: 2
    - name: SMA Today
      slave: 3
      register: 30535
      count: 2
      data_type: uint
      scale: 0.001
      precision: 2
    - name: SMA device type 9347 = 8.0
      slave: 3
      register: 30053
      count: 2
      data_type: int
    - name: SMA grid relay 51=Closed 311= Open
      slave: 3
      register: 30217
      count: 2
      data_type: int
And would colde like the code in the bottom of this message be a good catch to go to ‘0’ in stead of high values?
  - platform: SMA
    sensors:
      sma_power_power:
        value_template: “{% if states(‘sensor.sma_power_l1’)|float < 0 %}0{% else %}{{ states(‘sensor.sma_power_l1’) | float / 100 | round(2)}}{% endif %}”
        friendly_name: ‘Power’
        unit_of_measurement: ‘W’
        icon_template: mdi:flash-circle
Hi MBolt,
I solved this by using an additional template sensor using the modbus sensor as input like this:
      power_sma_filtered:
        friendly_name: "Erzeugung aktuell"
        unit_of_measurement: W
        value_template: >-
          {% if (states('sensor.power_sma')|int >= 10000 or states('sensor.power_smal')|int < 0) %}
            0
            {{(states('sensor.power_sma')|int)}}
I use this in config
# SMA over modbus
modbus:
  type: tcp
  host: 192.168.178.171
  port: 502
and this in sensors
- platform: modbus
  scan_interval: 30
  registers:
      hub: sma
and get this error in my log
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 179, in _async_setup_platform
    await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
  File "/usr/local/lib/python3.7/asyncio/tasks.py", line 442, in wait_for
    return fut.result()
  File "/usr/src/homeassistant/homeassistant/components/modbus/sensor.py", line 129, in setup_platform
KeyError: 'sma'
I can login to the webinterface just fine. I came here bc the standard SMA integration was not working, but am having issues with this as well. Anyone care to shed some light on this?
I think it’s because you are missing the sma name for the modbus tcp, port and ip settings.
Add “name: sma” or it might also work if you remove “hub: sma” from the registers.
You have:
# SMA over modbus
modbus:
  type: tcp
  port: 502
Should be (if you use “hub: sma”)
# SMA over modbus
modbus:
  type: tcp
  port: 502
I will try this too :slight_smile:
Modbus seems broken in 0.108 before in worked perfectly.
There were fixes in 0.108.2
Fix modbus default delay (@janiversen - #33877) (modbus docs)
The new default delay is 0.
delay
(integer)(Optional)
Time to sleep in seconds after connecting and before sending messages. Some modbus-tcp servers need a short delay typically 1-2 seconds in order to prepare the communication. If a server accepts connecting, but there is no response to the requests send, this parameter might help.
Default value:
0
My modbus integration looked like this
modbus:
  type: tcp
  port: 502
Unfortunately after adding the delay parameter with 1 or 2 doesn’t help. I get the following errors:
Logger: pymodbus.factory
Source: __main__.py:342
First occurred: 11:26:58 (6 occurrences)
Last logged: 11:29:32
Unable to decode response Modbus Error: Unknown response 59
Unable to decode response Modbus Error: Unknown response 90
Unable to decode response Modbus Error: Unknown response 125
index out of range
Logger: homeassistant.core
Source: /usr/src/homeassistant/homeassistant/core.py:144
Error doing job: Fatal error: protocol.data_received() call failed.
  File "/usr/local/lib/python3.7/asyncio/selector_events.py", line 826, in _read_ready__data_received
    self._protocol.data_received(data)
  File "/usr/local/lib/python3.7/site-packages/pymodbus/client/asynchronous/asyncio/__init__.py", line 192, in data_received
    self._dataReceived(data)
  File "/usr/local/lib/python3.7/site-packages/pymodbus/client/asynchronous/asyncio/__init__.py", line 139, in _dataReceived
    self.framer.processIncomingPacket(data, self._handleResponse, unit=unit)
  File "/usr/local/lib/python3.7/site-packages/pymodbus/framer/socket_framer.py", line 165, in processIncomingPacket
    self._process(callback, error=True)
  File "/usr/local/lib/python3.7/site-packages/pymodbus/framer/socket_framer.py", line 175, in _process
    raise ModbusIOException("Unable to decode request")
pymodbus.exceptions.ModbusIOException: Modbus Error: [Input/Output] Unable to decode request
I have the same issue with 0.108.1-3.
Reverted to 0.107.7 and it works fine again.
Yes modbus is definitely broken in 0.108 1-3
I stay on 0.108.3 but I switched to NodeRed and MQTT to retrieve my modbus data.
everything works now again.
I wrote a tutorial how to do this:
I thought it was me!, nothing would make my SunGrow inverter connect reliably.
I gave up on the Modbus intergration and went node-red also
Hi Darren, welcome to the club!
I see that you use the Modbus reader with input definition via a function block. Do you mind sharing the content of the block. I would like to add this approach to my tutorial with reference to your post
regards Chris
According to the source code of the modbus flex-getter, @drmcinnes is just reading an address range. You can also take a look at the Modbus-Flex-Suite examples via Import -> Examples -> node-red-contrib-modbus.
Sorry I haven’t been checking my mail, I’ll post it later tonight.
