Dont give up on modbus using node red, i saves you for looong yaml files if you are integrating the same features from the unit i’m integrating.
May this helps out as a start? (not possible to paste more code due to the size).
Reading modbus registers (sensors):
[{"id":"c65a5a65.72f3b8","type":"inject","z":"c1e03843.9d14a8","name":"Poll(10s)","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"10","crontab":"","once":true,"onceDelay":"10","topic":"","payload":"","payloadType":"date","x":80,"y":580,"wires":[["68a6b029.eb563","705bcad4.194ec4","80d78914.de5d38","1aedba91.04b3f5","b5d6e697.144ba8","f8e6582c.4ec7e8","3a7de46.32ee01c","5ea6e1d2.0b447","219b6a9a.0ed5e6","e6d9f4c7.a48278"]]},{"id":"68a6b029.eb563","type":"function","z":"c1e03843.9d14a8","name":"Modbus read","func":"var fc=3;\nvar sa=1254;\nvar addresses=1;\nvar slave_ip=msg.payload.slave_ip;\n\nmsg.slave_ip=\"192.168.1.30\";\nmsg.payload={value: msg.payload, 'fc': fc, 'unitid': 1, 'address': sa , 'quantity': addresses };\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":250,"y":580,"wires":[["84937855.5af778"]]},{"id":"84937855.5af778","type":"modbus-flex-getter","z":"c1e03843.9d14a8","name":"Sensor","showStatusActivities":false,"showErrors":true,"logIOActivities":false,"server":"86a33495.600fd8","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"x":400,"y":580,"wires":[[],["7bd64506.de398c"]],"info":"VTR300 Intern UR"},{"id":"7bd64506.de398c","type":"function","z":"c1e03843.9d14a8","name":"0-5000rpm","func":"var Rpm = msg.payload.data[0];\n\nmsg.payload = Rpm;\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":550,"y":580,"wires":[["e310653.30ff398"]]},{"id":"e310653.30ff398","type":"ha-entity","z":"c1e03843.9d14a8","name":"Vifte Komp. [rpm]","server":"2c4e313e.d0fc5e","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"vtr300_vifte_hast_komp_rpm"},{"property":"device_class","value":"power_factor"},{"property":"icon","value":""},{"property":"unit_of_measurement","value":"rpm"}],"state":"payload","stateType":"msg","attributes":[],"resend":false,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":810,"y":580,"wires":[[]],"info":"# Utekompensert vifte kompensering:\n0% til 50% pådrags kompensering "},{"id":"705bcad4.194ec4","type":"function","z":"c1e03843.9d14a8","name":"Modbus read","func":"var fc=3;\nvar sa=12102;\nvar addresses=1;\nvar slave_ip=msg.payload.slave_ip;\n\nmsg.slave_ip=\"192.168.1.30\";\nmsg.payload={value: msg.payload, 'fc': fc, 'unitid': 1, 'address': sa , 'quantity': addresses };\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":250,"y":620,"wires":[["79fc3ca2.89c304"]]},{"id":"79fc3ca2.89c304","type":"modbus-flex-getter","z":"c1e03843.9d14a8","name":"Sensor","showStatusActivities":false,"showErrors":true,"logIOActivities":false,"server":"86a33495.600fd8","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"x":400,"y":620,"wires":[[],["5627d7d5.1ce3e8"]],"info":"VTR300 Intern UR"},{"id":"5627d7d5.1ce3e8","type":"function","z":"c1e03843.9d14a8","name":"Range -40->80","func":"var Temp_raw = msg.payload.data[0];\nvar Temp_scaled;\n\nif (Temp_raw < 6280) { \n Temp_scaled = (Temp_raw *0.1);\n}\nelse {\n Temp_scaled = ((Temp_raw - 65535) *0.1); \n}\n\nmsg.payload = parseFloat((Temp_scaled).toFixed(2));\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":560,"y":620,"wires":[["8e139b51.6e3fe8"]],"info":"# Engineering range: -40°C -> 50°C\n"},{"id":"1aedba91.04b3f5","type":"function","z":"c1e03843.9d14a8","name":"Modbus read","func":"var fc=3;\nvar sa=12101;\nvar addresses=1;\nvar slave_ip=msg.payload.slave_ip;\n\nmsg.slave_ip=\"192.168.1.30\";\nmsg.payload={value: msg.payload, 'fc': fc, 'unitid': 1, 'address': sa , 'quantity': addresses };\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":250,"y":700,"wires":[["8d6ef3f4.328dc"]]},{"id":"8d6ef3f4.328dc","type":"modbus-flex-getter","z":"c1e03843.9d14a8","name":"Sensor","showStatusActivities":false,"showErrors":true,"logIOActivities":false,"server":"86a33495.600fd8","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"x":400,"y":700,"wires":[[],["87791222.6ca83"]],"info":"VTR300 Intern UR"},{"id":"87791222.6ca83","type":"function","z":"c1e03843.9d14a8","name":"Range -40->80","func":"var Temp_raw = msg.payload.data[0];\nvar Temp_scaled;\n\nif (Temp_raw < 6280) { \n Temp_scaled = (Temp_raw *0.1);\n}\nelse {\n Temp_scaled = ((Temp_raw - 65535) *0.1); \n}\n\nmsg.payload = parseFloat((Temp_scaled).toFixed(2));\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":560,"y":700,"wires":[["24aa165e.573b2a"]],"info":"# Engineering range: -40°C -> 50°C"},{"id":"24aa165e.573b2a","type":"ha-entity","z":"c1e03843.9d14a8","name":"Inntakstemp. [°C]","server":"2c4e313e.d0fc5e","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"vtr300_inntaks_temperatur"},{"property":"device_class","value":"temperature"},{"property":"icon","value":"mdi:thermometer"},{"property":"unit_of_measurement","value":"°C"}],"state":"payload","stateType":"msg","attributes":[],"resend":false,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":810,"y":700,"wires":[[]],"info":"# Utekompensert vifte kompensering:\n0% til 50% pådrags kompensering "},{"id":"8e139b51.6e3fe8","type":"ha-entity","z":"c1e03843.9d14a8","name":"Tilluftstemp. [°C]","server":"2c4e313e.d0fc5e","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"vtr300_tillufts_temperatur"},{"property":"device_class","value":"temperature"},{"property":"icon","value":"mdi:thermometer"},{"property":"unit_of_measurement","value":"°C"}],"state":"payload","stateType":"msg","attributes":[],"resend":false,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":800,"y":620,"wires":[[]],"info":"# Utekompensert vifte kompensering:\n0% til 50% pådrags kompensering "},{"id":"b5d6e697.144ba8","type":"function","z":"c1e03843.9d14a8","name":"Modbus read","func":"var fc=3;\nvar sa=12543;\nvar addresses=1;\nvar slave_ip=msg.payload.slave_ip;\n\nmsg.slave_ip=\"192.168.1.30\";\nmsg.payload={value: msg.payload, 'fc': fc, 'unitid': 1, 'address': sa , 'quantity': addresses };\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":250,"y":740,"wires":[["c6d50893.ed54c8"]],"info":"# 2050 NB!EAT/RAT used for extract air controller, benyttes pga. avtrekk AI er \"ekstrautstyr\""},{"id":"c6d50893.ed54c8","type":"modbus-flex-getter","z":"c1e03843.9d14a8","name":"Sensor","showStatusActivities":false,"showErrors":true,"logIOActivities":false,"server":"86a33495.600fd8","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"x":400,"y":740,"wires":[[],["573f9e49.21545"]],"info":"VTR300 Intern UR"},{"id":"573f9e49.21545","type":"function","z":"c1e03843.9d14a8","name":"Range -40->80","func":"var Temp_raw = msg.payload.data[0];\nvar Temp_scaled;\n\nif (Temp_raw < 6280) { \n Temp_scaled = (Temp_raw *0.1);\n}\nelse {\n Temp_scaled = ((Temp_raw - 65535) *0.1); \n}\n\nmsg.payload = parseFloat((Temp_scaled).toFixed(2));\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":560,"y":740,"wires":[["8caa3e3a.f515c"]],"info":"# Engineering range: -40°C -> 50°C"},{"id":"8caa3e3a.f515c","type":"ha-entity","z":"c1e03843.9d14a8","name":"Avtrekkstemp. [°C]","server":"2c4e313e.d0fc5e","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"vtr300_avtrekks_temperatur"},{"property":"device_class","value":"temperature"},{"property":"icon","value":"mdi:thermometer"},{"property":"unit_of_measurement","value":"°C"}],"state":"payload","stateType":"msg","attributes":[],"resend":false,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":810,"y":740,"wires":[[]],"info":"# Utekompensert vifte kompensering:\n0% til 50% pådrags kompensering "},{"id":"80d78914.de5d38","type":"function","z":"c1e03843.9d14a8","name":"Modbus read","func":"var fc=3;\nvar sa=12107;\nvar addresses=1;\nvar slave_ip=msg.payload.slave_ip;\n\nmsg.slave_ip=\"192.168.1.30\";\nmsg.payload={value: msg.payload, 'fc': fc, 'unitid': 1, 'address': sa , 'quantity': addresses };\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":250,"y":660,"wires":[["28f35935.b68ff6"]],"info":"# 2050 NB!EAT/RAT used for extract air controller, benyttes pga. avtrekk AI er \"ekstrautstyr\""},{"id":"28f35935.b68ff6","type":"modbus-flex-getter","z":"c1e03843.9d14a8","name":"Sensor","showStatusActivities":false,"showErrors":true,"logIOActivities":false,"server":"86a33495.600fd8","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"x":400,"y":660,"wires":[[],["de46baec.e636e8"]],"info":"VTR300 Intern UR"},{"id":"de46baec.e636e8","type":"function","z":"c1e03843.9d14a8","name":"Range -40->80","func":"var Temp_raw = msg.payload.data[0];\nvar Temp_scaled;\n\nif (Temp_raw < 6280) { \n Temp_scaled = (Temp_raw *0.1);\n}\nelse {\n Temp_scaled = ((Temp_raw - 65535) *0.1); \n}\n\nmsg.payload = parseFloat((Temp_scaled).toFixed(2));\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":560,"y":660,"wires":[["17f5ddc3.689502"]],"info":"# Engineering range: -40°C -> 50°C"},{"id":"17f5ddc3.689502","type":"ha-entity","z":"c1e03843.9d14a8","name":"Tilluftstemp. Overhetn. [°C]","server":"2c4e313e.d0fc5e","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"vtr300_overhetingstemperatur_tilluft"},{"property":"device_class","value":"temperature"},{"property":"icon","value":"mdi:thermometer"},{"property":"unit_of_measurement","value":"°C"}],"state":"payload","stateType":"msg","attributes":[],"resend":false,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":840,"y":660,"wires":[[]],"info":"# Utekompensert vifte kompensering:\n0% til 50% pådrags kompensering "},{"id":"86a33495.600fd8","type":"modbus-client","name":"VTR300","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"tcpHost":"192.168.1.30","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","unit_id":1,"commandDelay":1,"clientTimeout":1000,"reconnectOnTimeout":true,"reconnectTimeout":2000,"parallelUnitIdsAllowed":true},{"id":"2c4e313e.d0fc5e","type":"server","name":"Home Assistant","addon":true}]
Modbus write/readback:
[{"id":"87361de4.0b4aa","type":"modbus-flex-write","z":"c1e03843.9d14a8","name":"Set state","showStatusActivities":false,"showErrors":true,"server":"86a33495.600fd8","emptyMsgOnFail":false,"keepMsgProperties":false,"x":840,"y":3820,"wires":[[],[]]},{"id":"668663b5.e26c4c","type":"function","z":"c1e03843.9d14a8","name":"On/Off","func":"var fc=6;\nvar sa=2504;\nvar addresses=1;\nvar value=msg.payload;\n\nmsg.slave_ip=\"192.168.1.30\";\nmsg.payload={\"value\":value , 'fc': fc, 'unitid': 1, 'address': sa , 'quantity': addresses };\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":710,"y":3820,"wires":[["87361de4.0b4aa"]],"info":"# 0 Deaktiverer Eco drift\n# 1 Aktiverer Eco"},{"id":"ec5d08d0.5511b8","type":"rbe","z":"c1e03843.9d14a8","name":"POC","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":590,"y":3820,"wires":[["668663b5.e26c4c"]],"info":"Videresender kun nye verdier/endringer for å hindre unødig data til modbus slave."},{"id":"a0729a78.535c78","type":"trigger","z":"c1e03843.9d14a8","name":"Tr.5s","op1":"","op2":"","op1type":"nul","op2type":"payl","duration":"5","extend":true,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":470,"y":3820,"wires":[["ec5d08d0.5511b8"]],"info":"Videresender siste verdi etter 5 sek. for å unngå å jamme ned modbus slave, om ikke går ikke settpunkt gjennom."},{"id":"e204afdb.d756e","type":"change","z":"c1e03843.9d14a8","name":"Str.-->INT","rules":[{"t":"change","p":"payload","pt":"msg","from":"off","fromt":"str","to":"0","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"on","fromt":"str","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":340,"y":3820,"wires":[["a0729a78.535c78"]]},{"id":"aa920ab1.412b28","type":"inject","z":"c1e03843.9d14a8","name":"Poll(20s)","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"20","crontab":"","once":true,"onceDelay":"10","topic":"","payload":"","payloadType":"date","x":120,"y":3880,"wires":[["f04e59c8.5b2e88"]]},{"id":"f04e59c8.5b2e88","type":"function","z":"c1e03843.9d14a8","name":"Read","func":"var fc=3;\nvar sa=2504;\nvar addresses=1;\nvar slave_ip=msg.payload.slave_ip;\n\nmsg.slave_ip=\"192.168.1.30\";\nmsg.payload={value: msg.payload, 'fc': fc, 'unitid': 1, 'address': sa , 'quantity': addresses };\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":250,"y":3880,"wires":[["f5091f5f.b5b9c"]]},{"id":"f5091f5f.b5b9c","type":"modbus-flex-getter","z":"c1e03843.9d14a8","name":"Modbus","showStatusActivities":false,"showErrors":true,"logIOActivities":false,"server":"86a33495.600fd8","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"x":380,"y":3880,"wires":[[],["57cebaa5.bc2e94"]],"info":"VTR300 Intern UR"},{"id":"57cebaa5.bc2e94","type":"function","z":"c1e03843.9d14a8","name":"Eco mode","func":"var msg0 = msg.payload.data[0];\n\nmsg.payload = msg0;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":520,"y":3880,"wires":[["344e1f2d.df892","66c96a52.373bc4"]],"info":"# Engineering range: -30°C -> 0°C\n\nRaw 0 = 0°C\nRaw 65526 = -1°C\nRaw 65236 = -15°C\n\nRange 65526 - 65236 = 290\n290/29= 10Raw/1°C"},{"id":"344e1f2d.df892","type":"delay","z":"c1e03843.9d14a8","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":660,"y":3880,"wires":[["9e1413fb.8afb6"]]},{"id":"9e1413fb.8afb6","type":"rbe","z":"c1e03843.9d14a8","name":"POC","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":790,"y":3880,"wires":[["1ca24cdc.d0ba03"]]},{"id":"c244f269.9faec","type":"change","z":"c1e03843.9d14a8","name":"Off ","rules":[{"t":"change","p":"payload","pt":"msg","from":"0","fromt":"num","to":"off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1050,"y":3860,"wires":[["6cb7ca60.5c64e4"]]},{"id":"1ca24cdc.d0ba03","type":"switch","z":"c1e03843.9d14a8","name":"Int->Str.","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"eq","v":"1","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":920,"y":3880,"wires":[["c244f269.9faec"],["fcc9726e.ec7"]]},{"id":"fcc9726e.ec7","type":"change","z":"c1e03843.9d14a8","name":"On","rules":[{"t":"change","p":"payload","pt":"msg","from":"1","fromt":"num","to":"on","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1050,"y":3900,"wires":[["71b09b27.5220b4"]]},{"id":"66c96a52.373bc4","type":"ha-entity","z":"c1e03843.9d14a8","name":"Eco mode state","server":"2c4e313e.d0fc5e","version":1,"debugenabled":false,"outputs":1,"entityType":"binary_sensor","config":[{"property":"name","value":"vtr300_eco_mode_state"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:leaf"},{"property":"unit_of_measurement","value":""}],"state":"payload","stateType":"msg","attributes":[],"resend":false,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","outputOnStateChange":false,"outputPayload":"","outputPayloadType":"str","x":680,"y":3920,"wires":[[]]},{"id":"940bc341.d45bc","type":"server-state-changed","z":"c1e03843.9d14a8","name":"Eco mode trigger","server":"2c4e313e.d0fc5e","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_boolean.vtr300_eco_mode_dummy","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"milliseconds","ignorePrevStateNull":true,"ignorePrevStateUnknown":true,"ignorePrevStateUnavailable":true,"ignoreCurrentStateUnknown":true,"ignoreCurrentStateUnavailable":true,"x":120,"y":3820,"wires":[["e204afdb.d756e"]]},{"id":"6cb7ca60.5c64e4","type":"api-call-service","z":"c1e03843.9d14a8","name":"Set Eco. Off","server":"868599a7.b14688","version":1,"debugenabled":false,"service_domain":"switch","service":"turn_off","entityId":"switch.vtr300_eco_mode","data":"","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":1190,"y":3860,"wires":[[]]},{"id":"71b09b27.5220b4","type":"api-call-service","z":"c1e03843.9d14a8","name":"Set Eco. On","server":"868599a7.b14688","version":1,"debugenabled":false,"service_domain":"switch","service":"turn_on","entityId":"switch.vtr300_eco_mode","data":"","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":1190,"y":3900,"wires":[[]]},{"id":"86a33495.600fd8","type":"modbus-client","name":"VTR300","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"tcpHost":"192.168.1.30","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","unit_id":1,"commandDelay":1,"clientTimeout":1000,"reconnectOnTimeout":true,"reconnectTimeout":2000,"parallelUnitIdsAllowed":true},{"id":"2c4e313e.d0fc5e","type":"server","name":"Home Assistant","addon":true},{"id":"868599a7.b14688","type":"server","name":"Home Assistant","addon":true}]
