Modbus Sensor TCP for Komfovent
Could you share your config where I can see how you triggered max air ( changing value) ? Or you just set boost mode? :slight_smile:
Cool, so you just connect the main unit to the LAN and you can communicate over modbus protocol, right?
Does it have any sensor, example for cooking so it turns the vent to the maximum? Or you must turn it on manually?
Yes just connect to the lan. Also you could change paramters via phone app.
I also can’t understand how to set maximum value for the vent. Maybe someone will help us :slight_smile:
Cool. For the max value: can’t you use some network sniffer to check how the app communicates with the main unit?
I don’t know if it helps, but I requested modbus protocol from Komfovent:
https://mega.nz/folder/wVYAGBbQ#Po1_y6TCpkrkfrj52GZ6Ng
Hi, did some design, added some buttons and moved some.
Works like charm.
Thats really nice. Could you please share configuration.yaml and Lovelace?
Max air you can trigger by external wired circuit contact.
I use HA. If light ON, then boost for some time recuperation.
Hi, i used narnaliai setup and just edited it a bit.
configuration.yaml
modbus:
  type: tcp
  host: 192.168.1.34
  port: 502
switch:
  - platform: modbus
    registers:
      - name: "Komfovent Auto Mode"
        hub: Komfovent
        slave: 1
        register: 3
        command_on: 1
        command_off: 0
  - platform: modbus
    registers:
      - name: "Komfovent Power"
        hub: Komfovent
        slave: 1
        register: 0
        command_on: 1
        command_off: 0
  - platform: modbus
    registers:
      - name: "Komfovent Eco Mode"
        hub: Komfovent
        slave: 1
        register: 2
        command_on: 1
        command_off: 0
  - platform: modbus
    scan_interval: 10
    registers:
        hub: Komfovent
        register: 0
        register_type: holding
  - platform: modbus
    scan_interval: 10
    registers:
      - name: "Komfovent Eco"
        hub: Komfovent
        register: 2
  - platform: modbus
    scan_interval: 10
    registers:
      - name: "Komfovent Auto"
        hub: Komfovent
        register: 3
  - platform: modbus
    scan_interval: 10
    registers:
      - name: "Komfovent Mode"
        hub: Komfovent
        register: 4
  - platform: modbus
    scan_interval: 10
    registers:
      - name: "Komfovent Shedule"
        hub: Komfovent
        register: 5
  - platform: modbus
    scan_interval: 10
    registers:
      - name: "Komfovent Supply temperature 'C"
        hub: Komfovent
        register: 901
        unit_of_measurement: °C
        scale: 0.1
        precision: 1
  - platform: modbus
    scan_interval: 10
    registers:
      - name: "Komfovent Extract temperature 'C"
        hub: Komfovent
        register: 902
        scale: 0.1
        precision: 1
  - platform: modbus
    scan_interval: 10
    registers:
      - name: "Komfovent Supply Flow '%"
        hub: Komfovent
        register: 905
        count: 2
        precision: 1
  - platform: modbus
    scan_interval: 10
    registers:
      - name: "Komfovent Extract Flow '%"
        hub: Komfovent
        register: 907
        count: 2
        precision: 1
  - platform: modbus
    scan_interval: 10
    registers:
      - name: "Komfovent Supply Fan Intensivity '%"
        hub: Komfovent
        register: 909
        scale: 0.1
        precision: 1
  - platform: modbus
    scan_interval: 10
    registers:
      - name: "Komfovent Extract Fan Intensivity '%"
        hub: Komfovent
        register: 910
        scale: 0.1
        precision: 1
  - platform: modbus
    scan_interval: 10
    registers:
      - name: "Komfovent Outdoor temperature 'C"
        hub: Komfovent
        register: 903
        scale: 0.1
        precision: 1
  - platform: modbus
    scan_interval: 10
    registers:
      - name: "Komfovent Filter Dirt, %"
        hub: Komfovent
        register: 918
  - platform: modbus
    scan_interval: 10
    registers:
        hub: Komfovent
        register: 917
  - platform: modbus
    scan_interval: 10
    registers:
      - name: "Komfovent Filter Impurity, %"
        hub: Komfovent
        register: 916
  - platform: modbus
    scan_interval: 10
    registers:
      - name: "Komfovent Heating power, W"
        hub: Komfovent
        register: 912
        unit_of_measurement: W
  - platform: modbus
    scan_interval: 10
    registers:
      - name: "Komfovent Power consumption, W"
        hub: Komfovent
        register: 920
  - platform: modbus
    scan_interval: 10
    registers:
      - name: "Komfovent Heating Recovery Day, kWh"
        hub: Komfovent
        register: 938
        unit_of_measurement: kWh
        count: 2
        precision: 1
        scale: 0.001
  - platform: modbus
    scan_interval: 10
    registers:
      - name: "Komfovent Heating Recovery Month, kWh"
        hub: Komfovent
        register: 940
        count: 2
        precision: 2
        scale: 0.001
  - platform: modbus
    scan_interval: 10
    registers:
      - name: "Komfovent Heating Recovery Total, kWh"
        hub: Komfovent
        register: 942
        count: 2
        precision: 2
        scale: 0.001
  - platform: modbus
    scan_interval: 10
    registers:
      - name: "Komfovent Heat Recovery, W"
        hub: Komfovent
        register: 922
  - platform: modbus
    scan_interval: 10
    registers:
      - name: "Komfovent Heat exchanger efficiency, %"
        hub: Komfovent
        register: 923
        scale: 0.1
        precision: 2
  - platform: modbus
    scan_interval: 10
    registers:
      - name: "Komfovent Energy saving, %"
        hub: Komfovent
        register: 924
  - platform: modbus
    scan_interval: 10
    registers:
      - name: "Komfovent Specific power (SPI)"
        hub: Komfovent
        register: 925
        scale: 0.001
        precision: 2
Lovelace:
type: vertical-stack
cards:
  - type: horizontal-stack
    title: TööreĆŸiimid
    cards:
      - type: button
        entity: switch.komfovent_auto_mode
        icon: 'mdi:home-floor-a'
        hold_action: more_info
      - type: button
        entity: switch.komfovent_eco_mode
        icon: 'mdi:alpha-e-box-outline'
        hold_action: more-info
      - type: button
        entity: switch.komfovent_power
        icon: 'mdi:power'
    cards:
      - type: button
        tap_action:
          action: call-service
          service: modbus.write_register
          service_data:
            address: 4
            hub: Komfovent
            unit: 1
            value: 1
        hold_action:
          action: none
        show_name: true
        icon: 'mdi:home-export-outline'
      - type: button
        tap_action:
          service_data:
            address: 4
            hub: Komfovent
            unit: 1
            value: 2
        hold_action:
          action: none
        show_name: true
        icon: 'mdi:home-account'
      - type: button
        tap_action:
          service_data:
            address: 4
            hub: Komfovent
            unit: 1
            value: 3
        hold_action:
          action: none
        show_name: true
        icon: 'mdi:fan-plus'
      - type: button
        tap_action:
          service_data:
            address: 4
            hub: Komfovent
            unit: 1
            value: 4
        hold_action:
          action: none
        show_name: true
        icon: 'mdi:fan'
    title: Andurid
    cards:
      - type: sensor
        entity: sensor.komfovent_outdoor_temperature_c
        icon: 'mdi:thermometer'
        tap_action:
          action: none
      - type: sensor
        entity: sensor.komfovent_supply_temperature_c
        icon: 'mdi:home-import-outline'
        tap_action:
          action: none
      - type: sensor
        entity: sensor.komfovent_extract_temperature_c
        tap_action:
          action: none
    cards:
      - type: sensor
        entity: sensor.komfovent_supply_flow
        icon: 'mdi:fan'
        tap_action:
          action: none
      - type: sensor
        entity: sensor.komfovent_extract_flow
        icon: 'mdi:fan'
        tap_action:
          action: none
      - type: sensor
        entity: sensor.komfovent_filter_impurity
        icon: 'mdi:air-filter'
        tap_action:
          action: none
    cards:
      - type: sensor
        entity: sensor.komfovent_heating_recovery_day_kwh
        icon: 'mdi:atom-variant'
        tap_action:
          action: none
      - type: sensor
        entity: sensor.komfovent_heat_recovery_w
        tap_action:
          action: none
      - type: sensor
        entity: sensor.komfovent_power_consumption_w
        icon: 'mdi:lightning-bolt-outline'
    title: Kalendergraafik
    cards:
      - type: button
        tap_action:
          service_data:
            address: 5
            hub: Komfovent
            unit: 1
            value: 0
        hold_action:
          action: none
        show_name: true
        icon: 'mdi:home-outline'
      - type: button
        tap_action:
          service_data:
            address: 5
            hub: Komfovent
            unit: 1
            value: 1
        hold_action:
          action: none
        show_name: true
        icon: 'mdi:home-city-outline'
Sorry for my estonian translations, you can edit it at lovelace.
I’m estonian as well, so all good. Thanks
HI,
How you solved problems with state colors? without colors it is not clear which status
You need to install button-card.
cards:
    title: Recuperation
    style:
      width: 50%
    cards:
      - type: button
      - type: button
        icon: 'mdi:snowflake-variant'
    cards:
      - type: 'custom:button-card'
        entity: sensor.komfovent_mode
        tap_action:
          service_data:
            address: 4
            hub: Komfovent
            unit: 1
            value: 1
        hold_action:
          action: none
        show_name: true
        state:
          - value: '1'
            color: '#b58e31'
        tap_action:
          service_data:
            address: 4
            hub: Komfovent
            unit: 1
            value: 2
        hold_action:
          action: none
        show_name: true
        state:
          - value: '2'
            color: '#b58e31'
        tap_action:
          service_data:
            address: 4
            hub: Komfovent
            unit: 1
            value: 3
        hold_action:
          action: none
        show_name: true
        icon: 'mdi:weather-windy'
        state:
          - value: '3'
            color: '#b58e31'
        tap_action:
          service_data:
            address: 4
            hub: Komfovent
            unit: 1
            value: 4
        hold_action:
          action: none
        show_name: true
        icon: 'mdi:fan'
        state:
          - value: '4'
            color: '#b58e31'
    cards:
      - type: sensor
        tap_action:
          action: none
      - type: sensor
        tap_action:
          action: none
      - type: sensor
        tap_action:
          action: none
    title: Maintenance
    cards:
      - type: sensor
        icon: 'mdi:fan'
        tap_action:
          action: none
      - type: sensor
        icon: 'mdi:fan'
        tap_action:
          action: none
      - type: sensor
        icon: 'mdi:find-replace'
        tap_action:
          action: none
      - type: button
        icon: 'mdi:power'
    title: Power consumption
    cards:
      - type: sensor
        icon: 'mdi:power-plug'
      - type: sensor
        entity: sensor.komfovent_heating_power_w
        icon: 'mdi:radiator'
      - type: sensor
        entity: sensor.komfovent_heat_exchanger_efficiency
        icon: 'mdi:chart-areaspline'
    title: Schedule
    cards:
        entity: sensor.komfovent_shedule
        tap_action:
          service_data:
            address: 5
            hub: Komfovent
            unit: 1
            value: 0
        hold_action:
          action: none
        name: Stay at Home
        show_name: true
        state:
          - value: '0'
            color: '#b58e31'
      - type: "custom:button-card"
        tap_action:
          service_data:
            address: 5
            hub: Komfovent
            unit: 1
            value: 1
        hold_action:
          action: none
        show_name: true
        state:
          - value: '1'
            color: '#b58e31'
Hello.
Did anyone figure out how to control temperature (Register name - Setpoint)? I am able to change Supply/Extract flow values from HA but not temperature. Maybe it has something to do with Data type being signed short.
Hi!
Updated to newest home assistan and chekced in the logs. There were several modbus warnings (Sensor configuration is deprecated, will be removed in a future release).
Looks like there is a new style of modbus configuration.
You can now use the new style configuration when configuring the modbus integration. The existing configuration style is kept, allowing you to change gradually.
Remark the existing configuration style will be removed in a couple of releases.
Example of an existing configuration:
modbus:
  - name: "hub1"
    type: tcp
    host: IP_ADDRESS
    port: 502
  platform: modbus
  registers:
    - name: "Sensor1"
      hub: "hub1"
      unit_of_measurement: "°C"
      slave: 1
      register: 100
Same configuration in new style:
modbus:
  - name: "hub1"
    type: tcp
    host: IP_ADDRESS
    port: 502
    sensors:
      - name: "Sensor1"
        slave: 1
        address: 100
modbus docs: Modbus - Home Assistant
Has anybody already converted the configuration code to new style and can share it?
After latest update buttonsfor power ,eco and auto wend to be not availble
Is this a case of “new style” modbus configs ? Are somon already have new and can share :slight_smile:
Same here.
I did automation to tackle the lack of settings for summertime use of the ventilation. Komfovent is lacking the ability to dynamically change the ventilation taking account of room temperature. So in the daytime, when it’s hot outside and inside, it blows the hot air inside. Mine has a free cooling functionality, but this can be set only to supply temperature. If you set supply temp to 22 degrees, free flow tries to keep it that way and if room temp is 25 degrees and outside temp is 17 degrees, it does not allow cooler air than 22 degrees to supply. So i have set the supply temp to 5 degrees, to ensure getting as low supply air temp as possible.
Now other thing is that i don’t want is normal flow when outside is hot and inside is hot and cool the house when outside temp is low and inside is hot. This happens in the evenings and night. So depending on the inside temp I want to to cool either on normal (65/65) flow or intensive (80/80), when it’s really hot (over 35 degrees).
I game up with a automation I would like to share, so maybe somebody else can tackle the same supper hot issue:
alias: Summer Ventilation automation
description: ''
  - platform: time_pattern
    minutes: "/5" #automation runs every 5 minutes
condition: []
  - choose:
      - conditions:
          - condition: numeric_state
            entity_id: sensor.magamituba_current_temperature #my bedroom temp sensor
            above: '20'
            below: '25'
            entity_id: sensor.komfovent_supply_temperature_c
            above: '22'
        sequence:
          - service: modbus.write_register
              address: 4
              hub: Komfovent
              unit: 1
              value: 1 #Set to "away", so that it doesn't blow hot air to already hot room
      - conditions:
            above: '20'
            below: '25'
            below: '22'
        sequence:
              address: 4
              hub: Komfovent
              unit: 1
              value: 2 #Set to "normal" to use cooler outside air to cool the room
      - conditions:
            above: '25'
            below: '22'
        sequence:
              address: 4
              hub: Komfovent
              unit: 1
              value: 3 #Set to "intensive" to use cooler outside air to cool the room, if it's really hot inside
      - conditions:
            above: '25'
            above: '22'
        sequence:
              address: 4
              hub: Komfovent
              unit: 1
    default: []
mode: single
New style modbus configuration.yaml code:
modbus:
  - name: Komfovent
    type: tcp
    host: 192.168.1.34
    port: 502
    switches:
        slave: 1
        address: 3
        command_on: 1
        command_off: 0
        slave: 1
        address: 0
        command_on: 1
        command_off: 0
        slave: 1
        address: 2
        command_on: 1
        command_off: 0
    sensors:
        address: 0
        scan_interval: 10
        address: 2
        scan_interval: 10
        address: 4
        scan_interval: 10
        address: 3
        scan_interval: 10
        address: 5
        scan_interval: 10
        address: 901
        scan_interval: 10
        scale: 0.1
        precision: 1
        address: 902
        scan_interval: 10
        scale: 0.1
        precision: 1
        address: 905
        scan_interval: 10
        count: 2
        unit_of_measurement: '%'
        precision: 1
        address: 907
        scan_interval: 10
        count: 2
        precision: 1
        address: 909
        scan_interval: 10
        scale: 0.1
        precision: 1
        address: 910
        scan_interval: 10
        scale: 0.1
        precision: 1
        address: 903
        scan_interval: 10
        scale: 0.1
        precision: 1
        address: 918
        scan_interval: 10
        address: 917
        scan_interval: 10
        address: 916
        scan_interval: 10
        address: 912
        scan_interval: 10
        address: 920
        scan_interval: 10
      - name: "Komfovent Power consumption Month, kWh"
        address: 928
        scan_interval: 10
        count: 2
        precision: 0
        scale: 0.001
        address: 940
        scan_interval: 10
        count: 2
        precision: 0
        scale: 0.001
        address: 942
        scan_interval: 10
        count: 2
        precision: 0
        scale: 0.001
        address: 922
        scan_interval: 10
        address: 923
        scan_interval: 10
        scale: 1
        precision: 0
        address: 924
        scan_interval: 10
        address: 925
        scan_interval: 10
        scale: 0.001
        precision: 2
Ok ,thanks for th new code .
There is on thing with that , it is not changing th state , whn i change it from controller or via web page. ( So when i turn on Auto in HA it will be always on , even when i turn of from controller)
 Posible to fix it ?
I uptaded all code
modbus:
  - name: komfovent
    type: tcp
    host: 192.168.50.20
    port: 502
    switches:
        slave: 254
        address: 3
        command_on: 1
        command_off: 0
        slave: 254
        address: 1
        command_on: 1
        command_off: 0
        slave: 254
        address: 2
        command_on: 1
        command_off: 0
    sensors:
        scan_interval: 60
        address: 0
        input_type: holding
        scan_interval: 60
        address: 2
        input_type: holding
        scan_interval: 60
        address: 3
        input_type: holding
        scan_interval: 60
        address: 4
        input_type: holding
        scan_interval: 60
        address: 5
        input_type: holding
        address: 901
        input_type: holding
        scale: 0.1
        precision: 1
        scan_interval: 60
        address: 902
        input_type: holding
        scale: 0.1
        precision: 1
        scan_interval: 60
        address: 905
        count: 2
        input_type: holding
        precision: 1
        scan_interval: 60
        address: 907
        count: 2
        input_type: holding
        precision: 1
        scan_interval: 60
        address: 909
        input_type: holding
        scale: 0.1
        precision: 1
        scan_interval: 60
        address: 910
        input_type: holding
        scale: 0.1
        precision: 1
        scan_interval: 60
        address: 903
        input_type: holding
        scale: 0.1
        precision: 1
        scan_interval: 60
        address: 918
        input_type: holding
        scan_interval: 60
        address: 917
        input_type: holding
        scan_interval: 60
        address: 916
        input_type: holding
        scan_interval: 60
        address: 912
        input_type: holding
        scan_interval: 60
        address: 920
        input_type: holding
        scan_interval: 60
        address: 938
        input_type: holding
        count: 2
        precision: 2
        scale: 0.001
        scan_interval: 60
        address: 940
        input_type: holding
        count: 2
        precision: 2
        scale: 0.001
        scan_interval: 60
        address: 942
        count: 2
        input_type: holding
        precision: 2
        scale: 0.001
        scan_interval: 60
        address: 922
        input_type: holding
        scan_interval: 60
        address: 923
        input_type: holding
        scale: 0.1
        precision: 2
        scan_interval: 60
        address: 924
        input_type: holding
        scan_interval: 60
        address: 925
        input_type: holding
        scale: 0.001
        precision: 2
