Moes BHT-002GCLZB big probleme since
Hello
Since update to the last OS 9.5 OR the last Core 20223.2.1 OR the last last zigbee2mqtt addon i have a big problem with this device
In logs
Logger: homeassistant
Source: core.py:1144
First occurred: 08:04:38 (88 occurrences)
Last logged: 09:02:31
    Error doing job: Exception in callback MQTT._mqtt_handle_message(<paho.mqtt.cl... 0x7f5d051a80>)
    Error doing job: Exception in callback MQTT._mqtt_handle_message(<paho.mqtt.cl... 0x7f69403290>)
    Error doing job: Exception in callback MQTT._mqtt_handle_message(<paho.mqtt.cl... 0x7f611ee490>)
    Error doing job: Exception in callback MQTT._mqtt_handle_message(<paho.mqtt.cl... 0x7f685c58c0>)
    Error doing job: Exception in callback MQTT._mqtt_handle_message(<paho.mqtt.cl... 0x7f610f65e0>)
  File "/usr/local/lib/python3.10/asyncio/events.py", line 80, in _run
    self._context.run(self._callback, *self._args)
  File "/usr/src/homeassistant/homeassistant/components/mqtt/client.py", line 694, in _mqtt_handle_message
    self._mqtt_data.state_write_requests.process_write_state_requests()
  File "/usr/src/homeassistant/homeassistant/components/mqtt/models.py", line 267, in process_write_state_requests
    entity.async_write_ha_state()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 566, in async_write_ha_state
    self._async_write_ha_state()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 683, in _async_write_ha_state
    self.hass.states.async_set(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1512, in async_set
    state = State(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1144, in __init__
    raise InvalidStateError(
homeassistant.exceptions.InvalidStateError: Invalid state encountered for entity ID: sensor.thermostat_program. State max length is 255 characters.
And order send to the device dosen’t work. I can’t change the program values, i can’t on/off.
In this season it’s a big problem, and this device is at 800km. from me…
It seem’s that i 'm not alone
https://github.com/Koenkk/zigbee2mqtt/issues/16460
Have others perons the same problem
Before the updates, all work’s fine
Thank’s for the help
Similar issue for me which started after the same series of updates.
See
https://community.home-assistant.io/t/mqtt-error-for-one-of-11-identical-thermostats/531412
