EDIT: Did a test. Switch went off and its not continue.
Hi All,
Great integration. Does someone know what will happen when you have toggle time for 1 hour. And in between the toggle you restart HA. Will the timer still running after restart or do you lost it and switch will turn off automatic because of the restart?
I donāt get the āAll entitiesā option in the group config. Has defaulted to off, which in my case where I want an always on momentary switch, means I have to switch all the switches in the group off before it gets triggered. Has the group config UI changed? Anyone know if itās possible to set this in the yaml?
