What version of iPhone?
iPhone S, version 11.3.1
Wow! Thanks for the update and the work your putting in on this project! Would I be right in saying that to overcome the issues I was having previously I should use -tad flag?
I run HA on a NUC. Is it possible to also run this on the NUC as the master server as itās located centrally on main floor.
I would add 2 RPIās for basement and upstairs in slave mode.
NUC is running Ubuntu 18.04 and has built in BT.
Yes, the script will run on any UNIX or Linux box with all requirements and dependencies installed.
I would suggest to use -td, so that the only time a depart scan occurs is after a trigger is received
Thanks for the suggestion, would you suggest -td on both Pi Zeros or running this on one and leave my main one running with no flags?
Can you be more specific? iPhone 3GS? iPhone 4s? iPhone 5s? iPhone 7S? iPhone 7S plus?
If her phone is old, or her software is not updated, it is entirely possible that monitor or presence will not be able to detect her phone.
Try to detect her phone manually using hcitool name [mac address]
. If nothing is returned from this command when her phone screen is off, then neither presence nor monitor will be able to detect it.
Sorry, itās an iPhone 6s. I do think she needs to update her software. I saw a notification in there when I was looking for the Bluetooth Mac. Ok great, I will try and scan for it
I have been using -td on all my nodes with good results. However, I had to increase my trigger delay from 10 seconds to 20 seconds. This is because I also increased the arrival repetitions on my main node (3) and decreased the arrival repetitions (1) on my remote nodes.
Iām still experimenting to try and find the best settings, but this is working for now.
6s should work fine even without a software update from iOS 11.
I know the following may sound like a stupid question, but Iām asking because I ran into the same thing with a family member: are you sure sheās only turning off the screen not the entire phone?
Yeah, I was the one who was actually testing it. I turned Bluetooth off and then and on, and then received a 100 confidence. Then I turned the screen off and saw the messages coming in, dropping down to 50, 25,12, and then 0. When I turned the screen back on, the confidence did not increase back to 100
Iāve noticed since Iāve updated to latest build and added a couple of bluetooth beacons I am only receiving 1 MQTT message (for an iPhone) from Monitor in MQTT.fx. Looking at the output from sudo bash monitor.sh
Iām seeing this early on:
Error: A network protocol error occurred when communicating with the broker.
Iāve reset to default settings (sudo bash monitor.sh -d
) and updated (sudo bash monitor.sh -u
) but the issue persists.
Any ideas?
Well @andrewjfreyer, seems its no longer available as at the latest. At the same time it doesnāt seem to queue the messages.
is there something I am missing?
I am sorry I am responding so late.
I use Appdaamon and my script is here.
Honestly I keep updating it as @andrewjfreyer makes modes to the system
But basically what I do is, I have my departure scans reduced from default 4 to 3. So when a device sends a confidence of 0, I have an extra timeout of 10 secs, within this time I send out an Arrive scan again.
The scan is completed within the 10 secs, and it checks again to confirm the device is not available before declaring the user is not home.
Regards
Oh damnit. Iām sorry - stupid bug on my part. Updated. Make sure to set:
PREF_MQTT_REPORT_SCAN_MESSAGES=true
in the behavior preferences file.
Many thanks, its been fixed
Iām a trifle confused. In the write up, Andrew J Freyer says
āthe first floor pi then scans for the fixed address of our cell phones. These addresses are are stored in the known_static_addresses file. If one of those devices is seen, an mqtt message is sent to Home Assistant reporting that the scanned phone is āhomeā with a confidence of 100%. In addition, an mqtt message is sent to the second and third floor to trigger a scan on those floors as well.ā
Whatās the point of scanning the other floors when a device arrives? I know there will be a point, I just donāt know what that point is!
He then says
āWhen we leave the house, we use either the front door or the garage door to trigger an mqtt trigger of
[topic_path]/scan/depart
[ā¦] to trigger a departure scan of our devices.ā
Iām wondering if the only reason to do an MQTT departure scan trigger is precisely IF you have multiple Pis operating as a group and set to ā-tā ā¦ ? If you only have one Pi, you wouldnāt need to do this, right?
Great question - the point is to increase the range and reliability of the entire system!
For example, in a 1-node setup that does not include a trigger for depart scanning (-td
), if I spend more than a few moments on the third floor of my house, the first floor is likely to think that Iāve left because it can no longer scan my phone. Thatās bad.
I can attempt to solve this problem in at least two ways: (1) only trigger depart scans when particular doors open or close (front door, garage), and (2) include more scanning nodes.
It may not be immediately obvious but solution (1) presents an undesirable edge case if my wife and I are both home. If my wife is on the third floor when I leave to walk the dog, the 1-node will begin a depart scan and it will find that both of us have left. Iām out of range (out of the house) and sheās out of range (third floor).
If we implement (2), weāll have at least one node reporting that my wife is still home. By combining the output from our multiple nodes, (e.g., via max_min or mean; Iām now using max_min), we can obtain a non-zero confidence that my wife is in fact home despite that the first floor node doesnāt detect her when sheās on the third floor.
So, whatās the best of both worlds? Combine the strategies: use both (1) and (2). Thatās what monitor
and presence
are both designed to do.
The reason I also send an arrival scan is so that all nodes can, hopefully, update their respective internal database with respect to which devices are home and which devices are not. This also prevents an edge case where one device is scanning for arrival right after another device has reported a departure. This might cause HA to stutter on presence detection, rapidly shifting from home-away-home-away.
If you only have one pi, the triggering of other nodes neither hurts nor helps. But, by using only one node - regardless of how your scans are triggered - youāre susceptible to the edge case described above.
Update: 0.1.661
Change Log:
Breaking Change: conform online/offline status reports with home assistant MQTT sensor
Only reports known beacons (not all public beacons observed) if the known_beacons file includes content
Option for single-topic reporting with
-s
flag. All presence updates are sent to the same topic based on your publisher identity and topic path. -
Various bugfixes
