[monitor] Reliable, Multi-User, Distributed Bluetooth Occupancy/Presence Detection
Tried following the (kinda hard to follow) guide… but was stopped at this message which I get every time the script tries to publish anything to MQTT (which I can do manually)
[-] 0.2.150 27-04-2019 12:43:05 am [CMD-POST]   monitor/mon/40:98:AD:1C:44:D4
*** Error in `/usr/bin/mosquitto_pub': munmap_chunk(): invalid pointer: 0x7e94a7d7 ***
./support/mqtt: line 184: 17099 Aborted                 ( $mosquitto_pub_path -I
"$mqtt_publisher_identity" $should_retain $mqtt_version_append $mqtt_ca_file_append -L
"$mqtt_url$topic" -m "$message" 2>&1 )
I have the same error as Davst after following the guide and installing Monitor on Pi Zero W yesterday. When I was trying Monitor a few weeks ago on Pi 3, I didn’t have this issue.
Also, when I publish arrive scan, it won’t trigger the scan, though depart scan triggers. - Works if a known device is not home.
*** Error in `/usr/bin/mosquitto_pub': free(): invalid pointer: 0xbe99c87e ***
./support/mqtt: riadok 149: 12333 Aborted               ( $mosquitto_pub_path -I "$mqtt_publisher_identity" $mqtt_version_append $mqtt_ca_file_append -L "$mqtt_url$topic" -m "$message" 2>&1 )
Might have solved this by reverting bakc to the commit on march 14th. everything after that seems to be broken.
git checkout 05500a8eb354a2db7302117124977490af5eaa4b
should help you as well.
yes, please open an issue on github and we will start working through this now.
Hi Andrew,
Just got back to this. it run for about an hour.
Here what I got - last few lines. I edited the Mac addresses with xx for security reasons.
`**************** ARRIVE/REJECT FILTER DEBUG **********************
btmon packet:
> HCI Event: LE Meta Event (0x3e) plen 40 [hci0] 31.201475
  LE Advertising Report (0x02)
    Num reports: 1
    Event type: Scannable undirected - ADV_SCAN_IND (0x02)
    Address type: Random (0x01)
    Address: 47:DF:13:F2:70:xx (Resolvable)
    Data length: 28
    16-bit Service UUIDs (complete): 1 entry
      Google (0xfe9f)
    Service Data (UUID 0xfe9f): 0000000000000000000000000000000000000000
    RSSI: -78 dBm (0xb2)
flag pass: only (.*)
mfcg pass: only (.*)
flag fail: not (none)
mfcg fail: not (none)
pdu filter: only (adv_ind|adv_scan_ind|adv_nonconn_ind|scan_rsp)
blacklist: false
type: RAND
mac: 47:DF:13:F2:70:xx
pdu: ADV_SCAN_IND
type: ???
oem: Google
rssi: -78 dBm
flags: ???
hex: 0000000000000000000000000000000000000000
resolvable: RESOLVABLE
man: Google
time: 1556379589
***************** ARRIVE/REJECT FILTER DEBUG **********************
btmon packet:
> HCI Event: LE Meta Event (0x3e) plen 43 [hci0] 31.774109
    Num reports: 1
    Event type: Connectable undirected - ADV_IND (0x00)
    Address: 18:B4:30:64:36:xx (Non-Resolvable)
    Data length: 31
    128-bit Service UUIDs (complete): 1 entry
      Vendor specific (d2d3f8ef-9c99-4d9c-a2b3-91c85d44326c)
    Company: not assigned (46104)
      Data: 3064362202e9dd5a85
    RSSI: -79 dBm (0xb1)
blacklist: false
type: RAND
mac: 18:B4:30:64:36:xx
pdu: ADV_IND
type: ???
oem: ???
rssi: -79 dBm
flags: ???
hex: d2d3f8ef-9c99-4d9c-a2b3-91c85d44326c
resolvable: NON_RESOLVABLE
man: not assigned
time: 1556379589
btmon packet:
> HCI Event: LE Meta Event (0x3e) plen 43 [hci0] 31.800848
    Num reports: 1
    Event type: Non connectable undirected - ADV_NONCONN_IND (0x03)
    Address: 2B:78:60:8B:96:xx (Non-Resolvable)
    Data length: 31
    Company: Microsoft (6)
      Data: 010920025d78731da978db571c2a4e57414b50c9b556a83ae04bf7
    RSSI: -89 dBm (0xa7)
blacklist: false
type: RAND
mac: 2B:78:60:8B:96:xx
pdu: ADV_NONCONN_IND
type: ???
oem: ???
rssi: -89 dBm
flags: ???
hex: 010920025d78731da978db571c2a4e57414b50c9b556a83ae04bf7
man: Microsoft
time: 1556379589
monitor.sh: line 951: 0b00: value too great for base (error token is “0b00”)
pi@raspberrypi:~/monitor $`
Thanks. I’ll investigate.
Although these logs don’t tell me a huge amount (unfortunately; thanks for providing them nonetheless), I think I have a reasonable explanation for the behavior you’re seeing. So, I made an adjustment in the beta branch and ran through these BTLE packets - each of these seems to pass just fine.
Please update to beta and let me know if you’re still experiencing continuing issues.
Thanks Andrew will update and advise. :grinning:
@andrewjfreyer Notable… I also was installing things on a RPi Model 3. Seems that might be a factor that me and @Tony321 have in common.
I reverted back to commit 05500a8eb354a2db7302117124977490af5eaa4b which solved things.
thanks for the report. i have a spare 3 for testing.
So… both my Apple Watch and my girlfriends Withings Steel HR keep a solid 0% confidence… is there any way to track watches?
connect your AW to a bluetooth headphone so that they advertise. the HR monitor should probably be a beacon, so use the -b flag
@andrewjfreyer Doubt it is, unless beacons are 2-way. it handles notifications and such:
BT Pairing fixed the apple watch… beacons did nothing for the Steel HR though.
have you run via command line with the -b flag? can you DM your verbose/flag debug logs?
Beacons can definitely be two-way (and/or trigger or facilitate a more traditional BT connection), but the point is more to the fact that the Withings watch likely does everything it can to save battery power.
Yeah that’s likely. Shame… she’ll have to keep her phone with her =)
Hi Andrew,
I updated to the latest 0.2.186. and it still stopping.
I run it a few of times.
Last line now just says “Exited”. :frowning:
@vin, @davst @Tony321 Best solution until mosquitto is updated is to revert to mosquitto 1.5.xx per here:
EDIT - fixed in mosquitto 1.6.2+
[REMOVED]
Will try.
Thanks Andrew.
Can you shoot me a DM with a new set of logs so we can work through the stopping?
