If home assistant is running on the Raspberry Pi, I use this:
- platform: command_line
command: "/bin/cat /sys/class/thermal/thermal_zone0/temp"
unit_of_measurement: "ºC"
value_template: '{{ value | multiply(0.001) }}'
- platform: systemmonitor
resources:
- type: disk_use_percent
arg: /
- type: memory_free
- type: memory_use_percent
- type: processor_use
- type: since_last_boot
#- type: network_in
# arg: eth0
#- type: network_out
# arg: eth0
I put this in a file `packages/dev_pi.yaml" or similar, and include the package from the main configuration.
Then I havea group:
dev_pi:
entities:
- sensor.cpu_use
- sensor.cpu_temp
- sensor.disk_use_
#- sensor.disk_use_home
- sensor.ram_free
- sensor.ram_use_percent
- sensor.since_last_boot
