yes. I have another Pi where I have the docker and portainer running with some other set of containers for a different purpose. In HA on a different machine I had already influxDB and Grafana running. I wanted Unpoller thats why in HA machine, so this was the most elegant solution.
Hi there,
I finally setup snmp on Dream Machine Pro, but still have issues with:
- convert kbps to MB/s
- graphs are so slow not showing actual bandwidth usage.
- platform: unifi_status
host: xxx.xxx.xxx.xxx
port: 443
version: UDMP-unifiOS
username: USERNAME
password: PASSWORD
scan_interval: 1
monitored_conditions:
- www
- wan
- wlan
- lan
- alerts
- firmware
sensors:
unifi_status_wan_cpu:
friendly_name: "CPU"
unit_of_measurement: "%"
value_template: "{{ states.sensor.unifi_status_wan.attributes['gw_system-stats']['cpu'] }}"
unifi_status_wan_mem:
friendly_name: "Memory"
value_template: "{{ states.sensor.unifi_status_wan.attributes['gw_system-stats']['mem'] }}"
unifi_status_wan_ip:
friendly_name: 'WAN IP'
value_template: '{{ states.sensor.unifi_status_wan.attributes.wan_ip }}'
unifi_status_wan_download:
friendly_name: 'WAN Download'
unit_of_measurement: kbps
icon_template: "mdi:progress-download"
value_template: "{{ (states.sensor.unifi_status_wan.attributes['rx_bytes-r'] / 1024) | int }}"
unifi_status_wan_upload:
friendly_name: "WAN Upload"
icon_template: "mdi:progress-upload"
value_template: "{{ (states.sensor.unifi_status_wan.attributes['tx_bytes-r'] / 1024) | int }}"
unifi_status_wan_uptime:
friendly_name: "UDM Uptime"
value_template: >
{%- set time = states.sensor.unifi_status_wan.attributes['gw_system-stats']['uptime'] | int %}
{%- set minutes = ((time % 3600) // 60) %}
{%- set minutes = '{}min'.format(minutes) if minutes > 0 else '' %}
{%- set hours = ((time % 86400) // 3600) %}
{%- set hours = '{}hr '.format(hours) if hours > 0 else '' %}
{%- set days = (time // 86400) %}
{%- set days = '{}d '.format(days) if days > 0 else '' %}
{{ 'Less than 1 min' if time < 60 else days + hours + minutes }}
unifi_status_firmware_version:
friendly_name: "UDM Firmware Version"
icon_template: "mdi:database-plus"
value_template: "{{ states.sensor.unifi_status_wan.attributes.gw_version }}"
unifi_status_www_xput_down:
friendly_name: "UDM Speedtest Download"
unit_of_measurement: Mbps
value_template: "{{ states.sensor.unifi_status_www.attributes.xput_down }}"
unifi_status_www_xput_up:
friendly_name: "UDM Speedtest Upload"
value_template: "{{ states.sensor.unifi_status_www.attributes.xput_up }}"
unifi_status_www_speedtest_ping:
friendly_name: "UDM Speedtest Ping"
unit_of_measurement: ms
icon_template: "mdi:progress-clock"
value_template: "{{ states.sensor.unifi_status_www.attributes.speedtest_ping }}"
unifi_status_www_uptime:
friendly_name: 'Internet Uptime'
value_template: >
{%- set time = states.sensor.unifi_status_www.attributes.uptime | int %}
unifi_status_wlan_num_user:
friendly_name: 'Users Wifi'
icon_template: "mdi:account-multiple"
value_template: '{{ states.sensor.unifi_status_wlan.attributes.num_user }}'
unifi_status_lan_num_user:
friendly_name: 'Users Lan'
value_template: '{{ states.sensor.unifi_status_lan.attributes.num_user }}'
Any ideas?
I want to use HA like monitoring for my network.
Thank you.
I’ve given up on SNMP monitoring, I’m using UnifiPoller. That fetches data to InfluxDB, and gives tons of data, and from that I show the usage graphs on a graph I’ve made with Grafana
Does this allow you to create Lovelace Dashboard UI cards for showing current bandwidth usage?
I can’t be the only one who simply wants to see how much internet bandwidth is being used by my UDM Pro – and this really shouldn’t be that hard.
