Hi! Is there a way to monitor the uptime of other linux servers on my network?
I do it with a little bash script on the server that runs in crontab and sends the values to mqtt.
#!/bin/bash
MQTT='192.168.1.67'
## Uptime
TOPIC="home/sensors/$(hostname)/uptime"
PAYLOAD=$(cat /proc/uptime | awk '{printf "%0.f", $1}')
/usr/bin/mosquitto_pub -t "$TOPIC" -m "$PAYLOAD" -h "$MQTT"
Then, in HA, a mqtt sensor and for a nicer look a template sensor.
- platform: mqtt
state_topic: 'home/sensors/bbb-ha-gw01/uptime'
unit_of_measurement: 's'
sensors:
bbb_uptime_template:
value_template: >-
{% set uptime = (states.sensor.bbb_ha_gw01_uptime.state | float) %}
{% set seconds = uptime % 60 %}
{% set minutes = ((uptime % 3600) / 60) | int %}
{% set hours = ((uptime % 86400) / 3600) | int %}
{% set days = (uptime / 86400) | int %}
{%- if days > 0 -%}
{%- if days == 1 -%}
1 day
{%- else -%}
{{ days }} days
{%- endif -%}
{%- endif -%}
{{ '%02d' % hours }}:{{ '%02d' % minutes }}
thanks for your suggestion! I got the shell script and sensor updating in HA… I must not understand how mqttt works. my sensors show ‘unknown’ result. Any suggestions?
Do you have an MQTT broker running?
This, and does the script run in a terminal?
The mosquitto-clients
need to be installed on the server.
Yes - I have a broker running on my HA box & ` mosquitto-clients’ on my servers running the minecraft servers.
I can’t seem to find an error msg in my logs either. Any ideas for what I should specifically looking for there? I have another item using MQTT successfully.
my mosquitto broker settings:
logins: []
anonymous: true
customize:
active: false
folder: mosquitto
certfile: fullchain.pem
keyfile: privkey.pem
require_certificate: false
configuration.yaml:
- platform: mqtt
state_topic: 'home/sensors/monster/uptime'
sensors:
value_template: >-
{% set uptime = (states.sensor.monster_uptime.state | float) %}
{%- if days > 0 -%}
1 day
{%- else -%}
{{ days }} days
{%- endif -%}
{%- endif -%}
- platform: mqtt
state_topic: 'home/sensors/melon/uptime'
sensors:
value_template: >-
{% set uptime = (states.sensor.melon_uptime.state | float) %}
{%- if days > 0 -%}
1 day
{%- else -%}
{{ days }} days
{%- endif -%}
{%- endif -%}
Go to Configuration -> Integrations -> MQTT -> Configure and listen to one of the topics.
Now you can publish something to that topic.
If that works, try to publish something from you servers.
mosquitto_pub -h <mqtt_server_ip> -t home/sensors/monster/uptime -m "something"
Eureka ! thanks, that worked.
However, it seems like the ‘listen to a topic’ disappears after a reboot?
That’s only for testing.
Does it work if you publish from your servers?
Yes, if I run the script on the server, the uptime populates on the HA.
Do I need to specify HA to listen to MQTT topics somehow?
This should be done by the mqtt addon in HA.
Alternatively:
Your template sensors have both the same name, also you should write the templates one after another (not sure it that matters).
Try:
- platform: mqtt
- platform: mqtt
sensors:
monster_uptime_template: # <- this was wrong
value_template: >-
melon_uptime_template: # <- this was wrong
value_template: >-
Can you share the code you use to have the output you shared?
This is from my binary_sensor.yaml:
It is very simple. I assign static IPs to almost everything on my LAN.
### Ping for connected to GKAL Lan status
# Camera
- platform: ping
host: 10.74.1.189
count: 5
scan_interval: 300
- platform: ping
host: 10.74.1.244
count: 5
scan_interval: 300
- platform: ping
host: 10.74.1.94
count: 5
scan_interval: 300
- platform: ping
host: 10.74.1.118
count: 5
scan_interval: 300
- platform: ping
host: 10.74.1.201
count: 5
scan_interval: 300
- platform: ping
host: 10.74.1.192
count: 5
scan_interval: 300
# Rpi
- platform: ping
host: 10.74.1.144
count: 5
scan_interval: 300
- platform: ping
host: 10.74.1.199
count: 5
scan_interval: 300
- platform: ping
host: 10.74.1.169
count: 5
scan_interval: 300
- platform: ping
host: 10.74.1.38
count: 5
scan_interval: 300
Here is the display:
type: 'custom:auto-entities'
sort:
method: name
numeric: true
card:
type: entities
title: LAN
state_color: true
unique: true
filter:
include:
- entity_id: '*ping*'
options:
secondary_info: last-changed
- entity_id: '*external_ip*'
options:
exclude:
- name: '*Grocy*'
