Can you elaborate on this a little, why not for API?
I would have to find the thread(s) that explain it. It is probably the same one that gave you the impression that deep sleep is not recommended.
To GROUND or RST?
You are correct. D0 must be connected to RST. I fixed my post. Thanks!
Hello I am trying to get this up and running via esp home but when uploading your config yaml I get an error
Error reading file /config/esphome/common/binary_sensor_network_status.yaml: [Errno 2] No such file or directory: â/config/esphome/common/binary_sensor_network_status.yamlâ
this text is in red in your post so I think it needs to be changed for my setup but I am at a loss as what too? If you could expand a little please?
Can i use this to moniter my 12v 165ah solar battery
Tell me.
Those are pointers to included files. You can replace those with the âregularâ code you would have in an esphome node for wifi,log, ota etc
I can post the code in the more traditional way on Monday. Thanks
Yes you can, just make sure that you have the correct resistors for the battery Amperage, otherwise you will burn your microprocessor.
That would be great , thank you
Try this. This is the version without the included files.
substitutions:
devicename: battery_voltage
devicename_friendly: Car Battery
ip_address: 192.168.1.219
esphome:
platform: ESP8266
board: d1_mini
wifi:
networks:
ssid: "HomeAssistant"
password: "MyPassword"
priority: 1
#use_address: ${devicename}.local
power_save_mode: none
reboot_timeout: 15min
manual_ip:
static_ip: ${ip_address}
subnet: 255.255.255.0
gateway: 192.168.1.1
dns1: 192.168.1.1
ap:
ssid: "${devicename} Hotspot"
password: "AnotherPassword"
fast_connect: true
captive_portal:
logger:
baud_rate: 0
level: VERBOSE
ota:
deep_sleep:
run_duration: 20s
sleep_duration: 60min
mqtt:
broker: 192.168.1.XXX
username: !secret mqtt_username
password: !secret mqtt_password
on_message:
- topic: deep_sleep/ota_mode
payload: 'ON'
then:
- deep_sleep.prevent: battery_deep_sleep
payload: 'OFF'
then:
- deep_sleep.enter: battery_deep_sleep
binary_sensor:
- platform: status
name: ${devicename} network status
- platform: adc
pin: A0
update_interval: 10s
filters:
- multiply: 14.5583
- platform: wifi_signal
name: ${devicename} WiFi Signal
update_interval: 60s
- platform: uptime
unit_of_measurement: h
filters:
- lambda: return int((x + 1800.0) / 3600.0);
switch:
- platform: restart
text_sensor:
- platform: version
name: ${devicename} ESPHome version
- platform: wifi_info
ip_address:
name: ${devicename} IP Address
ssid:
name: ${devicename} Connected SSID
bssid:
thank you I will have a look tomorrow.
How about a monitor to open the garage door when the car starts up.
( Although a non HA solution might be better)
Just trigger on the voltage going above 13.7 volts (to be on the safe side)
hello, I have successfully got the module up and running and talking to home assistant-Thank you very much.
I just need to play with the multiplier value as it is 0.10 to low.
I would like to add another 2 cars , so other than changing the ip address and the device name would there be any other issues?
@laca75tn Also would it be possible to prevent deep sleep over a preset voltage say 13.5 volts when the engine is running, that way the wifi will be awake when the car arrives home, and could be used then for other automations ?
Yes, you can add that functionality using the on_value_range. It would be something like the code below. Check the indentation and syntax to make sure is correct.
- platform: adc
pin: A0
filters:
- multiply: 14.5583
on_value_range:
below: 13.5
then:
Emm⌠Will that not prevent deep sleep when it runs on battery?
Meaning while the car is parked the ESP will be on, when the car is running the deep sleep is activated?
Probably it should be above not below.
But even that will not be enough I believe.
If it does not know that the car is running then it canât prevent the deep sleep.
So worst case scenario, if you update every 10 minutes then you could be unlucky to start the car just after an update, then it wonât go out of deep sleep until the next update which is almost 10 minutes later.
If I recall correctly, you can wake it up with a pin.
If you take a wire that is connected to something that is only on while the car is running then you could add a voltage divider to this and feed it to the pin, so as you start the car this pin goes high => ESP wakes up.
I donât have all the details of what Philip wants to accomplish. I was just showing how he can prevent deep sleep based on a value. He can use above/below to prevent/enter deep sleep depending on what he wants to accomplish.
Only the Esp32 allows you to wake up from a pin, my example is using a D1 Mini 8266 and I canât do that. Thanks.
Sorry, that I didnât reply to this sooner, I never received a notification about it. Yes, you are correct, you just need to change the IP Address and name of the node. I would explicitly make the deep_sleep value to be internal to prevent confusion with the other node.
deep_sleep:
run_duration: 20s
internal: true
thank you for your help, I am using D1 minis , and I will have a play and see if I can get it working, I was just thinking long term for possible future automations.
