Monitor your Generac generator with Home Assistant
I suppose that’s possible but I haven’t had a service contract for the generator for about 3 years. Is there anyway to get a firmware version from the nexus controller? And what version would I be looking for?
Curious if this is the firmware issue you’re referring to- https://github.com/jgyates/genmon/issues/374
If so I don’t need to worry about it since it’s related to the Evolution controllers. Mine is Nexus.
Edit: Also looks like that issue has been resolved.
I would get GenMon a try. It is a very nice interface. I know in one of this boards someone has the all the scrape sensors for you to readily use that way you don’t have to worry about MQTT.
Not sure I understand. Genmon sensors can be added to HA without using MQTT?
I pretty new to HA and looking to keep this integration simple.
Go to the start of the thread and read from post 1. There are two yaml files posted. Neither of them use mqtt.
I think the preferred integration these days is to use MQTT. Initially, I looked at using the REST sensor to poll genmon, but later MQTT capability was added to genmon and that works quite well for me.
In addition to this page, there’s also a discussion of MQTT and Home Assistant integration in one of the genmon issues that you could review.
As @GlennHA mentioned, the genmon project is quite well managed and maintained, and there’s very active development going on. I would suggest looking at their github page and in particular, the genmon Wiki which will walk you through how to build your own.
You don’t need a hugely powerful Raspberry Pi - I initially ran it on a Raspberry Pi Zero W for more than a year with no problems. Because I can’t leave well enough alone, I built a piggyback board for the Raspberry Pi with 3 thermocouple interfaces and an isolated serial port. This was all complete overkill, but great fun. When I swapped it in, I used a Raspberry Pi 3, just to get a little more headroom.
I do get exported from genmon alarm conditions, such as warning for battery maintenance, etc. It’s also nice to know when the generator is running since I can’t really hear mine while running and when I wake up in the middle of the night, I can tell because I set some lights inside the house to remind me.
Thanks. Actually I’ll probably just purchase a pre-built genmon unit. I suck at diy cables.
So, to install this into HA I just need to drop the revised YAML file into the packages directory and restart the server?
I’ve only just skimmed over what’s required to use MQTT in HA. I see that I’ll need to install the mosquito add-on. Is there any special configuration necessary in genmon to get it connected to the broker?
@wgstarks You’ll need to enable the MQTT module in genmon as that’s not there by default. The YAML files that I had posted probably will need to be adjusted in that I used non-standard MQTT topic prefixes to match the scheme that I generally use here.
Also you can probably simply the YAML templates as I did my configuration back when the MQTT messages sent by genmon had units attached to the values. You can see in my templates where I match those to strip them off. It may actually be the case it will still work if the option to omit the units from the published are not actually present.
I run mosquitto as a separate docker container as I run the “Home Assistant Core” Docker container without the Home Assistant OS and Supervisor. You can achieve the same result by using the packaged add-ons, however as I don’t run that environment myself, I cannot be very specific. Not to worry, as there’s nothing particularly clever going on here. Mostly you just need to make sure the topic prefixes on the genmon end match what the MQTT sensors in Home Assistant are looking for.
Here’s what my current configuration in Home Assistant for genmon. It’s using the Home Assistant “package” configuration form, but you can split the pieces out as necessary.
## Package / Generator
#  Version 0.2
#  (This file is used as a "package" within the Home Assistant
#  configuration files.  If you don't use packages with your Home
#  Assistant configuration files, you need only take the relevant
#  sections of this file and add them to where you define
#  sensors, binary_sensors, etc.)
#  This package is used to interwork with (only) Generac-brand standby
#  generator systems with Nexus, Evolution and H100 controllers, also
#  using the open-source "genmon" package.  This package typically
#  runs on a dedicated Raspberry Pi (2, 3 or Zero) and is connected
#  via a serial cable to the controller located inside the generator
#  cabinet.  See:
#     https://github.com/jgyates/genmon
#  for additional information about genmon, how it works and what's
#  required to implement it.  Thanks very much to the author for a
#  quite complete and featureful monitoring system that can send
#  email, SMS notifications and many other things!
#  The genmon package consists of a number of components, the primary
#  one being the actual Python script that communicates with the
#  generator using a ModBus protocol.
#  In practice, this means running the genmon.py and genserv.py (web
#  server) daemons on the Raspberry Pi connected to the generator.
#  Among the optional components is a daemon which can monitor
#  the generator via genmon, and publish relevant information to
#  MQTT topics.
#  This module implements a means to collect this data without
#  requiring a custom component, or additional software that needs to
#  run.  This uses a number of MQTT sensors and jinga2 templates to
#  receive the published data and expose them as sensor entities in
#  Home Assistant.
#  genmon MQTT flushes out MQTT updated every 60 seconds.  You can choose
#  to have MQTT sensors for any or all of these data.  Note that some
#  of the published data changes rather often, such as wifi RSSI,
#  uptime counters, etc.  You might want to configure your recorder
#  component to not store those values to avoid needlessly bloating
#  the recorder database with historically uninteresting data.
#  note that the unique_id values in this file are not signficant (or
#  even required at all).  They exist so that the entities show up
#  within the Home Assistant configuration GUI for customization.  I
#  chose to use UUIDs because it was an easy source of unique values,
#  no harm would likely come from using these same values or any that
#  you choose from on your own.
#  Louis Mamakos <[email protected]>
#  10 Dec 2020
## Customize
homeassistant:
  customize:
    ## Node Anchors
    package.node_anchors:
      customize: &customize
        package: 'generator'
    ## generator customization
    binary_sensor.genmon_power_outage:
      friendly_name: 'Generator Power Outage'
    sensor.genmon_outage_status:
      friendly_name: 'Generator Status'
    sensor.genmon_outage_utility_voltage:
      friendly_name: 'Generator Utility Voltage'
    sensor.genmon_generator_battery:
      friendly_name: 'Generator Battery Voltage'
    sensor.genmon_generator_rpm:
      friendly_name: 'Generator RPM'
    sensor.genmon_generator_frequency:
      friendly_name: 'Generator Frequency'
    sensor.genmon_generator_output_voltage:
      friendly_name: 'Generator Output Voltage'
    sensor.genmon_generator_output_current:
      friendly_name: 'Generator Output Current'
    sensor.genmon_generator_output_power:
      friendly_name: 'Generator Output Power'
    sensor.genmon_generator_last_alarm_log:
      friendly_name: 'Generator Last Alarm'
    sensor.genmon_generator_last_service_log:
      friendly_name: 'Generator Last Service Log'
    sensor.genmon_generator_last_action:
      friendly_name: 'Generator Last Action'
    sensor.genmon_generator_capacity:
      friendly_name: 'Generator Capacity'
    sensor.genmon_generator_exercise_time:
      friendly_name: 'Generator Exercise Time'
    sensor.genmon_mon_cpu_temperature:
      friendly_name: 'Generator CPU Temperature'
    sensor.genmon_mon_uptime:
      friendly_name: 'Generator Monitor Uptime'
    sensor.genmon_mon_load:
      friendly_name: 'Generator Monitor Load'
    sensor.genmon_outage_summary:
      friendly_name: 'Generator Outage Summary'
## generator sensors
#  The MQTT topics need to match what's transmitted by the
#  genmon host.  I use a non-standard MQTT prefix of '19916/' to
#  conform with the convention that I happen to use with my own
#  home automation system.
  - platform: mqtt
    unique_id: "fd8f8c07-7d6f-4aea-92b5-16b7d8acc66b"
    expire_after: 300   # genmon MQTT flushes out MQTT updated every 60 seconds
    state_topic: '19916/generator/Outage/Status'
    name: Genmon Outage Status
  - platform: mqtt
    unique_id: "f565fed6-8a19-49d4-8066-4015c5ca91b1"
    state_topic: '19916/generator/Outage/Utility Voltage'
    name: Genmon Outage Utility Voltage
    value_template: '{{ value | regex_replace(" V", "") | float | round(0) }}'
    unit_of_measurement: "VAC"
  # status related sensors
  - platform: mqtt
    unique_id: "713eb4b9-feec-4425-8c83-84a9f486aae7"
    name: Genmon Generator Battery Raw
    state_topic: '19916/generator/Status/Engine/Battery Voltage'
    unit_of_measurement: "V"
    value_template: '{{ value | regex_replace(" V", "") | float | round(1) }}'
  - platform: filter
    entity_id: sensor.genmon_generator_battery_raw
    filters:
      - filter: time_throttle
        window_size: "00:15"
  - platform: mqtt
    unique_id: "f3a8aedd-206b-4e5f-baa9-677496ee8d3c"
    name:  Genmon Generator RPM
    unit_of_measurement: "RPM"
    state_topic: '19916/generator/Status/Engine/RPM'
    value_template: '{{ value | int }}'
  - platform: mqtt
    unique_id: "cbdc9c28-5748-4aef-91bc-5b5ec95ed545"
    name: Genmon Generator Frequency
    unit_of_measurement: "HZ"
    state_topic: '19916/generator/Status/Engine/Frequency'
    value_template: '{{ value | regex_replace(" Hz","") | float }}'
  - platform: mqtt
    unique_id: "f5f462db-e16d-4596-9bd3-232b70fa5038"
    name: Genmon Generator Output Voltage
    state_topic: '19916/generator/Status/Engine/Output Voltage'
    value_template: '{{ value | regex_replace(" V","") | float | round(1) }}'
  # current measrement is garbage on 22KW product, apparently
  - platform: mqtt
    unique_id: "10e1def6-35fd-4922-932a-90f25abb7f29"
    name: Genmon Generator Output Current
    unit_of_measurement: "A"
    state_topic: '19916/generator/Status/Engine/Output Current'
    value_template: '{{ value | regex_replace(" A","") | float | round(1) }}'
  - platform: mqtt
    unique_id: "914a4e97-54a0-41e7-bbeb-a256134e5e35"
    name: Genmon Generator Output Power
    unit_of_measurement: "W"
    state_topic: '19916/generator/Status/Engine/Output Power (Single Phase)'
    # this is normalized to watts from kilowatts
    value_template: '{{ value | regex_replace(" kW","") | float * 1000 | round(0) }}'
  - platform: mqtt
    unique_id: "8cb64471-9123-48f6-b9be-15c01595981e"
    name: Genmon Generator Last Alarm Log
    state_topic: '19916/generator/Status/Last Log Entries/Logs/Alarm Log'
  - platform: mqtt
    unique_id: "bce3182a-a525-47dc-937c-8be4e5afc619"
    name: Genmon Generator Last Service Log
    state_topic: '19916/generator/Status/Last Log Entries/Logs/Service Log'
  - platform: mqtt
    unique_id: "bf48e972-0b96-489a-9eee-4f2030017c3f"
    name: Genmon Generator Last Action
    state_topic: '19916/generator/Status/Last Log Entries/Logs/Start Stop Log'
    # maint related sensors
  - platform: mqtt
    unique_id: "bf7cbe92-2b1e-48ca-addd-df963697626c"
    name: Genmon Generator Capacity
    state_topic: '19916/generator/Maintenance/Rated kW'
    # normalize to watts
    value_template: '{{ value | float * 1000 | round(1) }}'
    unit_of_measurement: 'W'
  - platform: mqtt
    unique_id: "825657b6-c67a-427a-bee9-7b6ea2182628"
    name: Genmon Generator Exercise Time
    state_topic: '19916/generator/Maintenance/Exercise/Exercise Time'
    # might be nice to maybe somehow normalize this, but not sure into what date/time representation
    # value is something like:  "Weekly Sunday 17:35 Quiet Mode On"
  # genmon monitor related sensors
  - platform: mqtt
    unique_id: "792c8096-84a3-4870-ac23-8cc5dcc8f8f0"
    name: Genmon Mon CPU Temperature Raw
    unit_of_measurement: "°F"
    device_class: temperature
    state_topic: '19916/generator/Monitor/Platform Stats/CPU Temperature'
    value_template: '{{ value | regex_replace(" F","") | float | round(0) }}'
  - platform: filter
    entity_id: sensor.genmon_mon_cpu_temperature_raw
    filters:
        window_size: "00:10"
  - platform: mqtt
    unique_id: "7c398cb0-43bf-469b-b49f-ae8b526cac32"
    name: Genmon Mon Uptime
    # maybe parse this out into minutes/hours?
    state_topic: '19916/generator/Monitor/Platform Stats/System Uptime'
  - platform: mqtt
    unique_id: "60b44a17-2535-47da-af10-7f6b45d35d3a"
    name: Genmon Mon Load
    unit_of_measurement: '%'
    state_topic: '19916/generator/Monitor/Platform Stats/CPU Utilization'
    value_template: '{{ value | regex_replace(" *%","") | float | round(1) }}'
  # note that these following sensors are unique to my own specific situation and
  # are values collected from 1-wire bus temperature sensors connected to the Raspberry
  # Pi running genmon.  These do not come from the standard generator controller or
  # the on-board temperature sensor in the Raspberry Pi ARM CPU.  You should omit
  # these sensors if you're adapting my file for your own purposes.
  - platform: mqtt
    unique_id: "882cb971-bf3e-4281-a158-bf0d0e3eb4ea"
    expire_after: 600
    name: Genmon 1W Controller Box
    unit_of_measurement: °F
    state_topic: '19916/generator/Status/External Temperature Sensors/28-00000bc56fa5'
    value_template: '{{ value | regex_replace(" *F", "") | float | round(1) }}'
  - platform: mqtt
    unique_id: "1f54deef-b168-431a-aa9d-2af8e1fbf2c7"
    expire_after: 600
    name: Genmon 1W Outside Air
    state_topic: '19916/generator/Status/External Temperature Sensors/28-020a91770670'
  - platform: mqtt
    unique_id: "8ca45d5e-91fb-4826-bc75-ea1b3d8046c4"
    expire_after: 600
    name: Genmon TC Generator Body
    state_topic: '19916/generator/Status/External Temperature Sensors/3b-6d800cc77f01'
  - platform: mqtt
    unique_id: "545c8624-4428-4791-ba95-df671b74aafe"
    expire_after: 600
    name: Genmon TC Oil Cooler
    state_topic: '19916/generator/Status/External Temperature Sensors/3b-4c880b6ac367'
  - platform: mqtt
    unique_id: "d6f20e32-04bf-4155-842f-d68346e3a68b"
    expire_after: 600
    name: Genmon TC Engine Body
    state_topic: '19916/generator/Status/External Temperature Sensors/3b-4c880b6ac389'
    sensors:
      generator_outage_summary:
        # entity_id:
        #   - sensor.genmon_outage_status
        unique_id: "11be76cc-02bc-4868-b033-5efc60a289c5"
        value_template: >-
          {% if states.sensor.genmon_outage_status.state | regex_match('System in outage') %}
             {% set duration = (as_timestamp(now()) - as_timestamp(states.sensor.genmon_outage_status.state)) | regex_replace('System in outage since ') | int %}
             {% set hours = duration // 3600 %}
             {% set duration = duration - hours * 3600 %}
             {% set minutes = duration // 60 %}
             {% set seconds = duration % 60 %}
             Outage active for {{ '%d:%02d:%02d' | format(hours, minutes, seconds) }}
          {% else %}
            {{ states.sensor.genmon_outage_status.state }}
          {% endif %}
#  probably the most useful sensor - are we in a power outage condition or not?
binary_sensor:
  - platform: mqtt
    unique_id: "468414df-32b1-4127-8636-4202a11b880c"
    name: Genmon Power Outage
    state_topic: '19916/generator/Outage/System In Outage'
    payload_on: 'Yes'
    payload_off: 'No'
group:
  generator_stats:
    entities:
      - binary_sensor.genmon_power_outage
      - sensor.genmon_outage_utility_voltage
      - sensor.genmon_generator_battery
      - sensor.genmon_generator_rpm
      - sensor.genmon_generator_frequency
      - sensor.genmon_generator_output_voltage
      - sensor.genmon_generator_output_current
      - sensor.genmon_generator_output_power
      - sensor.genmon_generator_last_alarm_log
      - sensor.genmon_generator_last_service_log
      - sensor.genmon_generator_last_action
      - sensor.genmon_generator_capacity
      - sensor.genmon_generator_exercise_time
      - sensor.genmon_mon_cpu_temperature
      - sensor.genmon_mon_uptime
      - sensor.genmon_mon_load
      - sensor.power_volts
      - sensor.power_total
automation:
  - alias: 'start power outage'
    initial_state: 'on'
      - platform: state
        entity_id: binary_sensor.genmon_power_outage
        to: 'on'
        # so ideally wait a little bit for the generator to time out the utility power
        # loss, start and operate the automatic transfer switch from utility to generator
        # network equipment should be a UPS.. hopefully ISP connectivity is still working
        for:
          seconds: 45
      - service: notify.pushover_louie
          message: "Utiliy Power Loss at {{  now().strftime('%Y-%m-%d %H:%M:%S') }}"
          title: "HASS"
# maybe also initiate a zwave heal network or something after power is restored to
# from standby generator after a ~45 second interruption?  Switch back is pretty
# quick, with only a couple hundred millisecond transfer time in the ATS..
  - alias: end power outage
    initial_state: true
      - platform: state
        to: 'off'
          message: "Transfer back to utiliy power at {{  now().strftime('%Y-%m-%d %H:%M:%S') }}"
          title: "HASS"
############################################################################3
# Fun facts (For 22kw generac model)
#  Per specification, fuel consumption for propane is
#        2.56 gal/hr at 50% load (11KW)
#        3.87 gal/hr at 100% load (22KW)
#  Per genmon code, the 3 term polynomial to compute this is: [0, 2.74, 1.16]
#        gal/hr = (T0 * pctLoad^2) + (T1 * pctLoad) + T3
#        gal/hr =                    2.74 * pctLoad + 1.16
#  This is a pretty good fit to the spec sheet -
#       50% = 2.53 gal/hr  (vs 2.56 spec)
#      100% = 3.90 gal/hr  (vs 3.87 spec)
#  Home assistant could compute a gallons/hour rate in a template sensor if this seems useful.
Yes, my car has a privacy policy, and my stove has a motherboard.
This works great, thank you @lmamakos for your package yaml! Was pretty easy to wire this up to my Nexus controller on my Generac and power a Pi Zero W directly from the acc port and get genmon running, and your yaml worked great. I had looked into this a few years back and didn’t exist, glad the open source community was able to reverse engineer it. I ended up using this recommended cable, this TTL to RS232 converter, the status leds are handy when you accidentally reverse transmit/receive :slight_smile: I used this enclosure recommended on the Github issue tracker someone posted and remixed a Pi Zero case from Thingiverse to be able to mount the Pi and TTL converter into it.
I have some nice canvas gages setup for GenMon already to save you some time:
type: 'custom:canvas-gauge-card'
card_height: 300
entity: sensor.generator_voltage
gauge:
  type: radial-gauge
  title: Generator
  width: 300
  height: 300
  minValue: 0
  maxValue: 280
  startAngle: 40
  ticksAngle: 280
  valueBox: true
  units: Vac
  majorTicks:
    - 0
    - 28
    - 56
    - 84
    - 112
    - 140
    - 168
    - 196
    - 224
    - 252
    - 280
  minorTicks: 10
  strokeTicks: true
  highlights:
      to: 218
      color: 'rgba(234, 51, 36, .75)'
      to: 228
      color: 'rgba(255, 255, 85, .75)'
      to: 252
      color: 'rgba(104, 225, 67, .75)'
      to: 262
      to: 280
  borders: 'no'
  needleType: arrow
  needleWidth: 4
  needleCircleSize: 7
  needleCircleOuter: true
  needleCircleInner: false
  animationDuration: 1500
  animationRule: linear
  valueBoxBorderRadius: 10
  colorValueBoxRect: '#222'
  colorValueBoxRectEnd: '#333'
  valueDec: 0
  valueInt: 0
card_height: 300
entity: sensor.generator_frequency
gauge:
  type: radial-gauge
  title: Generator
  width: 300
  height: 300
  minValue: 0
  maxValue: 70
  startAngle: 40
  ticksAngle: 280
  valueBox: true
  units: Hz
  majorTicks:
    - 0
    - 10
    - 20
    - 30
    - 40
    - 50
    - 60
    - 70
  minorTicks: 10
  strokeTicks: true
  highlights:
      to: 57
      to: 58.5
      to: 61.5
      to: 63
      to: 70
  borders: 'no'
  needleType: arrow
  needleWidth: 4
  needleCircleSize: 7
  valueDec: 0
  valueInt: 0
The Generator and Utility Voltage gages are the same, so I only included one.
@GlennHA, those gauge cards look really nice! How did I not see those before… Thanks for the pointer!
Really nice @GlennHA !! Here’s a pic of my setup now that it’s daylight:
If not for the fact I couldn’t find a Pi Zero W without a $26 kit on Amazon, a relatively inexpensive project with minimal soldering required for those worried about custom wiring and soldering. This RS232/TTL board has a common ground too between both sides, so reduces communication issues which is nice in addition to the status LEDs. I was a bit annoyed as it’s “mounting holes” were smaller then M2.5 screws I had, so had to do a clamp setup for it.
I have exact enclosure, however I have a full pi and it does not look as nice. I put mine together before I had my 3D printer; I could go back and redo it, but…
I’ve got my genmon unit installed and have installed Mosquito MQTT on HA. I’ve subscribed it to topic MyGen in the integration settings. Don’t think that’s being saved though since that setting is blank if I refresh the page. I think I’m missing something somewhere?
Also not sure what to do with your generator.yaml file. Do I just install it into the Packages directory?
Edit: Tried adding the yaml file to packages directory but I get a lot of configuration errors.
Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?).  Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?).  Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?).  Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?).  Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?).  Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?).  Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?).  Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?).  Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?).  Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?).  Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?).  Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?).  Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?).  Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?).  Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?).  Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?).  Invalid config for [group]: [view] is an invalid option for [group]. Check: group->group->generator_stats->view. (See /config/configuration.yaml, line 13).  Invalid config for [binary_sensor.mqtt]: [friendly_name] is an invalid option for [binary_sensor.mqtt]. Check: binary_sensor.mqtt->friendly_name. (See ?, line ?).
@wgstarks Don’t feel bad, I didn’t either at first :slight_smile: In your config directory create a “packages” folder, then add the yaml to that. Then I added a reference to it in the configuration.yaml:
homeassistant:
  packages: !include_dir_named packages
You can also customize the entries in that yaml to fit your mqtt path if you tweaked it at all.
I already had that. Tried just adding the yaml to packages directory and got a bunch of configuration errors listed in the edit to my previous post.
Tried just adding a couple of sensors to configuration.yaml as a test but they don’t show up in the Lovelace dashboard. I can see them listed as entities with a status of unknown.
Let me look at me, I don’t recall having any problems besides having to change the pathing on the messages
@wgstarks If you use something like this: http://mqtt-explorer.com/ to watch your mqtt messages, do you see them coming in with the path you’d expect? Here’s an example of what mine looks like:
  - platform: mqtt
    state_topic: "/raw/generac01/generator/Monitor/Platform Stats/WLAN Signal Level"
    name: "Genmon WLAN Signal Level"
    value_template: '{{ value | regex_replace(" dBm", "") | float | round(1) }}'
    unit_of_measurement: dBm
    device_class: signal_strength
Which lines up to my root topic in the MQTT addon for genmon:
/raw/generac01
how do I add MQTT-explorer to HA?
