Motion-activated Light-brightness
Updated blueprint, in the last drawing, combined all the previous features (using only brightness, using color or color temperature), and also added the ability to select the transition time to turn on and off, the ability to dim the light, dim then turn off, or just turn off, also added more sensors (movement, door, occupancy, opening, moving, presence)
Hi There, just testing this blueprint and its really great as it has everything I was trying to do. One item I’m trying to achieve and checking if its possible.
Is there a way for it to not activate automatically during the day time, I tried setting the brightness for day to 0 however if motion triggers than it turns the light off.
Also is there a way to enable a condition so if the light is already on than dont change the brightness? i.e. if im in the room and adjust the brightness and the motion triggers it will reset the brightness according to the automation.
Good afternoon, yes, I can quite add a choice so that automation does not turn on during the daytime, also in general it can be done so that the brightness is not adjusted if the light is already on, but the light-off parameters will have to be left as it was, otherwise the light will not turn off, you can also use other automation, in which, according to the necessary conditions, it is simply will you turn this automation template off and on
That would be awesome for the day choice and the leave it alone if its already on.
A good idea of using another automation to toggle this the automation but that would stop the light off parameters.
I updated the last blueprint a little, now if an error occurred at one of the stages, the code will still continue to work and perform automation on dimming and turn off, I had this problem on one of the wleds when everything worked when the light was turned on, but the automation gave an error and stopped working and the light remained on, now this is fixed, and even if an error occurs somewhere, automation will still try to turn off the light
is there a way to use this with a presence mmwave sensor?
I’ve created an automation based on “Motion-activated Light-brightness” and, no matter which value I set into no_motion_wait_day, the light shuts off after exactly 4 minutes!..
Is there something else that I need to set?
I’m new to HA, and this is my first use of a blueprint. It’s outstanding - does almost everything I need to replace a legacy automation in place on another platform. I’ll add the bump to see if dusk/dawn or sun elevation could be used instead of the hard-coded time. That would make it perfect!
I would also love to see a version where you could disable it during the day. I’m using it to run outdoor lighting, which does not need to be motion activated during the daytime.
@Aleks130699 Any idea how to use this blueprint as a night light only? I’ve set the day brightness to “1”. But even then, it will still light up.
Just was wondering if anyone could help here, looking for a blueprint that could do just about the same as this one.
Been hunting one down for days
Motion is detected light goes to 100%(slider selectable) returns to a set value after no motion is detected 30%(slider selectable), but does not turn it off.
the ability to activate it during certain times
easy, set Day brightness to zero and it won’t turn on the light during this day period
Hi Aleks,
Great blueprint, love it. I do have instances where entities are are set as light and others as switches. I could convert a switch to a light using a helper but I am trying to clean the helpers as much as possible as my system was getting heavy.
when I try to tweak your code to replace the light service for the switch, it won’t work. I tried really hard but didn’t figure out why it doesn’t work.
As change you could create a version for Switches?
Hi @Aleks130699 ,
I would really like to try your blueprint, but I am getting an error when importing with the forum URL:
Other blueprints work as expected. Is there anything you can do?
Cheers;
BJ
Most likely, your motion sensor keeps the detected status for 4 minutes, blueprint start counting down from the moment the sensor switches to the not detected status
This automation is intended only for light sources that support brightness adjustment, for switch type sources, it cannot work, it is better to use another automation or create it yourself, it will be very simple, I myself for such sources
That works, but also doesn’t.
For example: I have outdoor lights in my garden set to turn on from sunset till 23:00.
Using this blueprint, I want the outdoor lights to turn on when motion is detected.
But if I use your fix by setting “Day brightness” to “zero”. It means that the lights from somewhere around sunset till 23:00 will go off AFTER the motion timer ends.
I only want my lights to turn on after 23:00 when motion is detected. It shouldn’t mess with anything during day-time.
FWIW, this works fine for sources that are switches, if you use the helper to make them lights first. Though there’s not a lot of point to that if all you have are switches, you don’t really need any of the special features here.
@Aleks130699 something that would really improve this would be checking to see if the lights are already off before going into the shutoff sequences.
Example: In my bedroom, I have three lights (one of which is a switch type converted to light :slight_smile: ) and all three are in a group, and this blueprint is attached to drive that group. I also have a remote control next to my bed, that also drives that group. I walk in the room, the lights come on. I get in bed, I press the button on the remote, the lights go off. A minute later, the blueprint gets to the timeout, and briefly blinks the lights back on to fade them out.
So checking to see if they are off and then exiting early would be really handy :slight_smile:
Thanks for the great script!
Does this blueprint work with 2026.3.0? I’ve used for many years but after the update lights don’t work. I haven’t updated this blueprint, is there a update?
Exactly the same here. 2026.3 has broken all my motion lights and also allmy light switches due to the change in this update. Got to spend today trying to fix my whole home.
Using color_temp (in mireds) to set a light’s color temperature is no longer supported. Use color_temp_kelvin instead.
Additionally, the color_temp, kelvin, min_mireds, and max_mireds light entity state attributes have been removed. Use color_temp_kelvin, min_color_temp_kelvin, and max_color_temp_kelvin instead.
