Motion sensor timer expand
first I used the choose action, then the triggered by and after that (to specify it more) an “and if” condition. do you mean that? Sorry it’s hard for me to understand what the posted code (and information from yours) does look like in the editor :frowning:
it’s very frustrating.
pretty cool, that feature could help me a lot. I will try it out.
Will I have to recreate all automations with motion sensors after installing that integration?
Well the point is, this is a replacement for the automations you already have.
You can see this as a digital device that handles the motion based lights for you (aka a state machine).
I installed the integration from HACS, rebooted and all zigbee devices are not available. I didn’t even “activated” the integration. What is that problem? is that related to that?
That can not be related if you didn’t changed your config file yet.
strange. I did nothing else :roll_eyes: :roll_eyes:
sh… now I have another construction site…
trying to load my last backup from tonight. hope that helps.
Any errors in your logs?
Which zigbee integration do you use?
I’m using the Sonoff 3.0 Dongle with Z2M integration. No errors, the lights, sensors, all zigbee things are away…suddenly. In Z2M I can see them, all are online and last seen xxx secs or xxx min ago and I’m able to switch the lights and so on. Only in HA there are all grey and not able to handle.
Is your MQTT broker running?
Keep it simple. The more dependencies and integrations you load, the more complex your system gets to maintain. Two simple automations:
- alias: Lights - hall light on
  description: Turns the hall room light on when motion detected.
    - platform: state
      entity_id: binary_sensor.motion_hallway_downstairs_occupancy
      to: 'on'
  condition:
    - condition: state
      entity_id: binary_sensor.lights_active
      state: 'on'
    - if:
        - condition: state
          entity_id: binary_sensor.nightmode
          state: 'on'
    - then:
        - service: light.turn_on
            kelvin: 2500
            brightness_pct: 20
            entity_id: light.hallway_downstairs
    - else:
            kelvin: 4000
            brightness_pct: 100
- alias: Lights - hall light off
  description: Turns the hall room light off 45 seconds after last motion detected.
    - platform: state
      to: 'off'
      for:
        seconds: 45
    - service: light.turn_off
yes it’s running. A few minutes ago as I wrote to you all, all things worked normally.
The only error I can see in the log of MQTT broker is:
2023-02-22 12:28:26: Client disconnected, not authorised.
2023-02-22 12:28:27: New connection from 172.30.33.7:53252 on port 1883.
Here. Your “And” has only one condition, so there is nothing for it to compare to.
This doesn’t mean “motion detected” and “nigthtmode off”, although it does technically work that way because of the default way multiple conditions work. The “and” applies to everything within its own code block. Im not sure if I’m explaining this well, but what you’re effectively doing is “motion detected” and [result of and conditions]
This would do the same:
      - conditions:
          - condition: trigger
          - condition: state
            state: "off"
If this was an “or” condition, it wouldn’t work the way I think you’d expect:
      - conditions:
          - condition: or
            conditions:
              - condition: state
                state: "off"
Here, you’d be doing “motion detected” and [result of or conditions]
ok now I understand, it’s not the best way for coding, right? but it works :blush:
Now I solved the issue, it was because I forgot the setup the new password for my users in HA after changing it yesterday. sorry.
