Motor on a roller blind - ESPHome version?
The secrets.yaml file contains the actual values for everything marked as !secret in the master yaml file. You don’t need it if you just replace all the !secret marks with their appropriate values. As for mqtt, if you’re not using one then I think you can not have those lines and rely on HA instead
So i got your setup build and now testing, calibration mode seems to be very hard to get to
esphome:
  platform: ESP8266
  board: nodemcuv2
  esp8266_restore_from_flash: true
  on_boot:
    then:
      - if:
          condition:
#           shade thinks it's at 0 but endstop is not triggered
            lambda: "if ((id(stepper_position) == 0) && (id(endstop).state == 0)) { return 1; } else { return 0; }"
          then:
#             open to blind to calibrate the endstop, remember the steps to do so, put the blind back to where it was
            - globals.set:
                value: '1'
#             set the assumed stepper position to stepper_steps + 4000 and have it travel to 0
            - stepper.report_position:
                position: !lambda "return id(stepper_steps) + 4000;"
            - stepper.set_target:
                target: 0
#             wait until the stepper is no longer moving
            - wait_until:
                - lambda: "if (id(my_stepper).current_position == id(my_stepper).target_position) { return 1; } else { return 0; }"
#             now move the blind back to however many steps it took to reach the endstop
                target: !lambda "return id(stepper_steps) + 4000 - id(stepper_prevpos);"
            - globals.set:
                value: '1'
            - delay: !lambda "return ((id(my_stepper).target_position - 834) * 2) + 3334;"
            - globals.set:
                value: !lambda "return id(my_stepper).target_position;"
            - globals.set:
                value: '0'
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: !secret ap_ssid
    password: !secret ap_password
# Enable Home Assistant API
api:
captive_portal:
web_server:
  port: 80
# Enable logging
logger:
ota:
globals:
  - id: stepper_steps
    type: int
    initial_value: '0'
    restore_value: true
  - id: stepper_prevpos
    type: float
    initial_value: '0'
  - id: stepper_position
    type: float
    initial_value: '0'
  - id: stepper_state
    type: int
    initial_value: '0'
  - id: calib_state
    type: int
    initial_value: '0'
  - platform: uptime
switch:
  - platform: restart
binary_sensor:
  - platform: gpio
    pin:
      number: D5
      mode: INPUT_PULLUP
    filters:
        - invert:
        - delayed_on: 10ms
    on_click:
    - min_length: 50ms
      max_length: 1000ms
      then:
        - lambda: |
            if ((id(stepper_state) == 0) && (id(endstop).state == 0)) {
              //shade is stopped and not already open at endstop
              id(blind).open();
            } else {
              //shade is moving
              id(blind).stop();
  - platform: gpio
    pin:
      number: D6
      mode: INPUT_PULLUP
    filters:
        - invert:
        - delayed_on: 10ms
    on_click:
    - min_length: 50ms
      max_length: 1000ms
      then:
        - lambda: |
            if ((id(stepper_state) == 0) && (id(stepper_position) < id(stepper_steps))) {
              //shade is stopped and not already closed
              id(blind).close();
            } else {
              //shade is moving
              id(blind).stop();
#     a 10s press on the down button will enter calibration mode
#     shutter goes all the way up and then travels down until a button is pressed
#     where shutter is stopped is the new stepper_steps value
    - min_length: 5000ms
      max_length: 15000ms
      then:
        - lambda: |
            id(calib_state) = 1;
              id(blind).open();
            } else if ((id(stepper_state) == 0) && (id(endstop).state == 1)) {
              //shade is stopped and already open at endstop
              id(blind).close();
  - platform: gpio
    pin:
      number: D7
      mode: INPUT_PULLUP
    filters:
        - invert:
    on_press:
      then:
#         hit the endstop, store the current steps value and reset stepper position to 0
        - globals.set:
            value: !lambda "return id(my_stepper).current_position;"
            position: 0
#         just in case, also set the target to 0
            target: 0
        - lambda: |
            if (id(stepper_state) == 1) {
              //shade is moving
              id(blind).stop();
cover:
    open_action:
      - globals.set:
          value: '1'
#       overshoot past the endstop to make sure it's hit (endstop will stop blind)
          target: -4000
      - wait_until:
      - globals.set:
      - globals.set:
          value: '0'
      - if:
          condition:
#           reached past the 'top' but still haven't triggered the endstop yet
            lambda: "if(id(stepper_position) == -4000 && id(endstop).state == 0) { return 1; } else { return 0; }"
          then:
#           reset stepper position to 0
              position: 0
              target: 0
    close_action:
      - globals.set:
          value: '1'
#         for calibration the number of steps is doubled
          target: !lambda "if(id(calib_state) == 0) { return id(stepper_steps); } else { return id(stepper_steps) * 2; }"
      - wait_until:
      - globals.set:
      - globals.set:
          value: '0'
      - lambda: |
          if (id(calib_state) == 1) {
            //reached double the current stepper distance
            id(stepper_steps) = id(stepper_position);
            //continue with calibration
            id(blind).close();
    stop_action:
          target: !lambda "return id(my_stepper).current_position;"
      - globals.set:
      - globals.set:
          value: '0'
      - lambda: |
          if (id(calib_state) == 1 && id(endstop).state == 0) {
            //stopping at something other than the endstop
            id(calib_state) = 0;
      - cover.template.publish:
          position: !lambda "return 1 - (id(stepper_position) / id(stepper_steps));"
    position_action:
          target: !lambda "return id(stepper_steps) * (1 - pos);"
    optimistic: true
    assumed_state: true
    has_position: true
stepper:
  - platform: a4988
    dir_pin: D3
    step_pin: D2
    max_speed: 500 steps/s
    # Optional:
    sleep_pin: D1
    acceleration: 300
    deceleration: 300
the switch’s do register correct in the small web portal ie up/down and endstop
but holding the down for 10 sec with the endstop activated does nothing
If anyone is interested, I’ve had this setup working reliably for two months or so.
esphome:
  platform: ESP32
  board: nodemcu-32s
wifi:
  password: !secret wifi_pass
  # manual_ip:
  #   static_ip: 192.168.107.22
  #   gateway: 192.168.107.1
  #   subnet: 255.255.255.0
  ap:
    ssid: "Projector Screen Basement (VS)"
    password: "XXXX"
captive_portal:
api:
  reboot_timeout: 60s
ota:
logger:
output:
  - platform: gpio
    pin: GPIO12
  - platform: gpio
    pin: GPIO14
  - platform: ledc
    pin: GPIO27
switch: #drive screen up or down at full speed, when so desired
  - platform: output
    output: down
    on_turn_on:
      then:
        - output.turn_on: pwm
  - platform: output
    output: up
    on_turn_on:
      then:
  - platform: restart
    name: "Reboot Projector Node"
sensor: #encoder
  - platform: rotary_encoder
    pin_a:
      number: GPIO5
      mode: INPUT_PULLDOWN
    pin_b:
      number: GPIO17
    internal: true #having it not show up in the HA GUI seems to help with capture accuracy
    resolution: 1
cover: #screen motor control
    optimistic: true
    open_action:
      - output.turn_off: down
      - output.set_level:
          level: "80%"
      - output.turn_on: up
      - wait_until:
          lambda: 'return id(step_counter).state >= 0;' #rolled up
      - switch.turn_off: up_1
      - delay: 1s
      - sensor.rotary_encoder.set_value:
          value: 0
    close_action:
      - output.turn_off: up
      - output.set_level:
          level: "50%"
      - output.turn_on: down
      - wait_until:
          lambda: 'return id(step_counter).state <= -8000;'
      - switch.turn_off: down_1
      - delay: 1s
          value: -8000 #fully unrolled
    stop_action:
      - output.turn_off: pwm
It’s driving a 100inch (diagonal) projector screen, which is clearly a lot heavier than your typical shade, so your motor wouldn’t need the level of gearing mine has.
Basically, I have a 24v DC motor with a worm gear box and shaft encoder connected to one end of the projector. Using an esp32 and a VNH5019 motor driver (which is more powerful than I need, but it was the only 24v capable driver I had on hand), I setup a cover to open/close (i.e.,roll down/roll up) the screen. In my case, 0 is ‘rolled up’ and -8000 is rolled down. The encoder on the shaft tracks these numbers (my cover does reset the encoder’s count to be exactly the 0 or -8000, cause it does over/undershoot by a few steps, but not to the degree where it is visibly noticeable).
LEDC is a PWM implementation specific to the esp32: I don’t believe you can use it with an 8266, but esphome has a comparable PWM component for 8266. LEDC basically let’s be manipulate the PWM frequency and/or duty cycle. In my case, you can see me changing the duty cycle in the cover actions (e.g., level: “50%” is a 50% duty cycle). I found that, by reducing the duty cycle (which you can kind of think of like reducing the “power”), I get a more accurate reading from the encoder. Obviously I give a high duty cycle when the motor is trying to roll the project screen back up vs. lowering it (80% vs. 50%).
Like I said, it works consistently. I’m still experimenting with getting a proper PID in place, but in the meantime…
Items:
    - lambda: |
          id(blind).open();
          id(blind).close();
when i start calibration with endstop active nothing happens
with the endstop not active it does go up but it never goes down to do the actual calibration
Calibration Mode: With the blind at full open, press and hold the Down (close) button for 10s. The blind will start going Down (close) until a button is pressed.
that is not the case, at full open the endstop would be active, and if it is and i enter calibration mode it will not go anywhere
I’m having the same issue, did you manage to find any resolution?
i found this github repro: https://github.com/RoadkillUK/Motor-on-a-Roller-Blind-for-ESPHOME
i combined the tesblind.yaml and common_blind.yaml to one file and came up with this:
# 1) Press button for > 1 second to enter setup mode
# 2) Press button again to start the blind closing
# 3) Press button again when closed and blind starts to open (actually resets the stepper position to 0)
# 4) Press button again when blind is fully open
# 5) Job Done
# Button is also used to open/close the blind (must be fully open/closed first)
esphome:
  platform: ESP8266
  board: nodemcuv2
  esp8266_restore_from_flash: True
  on_boot:
    - priority: -200.0
      then:
      - stepper.report_position: # Set stepper to global variable
          position: !lambda return id(my_stepper_global);
      - stepper.set_target: # Set stepper to global variable
          target: !lambda return id(my_stepper_global);
      - if: # If blind is Closed
          condition:
            - lambda: 'return id(my_stepper_global) == 0;'
          then: # Publish state etc.
                state: CLOSED
                current_operation: IDLE
      - if: # If blind is Open
          condition:
            - lambda: 'return id(my_stepper_global) == id(endstop);'
                state: OPEN
      - if: # If blind is Neither
          condition:
            - lambda: 'return (id(my_stepper_global) != 0) && (id(my_stepper_global) != id(endstop));'
          then: #  # Publish state etc.
                position: !lambda 'return (float(float(id(my_stepper).current_position) / float(id(endstop))));'
wifi:
  ap:
    ssid: Roller Blind
web_server:
  port: 80
logger:
api:
ota:
captive_portal:
stepper:
  - platform: a4988
    dir_pin:
      number: D3
      inverted: True
    step_pin: D2
    sleep_pin: D1
    max_speed: 500 steps/s # Set the speed of the motor
    acceleration: 300
    deceleration: 300
globals:
  - id: my_stepper_global # Integer for storing the stepper position in case of reboot
    type: int
    restore_value: True
    initial_value: '0'
  - id: openclosed # Boolean to store OPEN/CLOSED state
    type: bool
    restore_value: True
    initial_value: '0'
  - id: endstop # Variable for storing ENDSTOP (how far to move stepper)
    type: int
    restore_value: True
    initial_value: '1000'
  - id: settingmode # Integer for Setup Mode
    type: int
    restore_value: no
    initial_value: '0'
binary_sensor:
  - platform: gpio
    pin:
      number: D6 # Connect Button to D6 and GND
      mode: INPUT_PULLUP
      inverted: True
    internal: True
    on_click:
    - min_length: 50ms
      max_length: 500ms
      then: # Short press to OPEN/CLOSE blinds and also for setting up
        - if: # If settings variable is on
            condition:
              - lambda: 'return id(settingmode) != 0;'
            then: # Enter Setting Mode
              - script.execute: setupbutton
            else:
              - if: # If blind is closed
                  condition:
                    - lambda: 'return id(openclosed) == 0;'
                  then: # Open blind
                    - cover.open: blinded
                  else: # Close blind
                    - cover.close: blinded
    - min_length: 1000ms
      max_length: 3000ms
      then: # Long press to Enter Setting Mode
        - logger.log: "Entered Settings Mode"
        - globals.set:
            value:  '1'
switch:
    name: Roller Blind Setup Switch # Switch to enter Setup Mode
    lambda: |-
      if (id(settingmode) != 0) {
        return true;
      } else {
        return false;
    turn_on_action:
      then:
        - globals.set:
            value:  '1'
    turn_off_action:
      then:
        - logger.log: "Exiting Settings Mode"
        - globals.set:
            value:  '0'
    name: Roller Blind Setup Button # Switch to replicate the Physical Button
    turn_on_action:
          condition:
            - switch.turn_off: hasetup
cover:
    open_action:
      then:
        - logger.log: "Opening"
        - stepper.set_target: # Send stepper to endstop
            target: !lambda return id(endstop);
        - while:
            condition:
              lambda: 'return id(my_stepper).current_position != id(endstop);'
            then:
                  current_operation: OPENING
              - delay: 1000 ms
        - globals.set: # Set global to current position
            value: !lambda return id(my_stepper).current_position;
        - globals.set: # Set toggle to OPEN (No need for 'optimistic mode')
            value: '1'
            state: OPEN
    close_action:
      then:
        - logger.log: "Closing"
        - stepper.set_target: # Send stepper to 0
            target: '0'
        - while:
            condition:
              lambda: 'return id(my_stepper).current_position != 0;'
            then:
                  current_operation: CLOSING
              - delay: 1000 ms
        - globals.set: # Set toggle to CLOSED (No need for 'optimistic mode')
            value: '0'
            state: CLOSED
    position_action:
      then:
            target: !lambda return int(id(endstop) * pos);
        - while:
            condition:
              lambda: 'return id(my_stepper).current_position != int(id(endstop) * pos);'
            then:
              - delay: 1000 ms
    stop_action:
      then:
            target: !lambda return id(my_stepper).current_position;
    has_position: true
    device_class: blind
script:
  - id: setupbutton
    then:
      - if:
          condition:
            - lambda: 'return (id(settingmode) == 3);'
          then:
            - logger.log: "Pressed Setup Button: Mode 3"
            - stepper.set_target: # Set Stepper position
            - globals.set: # Set Endstop Variable
            - globals.set: # Set Global stepper position
            - globals.set: # Reset Setting Mode
                value:  '0'
            - globals.set: # Set toggle to Open
                value: '1'
                state: OPEN
            - logger.log: "Exiting Setting Mode"
      - if:
          condition:
            - lambda: 'return (id(settingmode) == 2);'
          then:
            - logger.log: "Pressed Setup Button: Mode 2"
            - stepper.report_position: # Reset Stepper position to 0
                position: '0'
            - stepper.set_target: # Reset Stepper position to 0
                target: '0'
            - globals.set: # Move stepper to 0 (doesn't move it's already there!)
                value: '0'
            - stepper.set_target: # Reset Stepper position to 72000
                target: '72000'
            - globals.set: # Advance setup to next mode
                value:  '3'
      - if:
          condition:
            - lambda: 'return (id(settingmode) == 1);'
          then:
            - logger.log: "Pressed Setup Button: Mode 1"
            - stepper.report_position: # Set Stepper position to 72000, makes it move to 0 (Closed)
                position: '72000'
                value:  '2'
the thing that is lost is that it goes up to endstop on boot, but the calibration works
and there is only one hardware button. So in the end not a great stepback considered i have tested it
the only thing to test is whatever one or 2 stepper motors are needed.
the printed parts i found on thingiverse but cant remember what thing.
EDIT: https://www.thingiverse.com/thing:2065722 was the one, i dont use the box thou.
and the part that goes in to the roller blind has to be adjusted to fit. if only one stepper is needed i also made a “dummy” version that just has a 608 bearing in it. in that way its the same in both ends. looks symetric. i then designed a bracket that can holde the stepper. the bracket is 2 parts where one parts slides in sideways. that makes it easy to the the whole blind down when cleaning
Glad I could help :wink:
yeah, i’m no good at programming but i managed to melt the 2 files together
i thought for a long time that it would be a shame to loose the endstop but not when you think long enough. and it makes the wiring more simple
If you put the 2 files in esphome directory, you only have to change/copy the testblinds.yaml to add more blinds (seperate esp’s)
I’m not the best programmer, I forget more than I learn :slight_smile:
I don’t actually use any physical buttons on the blind itself, I just use the webpage instead. It actually works quite well as I use it on 4 blinds and one of them got stuck last week and lost it’s calibration, sorted in no time at all.
The repo you found is actually further up in this post :slight_smile:
Im using this print I put together from others I found. I use it to pull my heave blinds.
Is everyone having the same jittering when using stepper motors? like it stops for a split second after every turn?
What sketch/repo are you using?
I think you’ll find it’s this line (and similar ones further down) that cause the delay as the blind reports it’s position, I’m not sure there’s a way around it (or I’ve not really looked that hard :slight_smile:)
I’ve ordered all my supplies to start building my own blinds now. Cant wait to get started. I have windows side by side at each location which require 2 blinds. Does anyone know if i can use a single esp board to control them individually or will i need to have 2?
What have you ordered for motor and steering?
I’ve ordered 12v 28BYJ-48 and a ULN2003
And that together with the thingiverse? Or?
Let us know the result!
