Naaaa, forget it. For automation something more solid is needed. I think the problem is that it takes value every 30 minutes for battery concern. I think is too much
well at that price it make sense the Hue PIR and light sensor … small, slick, it should work fine. Not too sure about the broadlink seeing how the temp sensor of the rmpro behaves …
This is a pretty old post, but I just want to say I saw this comment the other day when looking for a cheap light sensor, and I ended up building one as you described with a NodeMCU board.
In total, it cost me about $17 (I ordered on Amazon because I was impatient… if you ordered from China it would be much cheaper. Most expensive thing was the power supply oddly enough) and took about 3 hours to setup from start to finish (would have taken less time but I ran into some issues connecting my NodeMCU board to my Mac).
I flashed the board with the sketch from the BRUH Automation Multisensor. It works extremely well. I don’t have an enclosure for it yet, but I’m working on finding one or making one to 3D print.
BRUH Automation has an awesome video tutorial for how to set this up as well (just leave out the sensors you don’t need).
Anyway, to anyone who comes across this topic later, I’d recommend this as the way to go. Easy, cheap, and pretty fun to set up. Thanks @Zen
Another reply to an old topic, but if someone comes across this thread, here is another simple ESP-based option with several sensors on a small board for ~$12 on Aliexpress.com
