Moving from RPi to Docker
Does this give any clues as to where I may be going wrong?
So you have your path set to
/Users/ashleyscott/Downloads/homeassistant
Is this where your files are?
Did you restart the container after copying the files there?
Yes. Container has been restarted.
Here’s my config.yaml:
homeassistant:
  latitude:
  longitude:
  elevation: 192
  unit_system: metric
  time_zone: Europe/London
  customize: !include customize.yaml
frontend:
  themes: !include themes.yaml
config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
  base_url: http://localhost:8123/
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
  # Optional, allows Home Assistant developers to focus on popular components.
  # include_used_components: true
discovery:
camera:
  - platform: generic
    host: 10.0.1.77
    username:
    password:
    port: 9003
    still_image_url: http://10.0.1.77/jpg/image.jpg
influxdb:
  host: a0d7b954-influxdb
  port: 8086
  database: homeassistant
  username: homeassistant
  password: homeassistant
  max_retries: 3
  default_measurement: state
ffmpeg:
notify:
  - name: Prowl
    platform: prowl
    api_key: !secret prowl_api
  - name: neil_prowl
    platform: prowl
    api_key: !secret neil_prowl_api
  - name: iPhone
    platform: ios
    target: !secret ios_ash_x_push_id
  - platform: webostv
    host: 10.0.1.141
    filename: webostv.conf
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# lovelace:
#   mode: yaml
tts:
  - platform: google
weather:
  - platform: darksky
    api_key: !secret dark_sky_api
# Cloud
cloud:
  google_actions:
    filter:
      include_domains:
        - script
recorder:
ifttt:
  key: !secret IFTTT_webhook_api
panel_iframe:
  ide:
    title: IDE
    icon: mdi:code-braces
    url: http://10.0.1.32:8321
group: !include_dir_merge_named groups/
alert: !include alerts.yaml
input_number: !include input_number.yaml
script: !include scripts.yaml
binary_sensor: !include binary_sensor.yaml
switch: !include switch.yaml
sensor: !include sensor.yaml
input_boolean: !include booleans.yaml
input_select: !include input_select.yaml
cover: !include cover.yaml
automation: !include_dir_merge_list automation/
zone: !include zones.yaml
timer: !include timers.yaml
Well, for starters, discovery: will not work with you specifying a port to pass through. You need a --net=host, but I don’t think you can do that on Mac. This should be covered in the docs.
What shows up when you run docker ps -a? I suspect you have more than one instance running.
I think you’re right.
How do I get rid of the other one?
docker ps -a
the ? was indicating I was asking a question.
I spotted that too late!
I’ve edited it above.
docker kill homeassistant && docker rm homeassistant && docker kill home-assistant && docker rm home-assistant
Then run your docker run command again
Will that remove both so I start again?
yes. you could technically remove all the docker containers that are running, because it doesn’t look like any of them are important
OK, thank you. I’ll do that.
How do I get an MQTT container configured?
Perhaps you should look at this:
https://hub.docker.com/_/eclipse-mosquitto
Thank you.
All is now good. Just need to get the MQTT broker running and I’ll be done.
Thank you for your time and help. I appreciate it.
My Docker Stack shows you how a docker-compose file goes together, and the other link was the official documentation to get MQTT running on docker.
It’s not hard at all. Just understand how volumes get mounted, and permissions of the files.
