I currently struggeling how do Manage the MQTT user correctly.
As in the documentation shown, I only have to create an HA User and this user would be able to connecto to the mqtt broker addon.
Yes, thats working, but for now, every mqtt user (e.g. for Power-Plugs, Victron, …) will be able to logon to the HA Webinterface.
So is there any way of permission-management?
I tried to add on user only for the addon trough the configuration, but that didn’t work.
Everytime i press the save button i get an unexpect error:
“Fehler beim Speichern der Add-on-Konfiguration, Unknown error, see supervisor logs”
I wondered that too when faced with the problem of adding users via the user menu. Does it work if set them as not able to login?
I didn’t try that.
Anyway you can add via the addon. It’s picky about the format. You can do it with or without secrets. If you use secrets you usually have to add the user/pass to the secrets file, then restart, then add them to the addon.
