Thanks. I need to find a step by step to install HassIO in docker.
I installed HA OK, but not HassIO and had no joy withgetting Mosquitto password and user configured.
ok, I just checked the console of sonoff tasmota and saw the following when I clicked the switch :
16:45:24 MQT: stat/HA/living/RESULT = {“Command”:“Unknown”}
here is my code in my configuration.yaml :
switch:
so what could be wrong?
Do you have Tasmota?
If yes, the command topic should be %prefix%/%topic%/
So if the %topic% is HA the should be something like RELAY1 or POWER1.
Where did you get living?
“living” is dutch for the place where we have our couch and TV
I want to have different sonoffs in my house, so I need to configure them each differently (each their own topic)
I think you need to add /POWER
to the end of both of your topic strings
For my tasmota flashed Sonoff basics I use this config (topic is lamp)
mqtt:
embedded:
switch:
- platform: mqtt
state_topic: "stat/lamp/POWER"
command_topic: "cmnd/lamp/POWER"
availability_topic: "tele/lamp/LWT"
qos: 1
payload_on: "ON"
payload_off: "OFF"
payload_available: "Online"
payload_not_available: "Offline"
retain: false
I know what living stands for
As also @reef-actor said, you need to complete the cmnd with POWER if your sonoff has just one relay.
Same thing for the state_topic
It works!
woohoo, so glad!
2 more questions and then this topic is closed for me.
Is mqtt / tasmota case sensitive?
Because sometimes you see users using : POWER, Power, power, …
after I change something in the configuration.yaml, I always reboot my mini PC, is there another way for just resetting the layout of the screen?
@woody4165 : I still use Mosquitto by the way, didn’t change to the embedded broker, so Mosquitto works without a problem.
I think Tasmota is case sensitive
Complete reboot PC??? No!
If you change just lovelace.yaml, if you’re using it, there is nothing to do.
If you change any other yaml files, you can just restart HA with Settings->General->Restart, but I suggest always to do a Check before restarting
Well done for Mpsquitto
lovelace.yaml?
ui-lovelace.yaml
is the file where you can optionally manually configure the layout of your pages (documentation). If you are using the visual editor (the default) you will not have it.
What version of HA do you have?
