Every 30 seconds.
can you define that somewhere? or is it just the default scan_interval ?
It’s the default.
But you can try to overrule https://www.home-assistant.io/docs/configuration/platform_options/#scan-interval
Ok, tried your add-on, it’s working very good…
Is it also possible to display historical data like on solar online portal, like block graphs per month
I think you need to download historical data from it
Hi gieljnssns
Your github destination https://github.com/gieljnssns/My-Hassio-config/blob/master/config/custom_components/sensor/kostal.py is no longer available. Is it possible that you would like to share the component again?
hey
i am using it also
here you go, a copy of mine
Hey,
can you share your file with me pls.
sensor.py for kostal
You can find it here
And here
